nvdsinferserver Namespace Reference
Namespaces
 triton
Data Structures
class  BaseBackend
 Base class of inference backend processing. More...
class  BaseBatchArray
 The base class for array of batch buffers. More...
class  BaseBatchBuffer
 The base class for batch buffers. More...
class  BasePostprocessor
 Base post-processor class. More...
class  BasePreprocessor
 Base preprocessor class. More...
class  BatchSurfaceBuffer
class  BufOptions
class  ClassificationOutput
class  ClassifyPostprocessor
 Post processor class for classification output. More...
class  CpuMem
 Allocates and manages host memory. More...
class  CropSurfaceConverter
 Preprocessor for cropping, scaling and padding the inference input to required height, width. More...
class  CudaDeviceMem
 Allocates and manages CUDA device memory. More...
class  CudaEvent
 Wrapper class for CUDA events. More...
class  CudaHostMem
 Allocates and manages CUDA pinned memory. More...
class  CudaStream
 Wrapper class for CUDA streams. More...
class  CudaTensorBuf
 A batch buffer with CUDA memory allocation. More...
class  DetectionOutput
class  DetectPostprocessor
 Post processor class for detection output. More...
class  IBackend
class  IBatchArray
 Interface class for an array of batch buffers. More...
class  IBatchBuffer
 Interface class for a batch buffer. More...
class  IInferCustomProcessor
 Interface of Custom processor which is created and loaded at runtime through CreateCustomProcessorFunc. More...
class  ImageAlignBuffer
class  InferBaseContext
 The base class for handling the inference context. More...
struct  InferBatchDims
 Holds full dimensions (including batch size) for a layer. More...
struct  InferBufferDescription
 Holds the information about a inference buffer. More...
class  InferCudaContext
 Class for inference context CUDA processing. More...
struct  InferDims
 Holds the information about the dimensions of a neural network layer. More...
class  InferExtraProcessor
 : Extra processing pre/post inference. More...
class  InferGrpcClient
 Wrapper class for the gRPC client of the Triton Inference Server, interfaces with the Triton client library. More...
class  InferGrpcContext
 Inference context class accessing Triton Inference Server in gRPC mode. More...
class  InferSimpleContext
class  InferTrtISContext
 Inference context accessing Triton Inference Server in C-API mode. More...
class  IOptions
class  IPostprocessor
 Post-processor interface class. More...
class  IPreprocessor
 Preprocessor interface class. More...
struct  LayerDescription
 Stores the information of a layer in the inference model. More...
class  LstmController
class  NetworkPreprocessor
 Preprocessor for scaling and normalization of the input and conversion to network media format. More...
class  OtherPostprocessor
 Post processor class for tensor output for custom post processing. More...
class  Postprocessor
 A generic post processor class. More...
class  RefBatchBuffer
 A batch buffer with allocated memory. More...
class  SegmentationOutput
class  SegmentPostprocessor
 Post processor class for segmentation output. More...
class  StreamManager
class  SurfaceBuffer
class  SysMem
 Base class for managing memory allocation. More...
class  ThreadCudaPostprocessor
 A CUDA post processor thread queue template class. More...
class  ThreadHostPostprocessor
 A host post processor thread queue template class. More...
class  ThreadPreprocessor
 Preprocessor thread queue class template. More...
class  TritonGrpcBackend
 Triton gRPC mode backend processing class. More...
class  TritonGrpcRequest
 Triton gRPC inference request class holding data associated with one inference request. More...
class  TritonSimpleRuntime
class  TrtISBackend
 Triton backend processing class. More...
class  TrtIsClassifier
 Post processor class for Triton Classification option. More...
class  TrtISServer
 Wrapper class for creating Triton Inference Server instance. More...
class  TrtServerAllocator
 Wrapper class for Triton server output memory allocator. More...
class  TrtServerRequest
 Wrapper class for Triton inference request. More...
class  TrtServerResponse
 Wrapper class for Triton output parsing. More...
class  WrapCBatchBuffer
Typedefs
using SharedIBatchBuffer = std::shared_ptr< IBatchBuffer >
using SharedIBatchArray = std::shared_ptr< IBatchArray >
using SharedIOptions = std::shared_ptr< IOptions >
using SharedBufOptions = std::shared_ptr< BufOptions >
using UniqBackend = std::unique_ptr< BaseBackend >
using InferCompleted = std::function< void(NvDsInferStatus, SharedBatchArray)>
using TensorMapPool = MapBufferPool< std::string, UniqCudaTensorBuf >
using TensorMapPoolPtr = std::unique_ptr< TensorMapPool >
typedef std::map< std::string, std::string > Headers
using SharedGrpcRequest = std::shared_ptr< TritonGrpcRequest >
using TritonGrpcAsyncDone = std::function< void(NvDsInferStatus, SharedBatchArray)>
using LayerDescriptionList = std::vector< LayerDescription >
using SharedClassOutput = std::shared_ptr< ClassificationOutput >
using UniqSurfaceBuf = std::unique_ptr< SurfaceBuffer >
using SharedBatchSurface = std::shared_ptr< BatchSurfaceBuffer >
using SharedRequest = std::shared_ptr< TrtServerRequest >
using UniqResponse = std::unique_ptr< TrtServerResponse >
using SharedResponse = std::shared_ptr< TrtServerResponse >
using TritonInferAsyncDone = std::function< void(SharedRequest, UniqResponse)>
Enumerations
enum  InferTensorOrder : int {
  InferTensorOrder::kNone = 0,
  InferTensorOrder::kLinear = 1,
  InferTensorOrder::kNHWC = 2,
 The type of tensor order. More...
enum  InferMemType : int {
  InferMemType::kNone = 0,
  InferMemType::kGpuCuda = 1,
  InferMemType::kCpu = 2,
  InferMemType::kCpuCuda = 3,
  InferMemType::kNvSurface = 5,
  InferMemType::kNvSurfaceArray = 6,
 The memory types of inference buffers. More...
enum  InferDataType : int {
  InferDataType::kFp32 = FLOAT,
  InferDataType::kFp16 = HALF,
  InferDataType::kInt8 = INT8,
  InferDataType::kInt32 = INT32,
  InferDataType::kInt16 = 7,
  InferDataType::kUint8,
  InferDataType::kUint16,
  InferDataType::kUint32,
  InferDataType::kFp64,
  InferDataType::kInt64,
  InferDataType::kUint64,
  InferDataType::kString,
  InferDataType::kBool,
  InferDataType::kNone = -1,
 Datatype of the tensor buffer. More...
enum  InferPostprocessType : int {
  InferPostprocessType::kDetector = 0,
  InferPostprocessType::kClassifier = 1,
  InferPostprocessType::kSegmentation = 2,
  InferPostprocessType::kTrtIsClassifier = 3,
  InferPostprocessType::kOther = 100,
 Inference post processing types. More...
enum  InferMediaFormat : int {
  InferMediaFormat::kRGB = 0,
  InferMediaFormat::kBGR,
  InferMediaFormat::kGRAY,
  InferMediaFormat::kRGBA,
  InferMediaFormat::kBGRx,
  InferMediaFormat::kUnknown = -1,
 Image formats. More...
enum  OptionType : int {
  OptionType::oBool = 0,
  OptionType::oDouble,
  OptionType::oInt,
  OptionType::oUint,
  OptionType::oString,
  OptionType::oObject,
  OptionType::oArray,
  OptionType::oNone = -1,
  OptionType::oInt,
  OptionType::oUint,
  OptionType::oArray,
  OptionType::oInt,
  OptionType::oUint,
  OptionType::oArray,
  OptionType::oInt,
  OptionType::oUint,
  OptionType::oArray,
Functions
template<>
void BufOptions::D::BasicValue::setV< std::string > (const std::string &v, OptionType t)
void normalizeDims (InferDims &dims)
UniqCudaTensorBuf createTensorBuf (const InferDims &dims, InferDataType dt, int batchSize, const std::string &name, InferMemType mt, int devId, bool initCuEvent)
 Create a tensor buffer of the specified memory type, dimensions on the given device. More...
UniqCudaTensorBuf createGpuTensorBuf (const InferDims &dims, InferDataType dt, int batchSize, const std::string &name="", int devId=0, bool initCuEvent=false)
 Create a CUDA device memory tensor buffer of specified dimensions on the given device. More...
UniqCudaTensorBuf createCpuTensorBuf (const InferDims &dims, InferDataType dt, int batchSize, const std::string &name="", int devId=0, bool initCuEvent=false)
 Create a CUDA pinned memory tensor buffer of specified dimensions on the given device. More...
NvDsInferStatus syncAllCudaEvents (const SharedBatchArray &bufList)
 Synchronize on all events associated with the batch buffer array. More...
InferDataType dataTypeFromDsProto (ic::TensorDataType dt)
InferTensorOrder tensorOrderFromDsProto (ic::TensorOrder o)
InferMediaFormat mediaFormatFromDsProto (ic::MediaFormat f)
InferMemType memTypeFromDsProto (ic::MemoryType t)
NvBufSurfTransform_Compute computeHWFromDsProto (ic::FrameScalingHW h)
NvBufSurfTransform_Inter scalingFilterFromDsProto (uint32_t filter)
bool validateProtoConfig (ic::InferenceConfig &c, const std::string &path)
bool compareModelRepo (const ic::TritonModelRepo &repoA, const ic::TritonModelRepo &repoB)
bool hasTriton (const ic::BackendParams &params)
const ic::TritonParams & getTritonParam (const ic::BackendParams &params)
ic::TritonParams * mutableTriton (ic::BackendParams &params)
SharedBufPool< UniqSurfaceBufcreateSurfaceBufPool (int width, int height, InferMediaFormat color, int batchSize, int gpuId, int poolSize)
InferDataType DataTypeFromTriton (TRITONSERVER_DataType type)
 Maps the TRITONSERVER_DataType to the InferDataType. More...
TRITONSERVER_DataType DataTypeToTriton (InferDataType type)
 Maps the InferDataType to TRITONSERVER_DataType. More...
InferDataType DataTypeFromTritonPb (ni::DataType type)
 Maps the data type from Triton model configuration proto definition to InferDataType. More...
InferTensorOrder TensorOrderFromTritonPb (ni::ModelInput::Format order)
 Maps the tensor order from Triton model configuration proto definition to the InferTensorOrder type. More...
InferTensorOrder TensorOrderFromTritonMeta (const std::string &format)
 Maps the tensor order from Triton metadata string to the InferTensorOrder type. More...
TRITONSERVER_MemoryType MemTypeToTriton (InferMemType type)
 Maps the InferMemType to the TRITONSERVER_MemoryType. More...
InferMemType MemTypeFromTriton (TRITONSERVER_MemoryType type)
 Maps the TRITONSERVER_MemoryType to the InferMemType. More...
template<typename VecDims >
InferDims DimsFromTriton (const VecDims &shape)
 Converts the input shape vector from Triton to InferDims type. More...
const char * TritonControlModeToStr (int32_t mode)
 Returns a string describing the TRITONSERVER_ModelControlMode: none, explicit or poll. More...
Typedef Documentation
◆ Headers
typedef std::map< std::string, std::string > nvdsinferserver::Headers
◆ InferCompleted
◆ InferCustomProcessorPtr
◆ LayerDescriptionList
◆ SharedBatchArray
◆ SharedBatchBuf
Common buffer interfaces (internal).
Definition at line 71 of file sources/libs/nvdsinferserver/infer_common.h.
◆ SharedBatchSurface
◆ SharedBufOptions
◆ SharedClassOutput
◆ SharedCudaTensorBuf
◆ SharedCuEvent
typedef std::shared_ptr< CudaEvent > nvdsinferserver::SharedCuEvent
Definition at line 86 of file sources/libs/nvdsinferserver/infer_common.h.
◆ SharedCuStream
typedef std::shared_ptr< CudaStream > nvdsinferserver::SharedCuStream
Cuda based pointers.
Definition at line 84 of file sources/libs/nvdsinferserver/infer_common.h.
◆ SharedDllHandle
typedef std::shared_ptr< DlLibHandle > nvdsinferserver::SharedDllHandle
Definition at line 111 of file sources/libs/nvdsinferserver/infer_common.h.
◆ SharedGrpcRequest
◆ SharedIBatchArray
◆ SharedIBatchBuffer
◆ SharedIOptions
◆ SharedOptions
typedef std::shared_ptr< IOptions > nvdsinferserver::SharedOptions
Definition at line 73 of file sources/libs/nvdsinferserver/infer_common.h.
◆ SharedRefBatchBuf
◆ SharedRequest
◆ SharedResponse
◆ SharedSysMem
typedef std::shared_ptr< SysMem > nvdsinferserver::SharedSysMem
Definition at line 88 of file sources/libs/nvdsinferserver/infer_common.h.
◆ ShrTritonAllocator
◆ ShrTritonT
template<typename T >
using nvdsinferserver::ShrTritonT = typedef std::shared_ptr<T>
Definition at line 117 of file sources/libs/nvdsinferserver/infer_common.h.
◆ TensorMapPool
typedef MapBufferPool< std::string, UniqCudaTensorBuf > nvdsinferserver::TensorMapPool
◆ TensorMapPoolPtr
◆ TritonGrpcAsyncDone
◆ TritonInferAsyncDone
◆ TrtServerPtr
typedef std::shared_ptr< TrtISServer > nvdsinferserver::TrtServerPtr
Definition at line 121 of file sources/libs/nvdsinferserver/infer_common.h.
◆ UniqBackend
◆ UniqBatchArray
typedef std::unique_ptr< BaseBatchArray > nvdsinferserver::UniqBatchArray
Definition at line 76 of file sources/libs/nvdsinferserver/infer_common.h.
◆ UniqBatchBuf
typedef std::unique_ptr< BaseBatchBuffer > nvdsinferserver::UniqBatchBuf
Definition at line 72 of file sources/libs/nvdsinferserver/infer_common.h.
◆ UniqCudaTensorBuf
◆ UniqCuEvent
typedef std::unique_ptr< CudaEvent > nvdsinferserver::UniqCuEvent
Definition at line 87 of file sources/libs/nvdsinferserver/infer_common.h.
◆ UniqCuStream
typedef std::unique_ptr< CudaStream > nvdsinferserver::UniqCuStream
Definition at line 85 of file sources/libs/nvdsinferserver/infer_common.h.
◆ UniqInferExtraProcessor
◆ UniqLock
typedef std::unique_lock< std::mutex > nvdsinferserver::UniqLock
Miscellaneous declarations.
Definition at line 108 of file sources/libs/nvdsinferserver/infer_common.h.
◆ UniqLstmController
◆ UniqPostprocessor
Processor interfaces.
Definition at line 98 of file sources/libs/nvdsinferserver/infer_common.h.
◆ UniqPreprocessor
◆ UniqResponse
◆ UniqStreamManager
◆ UniqSurfaceBuf
◆ UniqSysMem
typedef std::unique_ptr< SysMem > nvdsinferserver::UniqSysMem
Definition at line 89 of file sources/libs/nvdsinferserver/infer_common.h.
◆ UniqTritonAllocator
◆ UniqTritonT
using nvdsinferserver::UniqTritonT = typedef std::unique_ptr<T, std::function<void(T*)> >
Definition at line 114 of file sources/libs/nvdsinferserver/infer_common.h.
◆ UniqTrtISBackend
◆ WeakTritonAllocator
◆ InferDataType [1/2]
enum nvdsinferserver::InferDataType : int
strong
Enumerator
kFp32
kFp16
kInt8
kInt32
kInt16
kUint8
kUint16
kUint32
kFp64
kInt64
kUint64
kString
kBool
kNone
kFp32
kFp16
kInt8
kInt32
kInt16
kUint8
kUint16
kUint32
kFp64
kInt64
kUint64
kString
kBool
kNone
Definition at line 83 of file sources/includes/nvdsinferserver/infer_datatypes.h.
◆ InferDataType [2/2]
strong
Enumerator
kFp32
kFp16
kInt8
kInt32
kInt16
kUint8
kUint16
kUint32
kFp64
kInt64
kUint64
kString
kBool
kNone
kFp32
kFp16
kInt8
kInt32
kInt16
kUint8
kUint16
kUint32
kFp64
kInt64
kUint64
kString
kBool
kNone
Definition at line 83 of file 9.0/sources/includes/nvdsinferserver/infer_datatypes.h.
◆ InferMediaFormat [1/2]
Image formats.
Enumerator
kRGB
24-bit interleaved R-G-B
kBGR
24-bit interleaved B-G-R
kGRAY
8-bit Luma
kRGBA
32-bit interleaved R-G-B-A
kBGRx
32-bit interleaved B-G-R-x
kUnknown
kRGB
kBGR
kGRAY
8-bit Luma
kRGBA
kBGRx
kUnknown
Definition at line 129 of file sources/includes/nvdsinferserver/infer_datatypes.h.
◆ InferMediaFormat [2/2]
Image formats.
Enumerator
kRGB
kBGR
kGRAY
8-bit Luma
kRGBA
kBGRx
kUnknown
kRGB
kBGR
kGRAY
8-bit Luma
kRGBA
kBGRx
kUnknown
Definition at line 129 of file 9.0/sources/includes/nvdsinferserver/infer_datatypes.h.
◆ InferMemType [1/2]
enum nvdsinferserver::InferMemType : int
strong
Enumerator
kNone
kGpuCuda
GPU CUDA memory.
kCpu
Host (CPU) memory.
kCpuCuda
CUDA pinned memory.
kNvSurface
NVRM surface memory.
kNvSurfaceArray
NVRM surface array memory.
kNone
kGpuCuda
GPU CUDA memory.
kCpu
Host (CPU) memory.
kCpuCuda
CUDA pinned memory.
kNvSurface
kNvSurfaceArray
Definition at line 56 of file 9.0/sources/includes/nvdsinferserver/infer_datatypes.h.
◆ InferMemType [2/2]
strong
Enumerator
kNone
kGpuCuda
GPU CUDA memory.
kCpu
Host (CPU) memory.
kCpuCuda
CUDA pinned memory.
kNvSurface
kNvSurfaceArray
kNone
kGpuCuda
GPU CUDA memory.
kCpu
Host (CPU) memory.
kCpuCuda
CUDA pinned memory.
kNvSurface
kNvSurfaceArray
Definition at line 56 of file sources/includes/nvdsinferserver/infer_datatypes.h.
◆ InferPostprocessType [1/2]
Enumerator
kDetector
Post processing for object detection.
kClassifier
Post processing for object classification.
kSegmentation
Post processing for image segmentation.
kTrtIsClassifier
Post processing using Triton Classifier.
kOther
Custom post processing.
kDetector
kClassifier
kSegmentation
kTrtIsClassifier
kOther
Definition at line 103 of file 9.0/sources/includes/nvdsinferserver/infer_datatypes.h.
◆ InferPostprocessType [2/2]
Enumerator
kDetector
kClassifier
kSegmentation
kTrtIsClassifier
kOther
kDetector
kClassifier
kSegmentation
kTrtIsClassifier
kOther
Definition at line 103 of file sources/includes/nvdsinferserver/infer_datatypes.h.
◆ InferTensorOrder [1/2]
Enumerator
kNone
kLinear
NCHW (batch-channels-height-width) tensor order.
kNHWC
NHWC (batch-height-width-channels) tensor order.
kNone
kLinear
kNHWC
Definition at line 41 of file sources/includes/nvdsinferserver/infer_datatypes.h.
◆ InferTensorOrder [2/2]
Enumerator
kNone
kLinear
kNHWC
kNone
kLinear
kNHWC
Definition at line 41 of file 9.0/sources/includes/nvdsinferserver/infer_datatypes.h.
◆ OptionType [1/2]
enum nvdsinferserver::OptionType : int
strong
Enumerator
oBool
oDouble
oInt
oUint
oString
oObject
oArray
oNone
oBool
oDouble
oInt
oUint
oString
oObject
oArray
oNone
Definition at line 28 of file sources/includes/nvdsinferserver/infer_ioptions.h.
◆ OptionType [2/2]
strong
Enumerator
oBool
oDouble
oInt
oUint
oString
oObject
oArray
oNone
oBool
oDouble
oInt
oUint
oString
oObject
oArray
oNone
Definition at line 28 of file 9.0/sources/includes/nvdsinferserver/infer_ioptions.h.
Function Documentation
◆ BufOptions::D::BasicValue::setV< std::string >()
template<>
void nvdsinferserver::BufOptions::D::BasicValue::setV< std::string > ( const std::string &  v,
OptionType  t
inline
Definition at line 183 of file sources/includes/nvdsinferserver/infer_options.h.
References oString.
◆ compareModelRepo()
bool nvdsinferserver::compareModelRepo ( const ic::TritonModelRepo &  repoA,
const ic::TritonModelRepo &  repoB
◆ computeHWFromDsProto()
NvBufSurfTransform_Compute nvdsinferserver::computeHWFromDsProto ( ic::FrameScalingHW  h)
◆ createCpuTensorBuf()
UniqCudaTensorBuf nvdsinferserver::createCpuTensorBuf ( const InferDims dims,
InferDataType  dt,
int  batchSize,
const std::string &  name = "",
int  devId = 0,
bool  initCuEvent = false
Parameters
[in]dimsDimensions of the tensor.
[in]dtDatatype.
[in]batchSizeBatch size.
[in]nameName of the buffer.
[in]devIdDevice ID for the memory allocation.
[in]initCuEventFlag to create an associated CUDA event.
Returns
Pointer to the newly created tensor buffer, null if the buffer could not be created.
◆ createGpuTensorBuf()
UniqCudaTensorBuf nvdsinferserver::createGpuTensorBuf ( const InferDims dims,
InferDataType  dt,
int  batchSize,
int  devId = 0,
Parameters
[in]dtDatatype.
Returns
◆ createSurfaceBufPool()
SharedBufPool< UniqSurfaceBuf > nvdsinferserver::createSurfaceBufPool ( int  width,
int  height,
int  batchSize,
int  gpuId,
int  poolSize
◆ createTensorBuf()
UniqCudaTensorBuf nvdsinferserver::createTensorBuf ( const InferDims dims,
InferDataType  dt,
int  batchSize,
const std::string &  name,
InferMemType  mt,
int  devId,
bool  initCuEvent
Parameters
[in]dtDatatype.
[in]mtMemory type.
Returns
◆ dataTypeFromDsProto()
InferDataType nvdsinferserver::dataTypeFromDsProto ( ic::TensorDataType  dt)
◆ DataTypeFromTriton()
InferDataType nvdsinferserver::DataTypeFromTriton ( TRITONSERVER_DataType  type)
Parameters
typeTRITONSERVER_DataType
Returns
InferDataType corresponding to the input type.
◆ DataTypeFromTritonPb()
InferDataType nvdsinferserver::DataTypeFromTritonPb ( ni::DataType  type)
Parameters
typeThe protobuf datatype.
Returns
InferDataType corresponding to the protobuf type.
◆ DataTypeToTriton()
TRITONSERVER_DataType nvdsinferserver::DataTypeToTriton ( InferDataType  type)
Parameters
typeInferDataType
Returns
TRITONSERVER_DataType corresponding to the input type.
◆ DimsFromTriton()
InferDims nvdsinferserver::DimsFromTriton ( const VecDims &  shape)
This functions provides a InferDims structure created based on the input dimensions vector. Any negative dimensions are mapped to -1. The numElements value is updated if there is no dynamic size dimension.
Template Parameters
VecDimsInput dimensions vector type.
Parameters
shapeInput dimensions vector.
Returns
The InferDims structure object created based on the input.
Definition at line 131 of file sources/libs/nvdsinferserver/infer_trtis_utils.h.
References nvdsinfer::hasWildcard(), normalizeDims(), and NVDSINFER_MAX_DIMS.
◆ getTritonParam()
const ic::TritonParams & nvdsinferserver::getTritonParam ( const ic::BackendParams &  params)
inline
◆ hasTriton()
bool nvdsinferserver::hasTriton ( const ic::BackendParams &  params)
inline
◆ mediaFormatFromDsProto()
InferMediaFormat nvdsinferserver::mediaFormatFromDsProto ( ic::MediaFormat  f)
◆ memTypeFromDsProto()
InferMemType nvdsinferserver::memTypeFromDsProto ( ic::MemoryType  t)
◆ MemTypeFromTriton()
InferMemType nvdsinferserver::MemTypeFromTriton ( TRITONSERVER_MemoryType  type)
◆ MemTypeToTriton()
TRITONSERVER_MemoryType nvdsinferserver::MemTypeToTriton ( InferMemType  type)
◆ mutableTriton()
ic::TritonParams * nvdsinferserver::mutableTriton ( ic::BackendParams &  params)
inline
◆ normalizeDims()
void nvdsinferserver::normalizeDims ( InferDims dims)
◆ scalingFilterFromDsProto()
NvBufSurfTransform_Inter nvdsinferserver::scalingFilterFromDsProto ( uint32_t  filter)
◆ syncAllCudaEvents()
NvDsInferStatus nvdsinferserver::syncAllCudaEvents ( const SharedBatchArray bufList)
Parameters
[in]bufListArray of the batch buffers.
Returns
NVDSINFER_SUCCESS or NVDSINFER_CUDA_ERROR.
◆ tensorOrderFromDsProto()
InferTensorOrder nvdsinferserver::tensorOrderFromDsProto ( ic::TensorOrder  o)
◆ TensorOrderFromTritonMeta()
InferTensorOrder nvdsinferserver::TensorOrderFromTritonMeta ( const std::string &  format)
Parameters
[in]formatThe Triton metadata tensor order string.
Returns
InferTensorOrder type corresponding to the protobuf order.
◆ TensorOrderFromTritonPb()
InferTensorOrder nvdsinferserver::TensorOrderFromTritonPb ( ni::ModelInput::Format  order)
Parameters
[in]orderThe protobuf tensor order type.
Returns
◆ TritonControlModeToStr()
const char * nvdsinferserver::TritonControlModeToStr ( int32_t  mode)
◆ validateProtoConfig()
bool nvdsinferserver::validateProtoConfig ( ic::InferenceConfig &  c,
const std::string &  path
