slice level data used with slice level decoding
Definition at line 442 of file nvmedia_common.h.
Data Fields | |
| uint32_t | uBitstreamDataLen |
| Bitstream data. More... | |
| uint8_t * | pBitstreamData |
| Ptr to bitstream data for this picture (slice-layer) More... | |
| uint32_t | uNumSlices |
| Number of slices in this SliceData. More... | |
| uint32_t * | pSliceDataOffsets |
| If not NULL, nNumSlices entries, contains offset of each slice within the bitstream data buffer. More... | |
| uint32_t | uCTBCount |
| Number of CTB present in this CTB. More... | |
| uint32_t | uFirstCtbAddr |
| CTB number of first CTB in the slice data. More... | |
| NvMediaBool | bFirstSlice |
| First slice flag: whether this SliceData contains first slice of frame. More... | |
| NvMediaBool | bLastSlice |
| Last slice flag: whether this SliceData contains last slice of frame. More... | |
| NvMediaBool | bErrorFlag |
| Error flag if some parsing error detected. More... | |
| NvMediaBool NvMediaSliceDecodeData::bErrorFlag |
Definition at line 462 of file nvmedia_common.h.
| NvMediaBool NvMediaSliceDecodeData::bFirstSlice |
Definition at line 458 of file nvmedia_common.h.
| NvMediaBool NvMediaSliceDecodeData::bLastSlice |
Definition at line 460 of file nvmedia_common.h.
| uint8_t* NvMediaSliceDecodeData::pBitstreamData |
Definition at line 448 of file nvmedia_common.h.
| uint32_t* NvMediaSliceDecodeData::pSliceDataOffsets |
Definition at line 452 of file nvmedia_common.h.
| uint32_t NvMediaSliceDecodeData::uBitstreamDataLen |
Bitstream data.
Number of bytes in bitstream data buffer
Definition at line 446 of file nvmedia_common.h.
| uint32_t NvMediaSliceDecodeData::uCTBCount |
Definition at line 454 of file nvmedia_common.h.
| uint32_t NvMediaSliceDecodeData::uFirstCtbAddr |
Definition at line 456 of file nvmedia_common.h.
| uint32_t NvMediaSliceDecodeData::uNumSlices |
Definition at line 450 of file nvmedia_common.h.
