9.0/sources/apps/apps-common/includes/deepstream_sources.h File Reference
Data Structures
struct  NvDsSourceConfig
struct  NvDsSrcBin
struct  NvDsSrcParentBin
Typedefs
typedef struct NvDsSrcParentBin NvDsSrcParentBin
Enumerations
enum  NvDsSourceType {
  NV_DS_SOURCE_CAMERA_V4L2 = 1,
  NV_DS_SOURCE_URI,
  NV_DS_SOURCE_URI_MULTIPLE,
  NV_DS_SOURCE_RTSP,
  NV_DS_SOURCE_CAMERA_CSI,
  NV_DS_SOURCE_AUDIO_WAV,
  NV_DS_SOURCE_AUDIO_URI,
  NV_DS_SOURCE_ALSA_SRC,
  NV_DS_SOURCE_IPC,
  NV_DS_SOURCE_URI,
  NV_DS_SOURCE_RTSP,
  NV_DS_SOURCE_IPC
Functions
gboolean create_source_bin (NvDsSourceConfig *config, NvDsSrcBin *bin)
gboolean create_audio_source_bin (NvDsSourceConfig *config, NvDsSrcBin *bin)
gboolean create_multi_source_bin (guint num_sub_bins, NvDsSourceConfig *configs, NvDsSrcParentBin *bin)
 Initialize NvDsSrcParentBin. More...
gboolean create_nvmultiurisrcbin_bin (guint num_sub_bins, NvDsSourceConfig *configs, NvDsSrcParentBin *bin)
gboolean reset_source_pipeline (gpointer data)
gboolean set_source_to_playing (gpointer data)
gpointer reset_encodebin (gpointer data)
void destroy_smart_record_bin (gpointer data)
Typedef Documentation
◆ NvDsSrcParentBin
◆ NvDsSourceType
Enumerator
NV_DS_SOURCE_URI
NV_DS_SOURCE_RTSP
NV_DS_SOURCE_IPC
NV_DS_SOURCE_URI
NV_DS_SOURCE_RTSP
NV_DS_SOURCE_IPC
Definition at line 25 of file 9.0/sources/apps/apps-common/includes/deepstream_sources.h.
Function Documentation
◆ create_audio_source_bin()
gboolean create_audio_source_bin ( NvDsSourceConfig config,
NvDsSrcBin bin
◆ create_multi_source_bin()
gboolean create_multi_source_bin ( guint  num_sub_bins,
NvDsSourceConfig configs,
NvDsSrcParentBin bin
It creates and adds source and other elements needed for processing to the bin. It also sets properties mentioned in the configuration file under group CONFIG_GROUP_SOURCE
Parameters
[in]num_sub_binsnumber of source elements.
[in]configsarray of pointers of type NvDsSourceConfig parsed from configuration file.
[in]binpointer to NvDsSrcParentBin to be filled.
Returns
true if bin created successfully.
◆ create_nvmultiurisrcbin_bin()
gboolean create_nvmultiurisrcbin_bin ( guint  num_sub_bins,
It creates and adds nvmultiurisrcbin needed for processing to the bin. It also sets properties mentioned in the configuration file under group CONFIG_GROUP_SOURCE_LIST, CONFIG_GROUP_SOURCE_ALL
Parameters
Returns
◆ create_source_bin()
gboolean create_source_bin ( NvDsSourceConfig config,
NvDsSrcBin bin
◆ destroy_smart_record_bin()
void destroy_smart_record_bin ( gpointer  data)
◆ reset_encodebin()
gpointer reset_encodebin ( gpointer  data)
◆ reset_source_pipeline()
gboolean reset_source_pipeline ( gpointer  data)
◆ set_source_to_playing()
gboolean set_source_to_playing ( gpointer  data)
