9.0/sources/includes/gst-nvevent.h
1 /*
2  * SPDX-FileCopyrightText: Copyright (c) 2018-2023 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
4  *
11  */
12
33 #ifndef __GST_NVEVENT_H__
34 #define __GST_NVEVENT_H__
35
36 #include <gst/gst.h>
37
38 #ifdef __cplusplus
39 extern "C" {
40 #endif
41
42 #define FLAG(name) GST_EVENT_TYPE_##name
43
47 typedef enum {
50  = GST_EVENT_MAKE_TYPE (400, FLAG(DOWNSTREAM) | FLAG(SERIALIZED) |
51  FLAG(STICKY) | FLAG(STICKY_MULTI)),
54  = GST_EVENT_MAKE_TYPE (401, FLAG(DOWNSTREAM) | FLAG(SERIALIZED) |
55  FLAG(STICKY) | FLAG(STICKY_MULTI)),
59  = GST_EVENT_MAKE_TYPE (402, FLAG(DOWNSTREAM) | FLAG(SERIALIZED) |
60  FLAG(STICKY) | FLAG(STICKY_MULTI)),
63  = GST_EVENT_MAKE_TYPE (403, FLAG(DOWNSTREAM) | FLAG(SERIALIZED) |
64  FLAG(STICKY) | FLAG(STICKY_MULTI)),
68  = GST_EVENT_MAKE_TYPE (404, FLAG(DOWNSTREAM) | FLAG(SERIALIZED) |
69  FLAG(STICKY) | FLAG(STICKY_MULTI)),
73  = GST_EVENT_MAKE_TYPE (405, FLAG(DOWNSTREAM) | FLAG(SERIALIZED) |
74  FLAG(STICKY) | FLAG(STICKY_MULTI)),
78  = GST_EVENT_MAKE_TYPE (406, FLAG(DOWNSTREAM) | FLAG(SERIALIZED) |
79  FLAG(STICKY) | FLAG(STICKY_MULTI))
80
82 #undef FLAG
83
94 GstEvent * gst_nvevent_new_pad_added (guint source_id);
95
106 GstEvent * gst_nvevent_new_pad_deleted (guint source_id);
107
118 GstEvent * gst_nvevent_new_stream_eos (guint source_id);
119
133 GstEvent * gst_nvevent_new_stream_segment (guint source_id, GstSegment *segment);
134
145 GstEvent * gst_nvevent_new_stream_reset (guint source_id);
146
162 GstEvent * gst_nvevent_new_update_caps (guint pad_id, guint width_val, guint height_val,
163  GstStructure *caps_str, gchar* stream_id_str, gboolean is_audio );
164
172 void gst_nvevent_parse_pad_added (GstEvent * event, guint * source_id);
173
181 void gst_nvevent_parse_pad_deleted (GstEvent * event, guint * source_id);
182
190 void gst_nvevent_parse_stream_eos (GstEvent * event, guint * source_id);
191
202 void gst_nvevent_parse_stream_segment (GstEvent * event, guint * source_id,
203  GstSegment **segment);
204
212 void gst_nvevent_parse_stream_reset (GstEvent * event, guint * source_id);
213
222 GstEvent * gst_nvevent_new_stream_start (guint source_id, gchar* stream_id);
223
234 void gst_nvevent_parse_stream_start (GstEvent * event, guint * source_id, gchar** stream_id);
235
236 #ifdef __cplusplus
237 }
238 #endif
239
240 #endif
241
GST_NVEVENT_STREAM_START
@ GST_NVEVENT_STREAM_START
Specifies a custom event to indicate start of a particular stream in a batch.
Definition: 9.0/sources/includes/gst-nvevent.h:72
void gst_nvevent_parse_pad_deleted(GstEvent *event, guint *source_id)
Parses a "pad deleted" event received on the sinkpad.
GstEvent * gst_nvevent_new_stream_eos(guint source_id)
Creates a "custom EOS" event for the specified source.
void gst_nvevent_parse_stream_segment(GstEvent *event, guint *source_id, GstSegment **segment)
Parses a "stream segment" event received on the sinkpad.
GST_NVEVENT_PAD_DELETED
@ GST_NVEVENT_PAD_DELETED
Specifies a custom event to indicate Pad Deleted.
Definition: 9.0/sources/includes/gst-nvevent.h:53
void gst_nvevent_parse_stream_reset(GstEvent *event, guint *source_id)
Parses a "stream reset" event received on the sinkpad.
GST_NVEVENT_PAD_ADDED
@ GST_NVEVENT_PAD_ADDED
Specifies a custom event to indicate Pad Added.
Definition: 9.0/sources/includes/gst-nvevent.h:49
GST_NVEVENT_UPDATE_CAPS
@ GST_NVEVENT_UPDATE_CAPS
Specifies a custom event to indicate update in caps of particular stream in a batch.
Definition: 9.0/sources/includes/gst-nvevent.h:77
GstEvent * gst_nvevent_new_stream_start(guint source_id, gchar *stream_id)
Creates a new "stream start" event.
GstEvent * gst_nvevent_new_update_caps(guint pad_id, guint width_val, guint height_val, GstStructure *caps_str, gchar *stream_id_str, gboolean is_audio)
Creates a "updated caps" event for the specified source.
GstEvent * gst_nvevent_new_pad_added(guint source_id)
Creates a "custom pad added" event for the specified source.
FLAG
#define FLAG(name)
Definition: 9.0/sources/includes/gst-nvevent.h:42
GST_NVEVENT_STREAM_EOS
@ GST_NVEVENT_STREAM_EOS
Specifies a custom event to indicate EOS of a particular stream in a batch.
Definition: 9.0/sources/includes/gst-nvevent.h:58
GstEvent * gst_nvevent_new_stream_reset(guint source_id)
Creates a "custom reset" event for the specified source.
GstEvent * gst_nvevent_new_pad_deleted(guint source_id)
Creates a "custom pad deleted" event for the specified source.
void gst_nvevent_parse_stream_start(GstEvent *event, guint *source_id, gchar **stream_id)
Parses a "stream start" event received on the sinkpad.
GST_NVEVENT_STREAM_RESET
@ GST_NVEVENT_STREAM_RESET
Specifies a custom event to indicate reset of a particular stream in a batch.
Definition: 9.0/sources/includes/gst-nvevent.h:67
GstEvent * gst_nvevent_new_stream_segment(guint source_id, GstSegment *segment)
Creates a "custom segment" event for the specified source.
void gst_nvevent_parse_stream_eos(GstEvent *event, guint *source_id)
Parses a "stream EOS" event received on the sinkpad.
GST_NVEVENT_STREAM_SEGMENT
@ GST_NVEVENT_STREAM_SEGMENT
Specifies a custom event to indicate a stream segment.
Definition: 9.0/sources/includes/gst-nvevent.h:62
GstNvEventType
GstNvEventType
Defines supported types of custom events.
Definition: 9.0/sources/includes/gst-nvevent.h:47
void gst_nvevent_parse_pad_added(GstEvent *event, guint *source_id)
Parses a "pad added" event received on the sinkpad.
