7.1 Release
NvDsSourceConfig Struct Reference
Definition at line 38 of file deepstream_sources.h.
Collaboration diagram for NvDsSourceConfig:
Data Fields
NvDsSourceType type
gboolean enable
gboolean loop
gboolean live_source
gboolean Intra_decode
gboolean low_latency_mode
guint smart_record
gint source_width
gint source_height
gint source_fps_n
gint source_fps_d
gint camera_csi_sensor_id
gint camera_v4l2_dev_node
gchar * uri
gchar * dir_path
gchar * file_prefix
gint latency
guint smart_rec_cache_size
guint smart_rec_container
guint smart_rec_def_duration
guint smart_rec_duration
guint smart_rec_start_time
guint smart_rec_interval
guint num_sources
guint gpu_id
guint camera_id
guint source_id
guint select_rtp_protocol
guint num_decode_surfaces
guint num_extra_surfaces
guint nvbuf_memory_type
guint cuda_memory_type
NvDsDewarperConfig dewarper_config
guint drop_frame_interval
gboolean extract_sei_type5_data
gint rtsp_reconnect_interval_sec
guint rtsp_reconnect_attempts
gboolean rtsp_reconnect_attempt_exceeded
guint udp_buffer_size
guint input_audio_rate
 Desired input audio rate to nvinferaudio from PGIE config; This config shall be copied over from NvDsGieConfig at create_multi_source_bin() More...
gchar * alsa_device
 ALSA device, as defined in an asound configuration file. More...
gchar * video_format
 Video format to be applied at nvvideoconvert source pad. More...
Field Documentation
◆ alsa_device
gchar* NvDsSourceConfig::alsa_device
Definition at line 88 of file deepstream_sources.h.
◆ camera_csi_sensor_id
gint NvDsSourceConfig::camera_csi_sensor_id
Definition at line 51 of file deepstream_sources.h.
◆ camera_id
guint NvDsSourceConfig::camera_id
Definition at line 65 of file deepstream_sources.h.
◆ camera_v4l2_dev_node
gint NvDsSourceConfig::camera_v4l2_dev_node
Definition at line 52 of file deepstream_sources.h.
◆ cuda_memory_type
guint NvDsSourceConfig::cuda_memory_type
Definition at line 71 of file deepstream_sources.h.
◆ dewarper_config
NvDsDewarperConfig NvDsSourceConfig::dewarper_config
Definition at line 76 of file deepstream_sources.h.
◆ dir_path
gchar* NvDsSourceConfig::dir_path
Definition at line 54 of file deepstream_sources.h.
◆ drop_frame_interval
guint NvDsSourceConfig::drop_frame_interval
Definition at line 77 of file deepstream_sources.h.
◆ enable
gboolean NvDsSourceConfig::enable
Definition at line 41 of file deepstream_sources.h.
◆ extract_sei_type5_data
gboolean NvDsSourceConfig::extract_sei_type5_data
Definition at line 78 of file deepstream_sources.h.
◆ file_prefix
gchar* NvDsSourceConfig::file_prefix
Definition at line 55 of file deepstream_sources.h.
◆ gpu_id
guint NvDsSourceConfig::gpu_id
Definition at line 64 of file deepstream_sources.h.
◆ input_audio_rate
guint NvDsSourceConfig::input_audio_rate
Definition at line 86 of file deepstream_sources.h.
◆ Intra_decode
gboolean NvDsSourceConfig::Intra_decode
Definition at line 44 of file deepstream_sources.h.
◆ latency
gint NvDsSourceConfig::latency
Definition at line 56 of file deepstream_sources.h.
◆ live_source
gboolean NvDsSourceConfig::live_source
Definition at line 43 of file deepstream_sources.h.
◆ loop
gboolean NvDsSourceConfig::loop
Definition at line 42 of file deepstream_sources.h.
◆ low_latency_mode
gboolean NvDsSourceConfig::low_latency_mode
Definition at line 45 of file deepstream_sources.h.
◆ num_decode_surfaces
guint NvDsSourceConfig::num_decode_surfaces
Definition at line 68 of file deepstream_sources.h.
◆ num_extra_surfaces
guint NvDsSourceConfig::num_extra_surfaces
Definition at line 69 of file deepstream_sources.h.
◆ num_sources
guint NvDsSourceConfig::num_sources
Definition at line 63 of file deepstream_sources.h.
◆ nvbuf_memory_type
guint NvDsSourceConfig::nvbuf_memory_type
Definition at line 70 of file deepstream_sources.h.
◆ rtsp_reconnect_attempt_exceeded
gboolean NvDsSourceConfig::rtsp_reconnect_attempt_exceeded
Definition at line 81 of file deepstream_sources.h.
◆ rtsp_reconnect_attempts
guint NvDsSourceConfig::rtsp_reconnect_attempts
Definition at line 80 of file deepstream_sources.h.
◆ rtsp_reconnect_interval_sec
gint NvDsSourceConfig::rtsp_reconnect_interval_sec
Definition at line 79 of file deepstream_sources.h.
◆ select_rtp_protocol
guint NvDsSourceConfig::select_rtp_protocol
Definition at line 67 of file deepstream_sources.h.
◆ smart_rec_cache_size
guint NvDsSourceConfig::smart_rec_cache_size
Definition at line 57 of file deepstream_sources.h.
◆ smart_rec_container
guint NvDsSourceConfig::smart_rec_container
Definition at line 58 of file deepstream_sources.h.
◆ smart_rec_def_duration
guint NvDsSourceConfig::smart_rec_def_duration
Definition at line 59 of file deepstream_sources.h.
◆ smart_rec_duration
guint NvDsSourceConfig::smart_rec_duration
Definition at line 60 of file deepstream_sources.h.
◆ smart_rec_interval
guint NvDsSourceConfig::smart_rec_interval
Definition at line 62 of file deepstream_sources.h.
◆ smart_rec_start_time
guint NvDsSourceConfig::smart_rec_start_time
Definition at line 61 of file deepstream_sources.h.
◆ smart_record
guint NvDsSourceConfig::smart_record
Definition at line 46 of file deepstream_sources.h.
◆ source_fps_d
gint NvDsSourceConfig::source_fps_d
Definition at line 50 of file deepstream_sources.h.
◆ source_fps_n
gint NvDsSourceConfig::source_fps_n
Definition at line 49 of file deepstream_sources.h.
◆ source_height
gint NvDsSourceConfig::source_height
Definition at line 48 of file deepstream_sources.h.
◆ source_id
guint NvDsSourceConfig::source_id
Definition at line 66 of file deepstream_sources.h.
◆ source_width
gint NvDsSourceConfig::source_width
Definition at line 47 of file deepstream_sources.h.
◆ type
NvDsSourceType NvDsSourceConfig::type
Definition at line 40 of file deepstream_sources.h.
◆ udp_buffer_size
guint NvDsSourceConfig::udp_buffer_size
Definition at line 82 of file deepstream_sources.h.
◆ uri
gchar* NvDsSourceConfig::uri
Definition at line 53 of file deepstream_sources.h.
◆ video_format
gchar* NvDsSourceConfig::video_format
Definition at line 90 of file deepstream_sources.h.
