nvdsinferserver::RefBatchBuffer Class Reference
A batch buffer with allocated memory.
Definition at line 205 of file sources/libs/nvdsinferserver/infer_batch_buffer.h.
Inheritance diagram for nvdsinferserver::RefBatchBuffer:
Collaboration diagram for nvdsinferserver::RefBatchBuffer:
Public Member Functions
 RefBatchBuffer (void *bufBase, size_t offset, size_t bufBytes, const InferBufferDescription &desc, uint32_t batchSize)
void * getBufPtr (uint32_t batchIdx) const override
uint64_t getTotalBytes () const final
void * basePtr ()
size_t getBufOffset (uint32_t batchIdx) const override
 Get the offset from start of the memory allocation to the buffer pointer. More...
void * basePtr ()
const InferBufferDescriptiongetBufDesc () const final
uint32_t getBatchSize () const final
void setBufDesc (const InferBufferDescription &desc)
InferBufferDescriptionmutableBufDesc ()
virtual void setBatchSize (uint32_t size)
const SharedCuEventcuEvent () const
void setCuEvent (SharedCuEvent e)
void setSyncObj (NvBufSurfTransformSyncObj_t SyncObj)
NvBufSurfTransformSyncObj_tgetSyncObj ()
void waitForSyncObj ()
void attach (SharedBatchBuf buf)
void detach ()
void detach ()
bool hasAttachedBufs () const
const std::vector< SharedBatchBuf > & attachedBufs () const
std::vector< SharedBatchBuf > & mutableAttachedBufs ()
bool hasAttachLoop () const
void setBufId (uint64_t id)
uint64_t bufId () const
◆ RefBatchBuffer() [1/2]
nvdsinferserver::RefBatchBuffer::RefBatchBuffer ( void *  bufBase,
size_t  offset,
size_t  bufBytes,
const InferBufferDescription desc,
uint32_t  batchSize
inline
◆ RefBatchBuffer() [2/2]
size_t  offset,
size_t  bufBytes,
uint32_t  batchSize
inline
Member Function Documentation
◆ attach() [1/2]
void nvdsinferserver::BaseBatchBuffer::attach ( SharedBatchBuf  buf)
inlineinherited
◆ attach() [2/2]
inlineinherited
◆ attachedBufs() [1/2]
const std::vector<SharedBatchBuf>& nvdsinferserver::BaseBatchBuffer::attachedBufs ( ) const
inlineinherited
◆ attachedBufs() [2/2]
inlineinherited
◆ basePtr() [1/2]
void* nvdsinferserver::RefBatchBuffer::basePtr ( )
inline
◆ basePtr() [2/2]
inline
◆ bufId() [1/2]
uint64_t nvdsinferserver::BaseBatchBuffer::bufId ( ) const
inlineinherited
◆ bufId() [2/2]
inlineinherited
◆ cuEvent() [1/2]
const SharedCuEvent& nvdsinferserver::BaseBatchBuffer::cuEvent ( ) const
inlineinherited
◆ cuEvent() [2/2]
inlineinherited
◆ detach() [1/2]
void nvdsinferserver::BaseBatchBuffer::detach ( )
inlineinherited
◆ detach() [2/2]
inlineinherited
◆ getBatchSize() [1/2]
uint32_t nvdsinferserver::BaseBatchBuffer::getBatchSize ( ) const
inlinefinalvirtualinherited
◆ getBatchSize() [2/2]
◆ getBufDesc() [1/2]
const InferBufferDescription& nvdsinferserver::BaseBatchBuffer::getBufDesc ( ) const
◆ getBufDesc() [2/2]
◆ getBufOffset() [1/2]
size_t nvdsinferserver::RefBatchBuffer::getBufOffset ( uint32_t  batchIdx) const
inlineoverridevirtual
Needed for sharing CUDA memory with Triton server.
Reimplemented from nvdsinferserver::BaseBatchBuffer.
Definition at line 232 of file sources/libs/nvdsinferserver/infer_batch_buffer.h.
References nvdsinferserver::InferBufferDescription::dataType, nvdsinferserver::InferBufferDescription::dims, nvdsinferserver::InferBufferDescription::elementSize, and nvdsinferserver::InferDims::numElements.
◆ getBufOffset() [2/2]
Definition at line 232 of file 9.0/sources/libs/nvdsinferserver/infer_batch_buffer.h.
◆ getBufPtr() [1/2]
◆ getBufPtr() [2/2]
◆ getSyncObj() [1/2]
NvBufSurfTransformSyncObj_t& nvdsinferserver::BaseBatchBuffer::getSyncObj ( )
inlineinherited
◆ getSyncObj() [2/2]
inlineinherited
◆ getTotalBytes() [1/2]
uint64_t nvdsinferserver::RefBatchBuffer::getTotalBytes ( ) const
inlinefinalvirtual
◆ getTotalBytes() [2/2]
inlinefinalvirtual
◆ hasAttachedBufs() [1/2]
bool nvdsinferserver::BaseBatchBuffer::hasAttachedBufs ( ) const
inlineinherited
◆ hasAttachedBufs() [2/2]
inlineinherited
◆ hasAttachLoop() [1/2]
bool nvdsinferserver::BaseBatchBuffer::hasAttachLoop ( ) const
inlineinherited
◆ hasAttachLoop() [2/2]
inlineinherited
◆ mutableAttachedBufs() [1/2]
std::vector<SharedBatchBuf>& nvdsinferserver::BaseBatchBuffer::mutableAttachedBufs ( )
inlineinherited
◆ mutableAttachedBufs() [2/2]
inlineinherited
◆ mutableBufDesc() [1/2]
InferBufferDescription& nvdsinferserver::BaseBatchBuffer::mutableBufDesc ( )
inlineinherited
◆ mutableBufDesc() [2/2]
inlineinherited
◆ setBatchSize() [1/2]
virtual void nvdsinferserver::BaseBatchBuffer::setBatchSize ( uint32_t  size)
inlinevirtualinherited
◆ setBatchSize() [2/2]
◆ setBufDesc() [1/2]
void nvdsinferserver::BaseBatchBuffer::setBufDesc ( const InferBufferDescription desc)
inlineinherited
◆ setBufDesc() [2/2]
◆ setBufId() [1/2]
void nvdsinferserver::BaseBatchBuffer::setBufId ( uint64_t  id)
inlineinherited
◆ setBufId() [2/2]
inlineinherited
◆ setCuEvent() [1/2]
void nvdsinferserver::BaseBatchBuffer::setCuEvent ( SharedCuEvent  e)
inlineinherited
◆ setCuEvent() [2/2]
inlineinherited
◆ setSyncObj() [1/2]
void nvdsinferserver::BaseBatchBuffer::setSyncObj ( NvBufSurfTransformSyncObj_t  SyncObj)
inlineinherited
◆ setSyncObj() [2/2]
inlineinherited
◆ waitForSyncObj() [1/2]
void nvdsinferserver::BaseBatchBuffer::waitForSyncObj ( )
inlineinherited
◆ waitForSyncObj() [2/2]
inlineinherited
