8.0 Release
struct NvDsMsg2pCtx NvDsMsg2pCtx
NvDsMsg2pCtx is structure for library context.
NvDsPayload ** nvds_msg2p_generate_multiple(NvDsMsg2pCtx *ctx, NvDsEvent *events, guint size, guint *payloadCount)
This function will parse the NvDsEventMsgMeta and will generate multiple message payloads.
NvDsPayloadType payloadType
type of payload to be generated.
void nvds_msg2p_ctx_destroy(NvDsMsg2pCtx *ctx)
Release the resources allocated during context creation.
gpointer privData
private to component.
NvDsPayload * nvds_msg2p_generate(NvDsMsg2pCtx *ctx, NvDsEvent *events, guint size)
This function will parse the NvDsEventMsgMeta and will generate message payload.
NvDsMsg2pCtx * nvds_msg2p_ctx_create(const gchar *file, NvDsPayloadType type)
This function initializes the library with user defined options mentioned in the file and returns the...
void nvds_msg2p_release(NvDsMsg2pCtx *ctx, NvDsPayload *payload)
This function should be called to release memory allocated for payload.
