9.0/sources/libs/nvdsinferserver/infer_batch_buffer.h File Reference
Header file of batch buffer related class declarations.
Definition in file 9.0/sources/libs/nvdsinferserver/infer_batch_buffer.h.
Data Structures
class  nvdsinferserver::BaseBatchBuffer
 The base class for batch buffers. More...
class  nvdsinferserver::BaseBatchArray
 The base class for array of batch buffers. More...
class  nvdsinferserver::RefBatchBuffer
 A batch buffer with allocated memory. More...
class  nvdsinferserver::WrapCBatchBuffer
Namespaces
 nvdsinferserver
Functions
void nvdsinferserver::normalizeDims (InferDims &dims)
