8.0 Release
13 #ifndef _NVDS_SERVER_H_
14 #define _NVDS_SERVER_H_
17 #include <unordered_map>
22 #include <json/json.h>
23 #define UNKNOWN_STRING "unknown"
24 #define EMPTY_STRING ""
250 std::pair < int, std::string >
err_log;
315 std::vector < RoiDimension >
vect;
455 const Json::Value & in,
456 Json::Value & out,
struct mg_connection * conn,
void *ctx)>;
483 class NvDsRestServer;
486 bool iequals (
const std::string & a,
const std::string & b);
@ INFER_INTERVAL_UPDATE_SUCCESS
struct NvDsServerTextEmbeddingInfo NvDsServerTextEmbeddingInfo
@ LOW_LATENCY_MODE_UPDATE_SUCCESS
std::string metadata_resolution
NvDsServerGetRequestStatus
NvDsServerInferPropFlag infer_flag
NvDsServerNvTrackerPropFlag
bool iequals(const std::string &a, const std::string &b)
NvDsServerNvTrackerStatus status
std::unordered_map< std::string, cb_func > custom_cb_endpt
@ GET_METADATA_INFO_SUCCESS
NvDsServerRoiPropFlag roi_flag
@ DROP_FRAME_INTERVAL_UPDATE_SUCCESS
NvDsServerConvStatus status
struct NvDsServerStreamInfo NvDsServerStreamInfo
NvDsServerMuxPropFlag mux_flag
NvDsServerStatusCode code
NvDsServerOsdStatus status
std::function< void(NvDsServerNvTrackerInfo *nvTracker_info, void *ctx) > nvTracker_cb
std::pair< int, std::string > err_log
@ BATCHED_PUSH_TIMEOUT_UPDATE_SUCCESS
NvDsServerErrorInfo err_info
std::function< NvDsServerStatusCode(const Json::Value &req_info, const Json::Value &in, Json::Value &out, struct mg_connection *conn, void *ctx)> cb_func
@ BATCHED_PUSH_TIMEOUT_UPDATE_FAIL
NvDsServerAppInstanceStatus
std::string value_camera_name
NvDsServerInferServerPropFlag inferserver_flag
@ TEXT_EMBEDDING_GENERATE_FAIL
void nvds_rest_server_stop(NvDsRestServer *ctx)
NvDsServerAppInstanceFlag
NvDsServerAnalyticsPropFlag
NvDsServerGetRequestPropFlag get_request_flag
std::string value_creation_time
std::function< void(NvDsServerOsdInfo *osd_info, void *ctx) > osd_cb
std::string headers_source
std::vector< RoiDimension > vect
struct NvDsServerMuxInfo NvDsServerMuxInfo
@ TEXT_EMBEDDING_GENERATE_SUCCESS
std::vector< NvDsSensorInfo * > sensorInfo_vec
std::function< void(NvDsServerEncInfo *enc_info, void *ctx) > enc_cb
@ DEST_CROP_UPDATE_SUCCESS
@ FORCE_INTRA_UPDATE_SUCCESS
std::function< void(NvDsServerAppInstanceInfo *appinstance_info, void *ctx) > appinstance_cb
guint drop_frame_interval
@ StatusProxyAuthenticationRequired
Flags for GET request types supported by the REST server.
@ GET_METRICS_INFO_SUCCESS
NvDsServerAnalyticsStatus
std::function< void(NvDsServerConvInfo *conv_info, void *ctx) > conv_cb
@ SKIP_FRAMES_UPDATE_FAIL
NvDsServerTextEmbeddingPropFlag text_embedding_flag
NvDsServerEncStatus status
NvDsServerNvTrackerPropFlag nvTracker_flag
std::function< void(NvDsServerInferServerInfo *inferserver_info, void *ctx) > inferserver_cb
@ SKIP_FRAMES_UPDATE_SUCCESS
NvDsServerInferServerStatus status
struct NvDsServerErrorInfo NvDsServerErrorInfo
NvDsServerDecPropFlag dec_flag
std::function< void(NvDsServerDecInfo *dec_info, void *ctx) > dec_cb
std::string value_camera_url
@ FLIP_METHOD_UPDATE_SUCCESS
@ INFERSERVER_INTERVAL_UPDATE_FAIL
struct NvDsServerInferInfo NvDsServerInferInfo
gboolean low_latency_mode
std::string analytics_log
NvDsServerInferStatus status
NvDsServerAnalyticsPropFlag analytics_flag
@ INTERPOLATION_METHOD_UPDATE_FAIL
struct NvDsServerCallbacks NvDsServerCallbacks
struct NvDsServerAnalyticsInfo NvDsServerAnalyticsInfo
std::function< void(NvDsServerTextEmbeddingInfo *text_embedding_info, void *ctx) > text_embedding_cb
@ LOW_LATENCY_MODE_UPDATE_FAIL
struct NvDsServerAppInstanceInfo NvDsServerAppInstanceInfo
NvDsServerTextEmbeddingStatus
NvDsServerGetRequestStatus status
std::string metadata_framerate
struct NvDsServerResponseInfo NvDsServerResponseInfo
@ IFRAME_INTERVAL_UPDATE_FAIL
struct NvDsGetRequestInfo NvDsServerGetRequestInfo
@ FORCE_INTRA_UPDATE_FAIL
NvDsRestServer * nvds_rest_server_start(NvDsServerConfig *server_config, NvDsServerCallbacks *server_cb, void *custom_ctx)
std::function< void(NvDsServerStreamInfo *stream_info, void *ctx) > stream_cb
std::function< void(NvDsServerRoiInfo *roi_info, void *ctx) > roi_cb
NvDsServerRoiStatus status
@ FLIP_METHOD_UPDATE_FAIL
struct NvDsServerNvTrackerInfo NvDsServerNvTrackerInfo
@ PROCESS_MODE_UPDATE_SUCCESS
struct NvDsServerInferServerInfo NvDsServerInferServerInfo
std::string config_file_path
std::string get_request_log
struct NvDsServerRoiInfo NvDsServerRoiInfo
@ RELOAD_CONFIG_UPDATE_FAIL
NvDsServerAppInstanceStatus status
std::function< void(NvDsServerGetRequestInfo *get_request_info, void *ctx) > get_request_cb
NvDsServerDecStatus status
struct NvDsServerConfig NvDsServerConfig
@ FORCE_IDR_UPDATE_SUCCESS
std::string nvTracker_log
@ INTERPOLATION_METHOD_UPDATE_SUCCESS
@ MAX_LATENCY_UPDATE_FAIL
guint interpolation_method
@ INFERSERVER_INTERVAL_UPDATE_SUCCESS
@ DROP_FRAME_INTERVAL_UPDATE_FAIL
@ RELOAD_CONFIG_UPDATE_SUCCESS
@ StatusInternalServerError
@ PROCESS_MODE_UPDATE_FAIL
@ NVTRACKER_CONFIG_UPDATE_SUCCESS
std::string metadata_codec
NvDsServerOsdPropFlag osd_flag
NvDsServerEncPropFlag enc_flag
@ GET_LIVE_STREAM_INFO_SUCCESS
gint batched_push_timeout
struct NvDsServerDecInfo NvDsServerDecInfo
NvDsServerAnalyticsStatus status
@ StatusUnsupportedMediaType
struct NvDsServerOsdInfo NvDsServerOsdInfo
std::function< void(NvDsServerAnalyticsInfo *analytics_info, void *ctx) > analytics_cb
@ StatusPreconditionFailed
@ NVTRACKER_CONFIG_UPDATE_FAIL
NvDsServerTextEmbeddingStatus status
@ MAX_LATENCY_UPDATE_SUCCESS
std::string value_camera_id
@ GET_STARTUP_INFO_SUCCESS
@ GET_LIVE_STREAM_INFO_FAIL
@ IFRAME_INTERVAL_UPDATE_SUCCESS
NvDsServerMuxStatus status
@ SRC_CROP_UPDATE_SUCCESS
@ INFER_INTERVAL_UPDATE_FAIL
std::string text_embedding_log
NvDsServerConvPropFlag conv_flag
NvDsServerStreamStatus status
std::string headers_created_at
std::function< void(NvDsServerInferInfo *infer_info, void *ctx) > infer_cb
struct NvDsServerEncInfo NvDsServerEncInfo
std::string inferserver_log
struct NvDsServerConvInfo NvDsServerConvInfo
NvDsServerAppInstanceFlag appinstance_flag
std::function< void(NvDsServerMuxInfo *mux_info, void *ctx) > mux_cb
