8.0 Release
9.0/sources/includes/gst-nvdscommonconfig.h File Reference
Data Structures
struct  _NvDsSensorInfo
struct  _NvDsRtspAttemptsInfo
struct  _GstDsNvUriSrcConfig
struct  GstDsNvStreammuxConfig
Typedefs
typedef struct _NvDsSensorInfo NvDsSensorInfo
typedef struct _NvDsRtspAttemptsInfo NvDsRtspAttemptsInfo
typedef struct _GstDsNvUriSrcConfig GstDsNvUriSrcConfig
Enumerations
enum  NvDsUriSrcBinType {
  SOURCE_TYPE_AUTO,
  SOURCE_TYPE_URI,
  SOURCE_TYPE_RTSP,
  SOURCE_TYPE_AUTO,
  SOURCE_TYPE_URI,
  SOURCE_TYPE_RTSP,
  SOURCE_TYPE_AUTO,
  SOURCE_TYPE_URI,
  SOURCE_TYPE_RTSP,
  SOURCE_TYPE_AUTO,
  SOURCE_TYPE_URI,
  SOURCE_TYPE_RTSP
enum  NvDsUriSrcBinDecSkipFrame {
  DEC_SKIP_FRAMES_TYPE_NONE,
  DEC_SKIP_FRAMES_TYPE_NONREF,
  DEC_SKIP_FRAMES_TYPE_KEY_FRAME_ONLY,
enum  NvDsUriSrcBinRtpProtocol {
  RTP_PROTOCOL_UNKNOWN = 0,
  RTP_PROTOCOL_UDP = 1,
  RTP_PROTOCOL_UDP_MCAST = 2,
  RTP_PROTOCOL_TCP = 4,
  RTP_PROTOCOL_UDP_UDPMCAST_TCP = 7,
  RTP_PROTOCOL_HTTP = 10,
  RTP_PROTOCOL_TLS = 20,
enum  NvDsUriSrcBinLeaky {
  LEAKY_NONE,
  LEAKY_UPSTREAM,
  LEAKY_DOWNSTREAM,
  LEAKY_NONE,
  LEAKY_UPSTREAM,
  LEAKY_DOWNSTREAM,
  LEAKY_NONE,
  LEAKY_UPSTREAM,
  LEAKY_DOWNSTREAM,
  LEAKY_NONE,
  LEAKY_UPSTREAM,
  LEAKY_DOWNSTREAM
enum  NvDsUriSrcBinBufferMode {
  BUFFER_MODE_UNKNOWN = 0,
  BUFFER_MODE_SLAVE = 1,
  BUFFER_MODE_BUFFER = 2,
  BUFFER_MODE_AUTO = 3,
  BUFFER_MODE_SYNCED = 4,
enum  NvDsUriSrcBinSRType {
  SMART_REC_DISABLE,
  SMART_REC_CLOUD,
  SMART_REC_MULTI,
  SMART_REC_DISABLE,
  SMART_REC_CLOUD,
  SMART_REC_MULTI,
  SMART_REC_DISABLE,
  SMART_REC_CLOUD,
  SMART_REC_MULTI,
  SMART_REC_DISABLE,
  SMART_REC_CLOUD,
  SMART_REC_MULTI
enum  NvDsUriSrcBinSRMode {
  SMART_REC_AUDIO_VIDEO,
  SMART_REC_VIDEO_ONLY,
  SMART_REC_AUDIO_ONLY,
enum  NvDsUriSrcBinSRCont {
  SMART_REC_MP4,
  SMART_REC_MKV,
  SMART_REC_MP4,
  SMART_REC_MKV,
  SMART_REC_MP4,
  SMART_REC_MKV,
  SMART_REC_MP4,
  SMART_REC_MKV
Typedef Documentation
◆ GstDsNvUriSrcConfig
◆ NvDsRtspAttemptsInfo
◆ NvDsSensorInfo
◆ NvDsUriSrcBinBufferMode
Enumerator
BUFFER_MODE_UNKNOWN
BUFFER_MODE_SLAVE
BUFFER_MODE_BUFFER
BUFFER_MODE_AUTO
BUFFER_MODE_SYNCED
BUFFER_MODE_UNKNOWN
BUFFER_MODE_SLAVE
BUFFER_MODE_BUFFER
BUFFER_MODE_AUTO
BUFFER_MODE_SYNCED
BUFFER_MODE_UNKNOWN
BUFFER_MODE_SLAVE
BUFFER_MODE_BUFFER
BUFFER_MODE_AUTO
BUFFER_MODE_SYNCED
BUFFER_MODE_UNKNOWN
BUFFER_MODE_SLAVE
BUFFER_MODE_BUFFER
BUFFER_MODE_AUTO
BUFFER_MODE_SYNCED
Definition at line 54 of file 9.0/sources/includes/gst-nvdscommonconfig.h.
◆ NvDsUriSrcBinDecSkipFrame
Enumerator
Definition at line 29 of file 9.0/sources/includes/gst-nvdscommonconfig.h.
◆ NvDsUriSrcBinLeaky
Enumerator
LEAKY_NONE
LEAKY_UPSTREAM
LEAKY_DOWNSTREAM
LEAKY_NONE
LEAKY_UPSTREAM
LEAKY_DOWNSTREAM
LEAKY_NONE
LEAKY_UPSTREAM
LEAKY_DOWNSTREAM
LEAKY_NONE
LEAKY_UPSTREAM
LEAKY_DOWNSTREAM
Definition at line 47 of file 9.0/sources/includes/gst-nvdscommonconfig.h.
◆ NvDsUriSrcBinRtpProtocol
Enumerator
RTP_PROTOCOL_UDP
RTP_PROTOCOL_TCP
RTP_PROTOCOL_HTTP
RTP_PROTOCOL_TLS
RTP_PROTOCOL_UDP
RTP_PROTOCOL_TCP
RTP_PROTOCOL_HTTP
RTP_PROTOCOL_TLS
RTP_PROTOCOL_UDP
RTP_PROTOCOL_TCP
RTP_PROTOCOL_HTTP
RTP_PROTOCOL_TLS
RTP_PROTOCOL_UDP
RTP_PROTOCOL_TCP
RTP_PROTOCOL_HTTP
RTP_PROTOCOL_TLS
Definition at line 36 of file 9.0/sources/includes/gst-nvdscommonconfig.h.
◆ NvDsUriSrcBinSRCont
Enumerator
SMART_REC_MP4
SMART_REC_MKV
SMART_REC_MP4
SMART_REC_MKV
SMART_REC_MP4
SMART_REC_MKV
SMART_REC_MP4
SMART_REC_MKV
Definition at line 77 of file 9.0/sources/includes/gst-nvdscommonconfig.h.
◆ NvDsUriSrcBinSRMode
Enumerator
Definition at line 70 of file 9.0/sources/includes/gst-nvdscommonconfig.h.
◆ NvDsUriSrcBinSRType
Enumerator
SMART_REC_DISABLE
SMART_REC_CLOUD
SMART_REC_MULTI
SMART_REC_DISABLE
SMART_REC_CLOUD
SMART_REC_MULTI
SMART_REC_DISABLE
SMART_REC_CLOUD
SMART_REC_MULTI
SMART_REC_DISABLE
SMART_REC_CLOUD
SMART_REC_MULTI
Definition at line 63 of file 9.0/sources/includes/gst-nvdscommonconfig.h.
◆ NvDsUriSrcBinType
Enumerator
SOURCE_TYPE_AUTO
SOURCE_TYPE_URI
SOURCE_TYPE_RTSP
SOURCE_TYPE_AUTO
SOURCE_TYPE_URI
SOURCE_TYPE_RTSP
SOURCE_TYPE_AUTO
SOURCE_TYPE_URI
SOURCE_TYPE_RTSP
SOURCE_TYPE_AUTO
SOURCE_TYPE_URI
SOURCE_TYPE_RTSP
Definition at line 22 of file 9.0/sources/includes/gst-nvdscommonconfig.h.
