7.1 Release
Holds a person object's parameters.
gfloat visibility
Holds the object's visibility.
gchar * glasses
Holds a pointer to the type of glasses the person is wearing, if any.
Holds a product object's parameters.
guint age
Holds the person's age.
gchar * brand
Holds the product brand.
guint componentId
Holds the ID of the component (plugin) which attached the payload (optional).
guint embedding_length
Holds the length of embedding vector.
gchar * name
Holds a pointer to the person's name.
gchar * facialhair
Holds a pointer to the person's facial hair color.
Holds an embedding model's parameters.
gchar * cap
Holds a pointer to the type of cap the person is wearing, if any.
float left
Holds the position of rectangle's left side in pixels.
gchar * model
Holds a pointer to the model of the vehicle.
NvDsJoint * joints
Holds the joints of the person.
Holds a joint's position and confidence.
guint numFilled
Holds the number of points in the convex hull.
gchar * glasses
gchar * region
Holds a pointer to the region of the vehicle.
float z
Holds the joint z position in pixels.
gchar * cap
gchar * eyecolor
Holds a pointer to the person's eye color.
GList * mask
Holds a list of polygons for person mask.
Holds an object's signature.
guint age
gchar * facialhair
Holds data for any user defined custom message to be attached to the payload message : custom message...
gchar * brand
gchar * hair
Holds a pointer to the person's hair color.
float height
Holds the rectangle's height in pixels.
gdouble lat
Holds the location's latitude.
gchar * type
Holds the product type.
Holds 2D convex hull metadata.
gchar * hair
gchar * make
Holds a pointer to the make of the vehicle.
float x
Holds the joint x position in pixels.
guint size
Holds the number of signature values in signature.
gchar * shape
Holds the product shape.
gchar * hair
gchar * apparel
Holds a pointer to a description of the person's apparel.
gfloat ptWorldFeet[2]
Holds the object's estimated foot location in 2D coordinates on the estimated world ground.
guint payloadSize
Holds the size of the payload.
NvDsConvexHull convexHull
Holds the object's convex hull information.
gchar * gender
Holds a pointer to the person's gender.
gfloat ptImgFeet[2]
Holds the object's estimated foot location in frame coordinates.
gchar * model
gpointer payload
Holds a pointer to the payload.
GList * mask
Holds a list of polygons for face mask.
float width
Holds the rectangle's width in pixels.
gchar * type
Holds a pointer to the type of the vehicle.
gchar * color
Holds a pointer to the color of the vehicle.
float top
Holds the position of rectangle's top in pixels.
gchar * cap
gchar * license
Holds a pointer to the license number of the vehicle.
guint age
Hold a coordinate's position.
gchar * type
float * embedding_vector
Holds the embedding vector.
int pose_type
Holds the type of pose 0 - 2D, 1 - 3D , integer to support 2.5D in future.
gchar * gender
gdouble alt
Holds the location's altitude.
gchar * shape
int num_joints
Holds the number of joints.
gdouble * signature
Holds a pointer to an array of signature values.
gchar * color
gchar * eyecolor
float y
Holds the joint y position in pixels.
gchar * name
gchar * type
gchar * gender
float confidence
Holds the confidence of the joint.
Holds geolocation parameters.
guint age
gchar * gender
gint * points
Holds a pointer a list of convex hull points.
gdouble y
Holds the coordinate's Y position.
gchar * hair
gdouble lon
Holds the location's longitude.
gchar * license
gchar * make
gdouble z
Holds the coordinate's Z position.
Holds a vehicle object's parameters.
gchar * apparel
Holds Single View 3D Tracking metadata.
gchar * cap
Holds a body pose's joint points.
Holds a face object's parameters.
NvDsEventMsgMeta * metadata
Holds a pointer to event metadata.
gdouble x
Holds the coordinate's X position.
GList * mask
Holds a list of polygons for vehicle mask.
Holds a rectangle's position and size.
gchar * region
NvDsEventType eventType
Holds the type of event.
