NVIDIA DeepStream: Metadata Extension Structures
Description: This file defines the NVIDIA DeepStream metadata structures used to describe metadata objects.
Definition in file nvdsmeta_schema.h.
Data Structures | |
| struct | NvDsRect |
| Holds a rectangle's position and size. More... | |
| struct | NvDsGeoLocation |
| Holds geolocation parameters. More... | |
| struct | NvDsCoordinate |
| Hold a coordinate's position. More... | |
| struct | NvDsObjectSignature |
| Holds an object's signature. More... | |
| struct | NvDsProductObjectExt |
| Holds a product object's parameters. More... | |
| struct | NvDsVehicleObject |
| Holds a vehicle object's parameters. More... | |
| struct | NvDsPersonObject |
| Holds a person object's parameters. More... | |
| struct | NvDsFaceObject |
| Holds a face object's parameters. More... | |
| struct | NvDsVehicleObjectExt |
| struct | NvDsPersonObjectExt |
| struct | NvDsFaceObjectWithExt |
| struct | NvDsJoint |
| Holds a joint's position and confidence. More... | |
| struct | NvDsJoints |
| Holds a body pose's joint points. More... | |
| struct | NvDsEmbedding |
| Holds an embedding model's parameters. More... | |
| struct | NvDsProductObject |
| struct | NvDsConvexHull |
| Holds 2D convex hull metadata. More... | |
| struct | _NvDsBbox3dObject |
| struct | SourceTimePair |
| struct | _NvDsBbox3dObjectList |
| struct | NvDs3DTracking |
| Holds Single View 3D Tracking metadata. More... | |
| struct | NvDsConversationObject |
| struct | NvDsLLMObject |
| struct | NvDsInteractionObject |
| struct | NvDsCongestionObject |
| struct | NvDsTypeMetricsObject |
| struct | NvDsSegmentationObject |
| struct | NvDsEventMsgMeta |
| Holds event message meta data. More... | |
| struct | _NvDsEvent |
| Holds event information. More... | |
| struct | _NvDsCustomMsgInfo |
| Holds data for any user defined custom message to be attached to the payload message : custom message to be attached size : size of the custom message. More... | |
| struct | NvDsPayload |
| Holds payload metadata. More... | |
Macros | |
| #define | MAX_SOURCE_ID_LEN 128 |
| #define | MAX_NUM_OBJECTS 600 |
| #define | MAX_ENTRIES 100 |
Typedefs | |
| typedef enum NvDsEventType | NvDsEventType |
| Defines event type flags. More... | |
| typedef enum NvDsObjectType | NvDsObjectType |
| Defines object type flags. More... | |
| typedef enum NvDsPayloadType | NvDsPayloadType |
| Defines payload type flags. More... | |
| typedef struct NvDsRect | NvDsRect |
| typedef struct NvDsGeoLocation | NvDsGeoLocation |
| typedef struct NvDsCoordinate | NvDsCoordinate |
| typedef struct NvDsObjectSignature | NvDsObjectSignature |
| typedef struct NvDsProductObjectExt | NvDsProductObjectExt |
| typedef struct NvDsVehicleObject | NvDsVehicleObject |
| typedef struct NvDsPersonObject | NvDsPersonObject |
| typedef struct NvDsFaceObject | NvDsFaceObject |
| typedef struct NvDsVehicleObjectExt | NvDsVehicleObjectExt |
| typedef struct NvDsPersonObjectExt | NvDsPersonObjectExt |
| typedef struct NvDsFaceObjectWithExt | NvDsFaceObjectExt |
| typedef struct NvDsJoint | NvDsJoint |
| typedef struct NvDsJoints | NvDsJoints |
| typedef struct NvDsEmbedding | NvDsEmbedding |
| typedef struct NvDsProductObject | NvDsProductObject |
| typedef struct NvDsConvexHull | NvDsConvexHull |
| typedef struct _NvDsBbox3dObject | NvDsBbox3dObject |
| typedef struct _NvDsBbox3dObjectList | NvDsBbox3dObjectList |
| typedef struct NvDs3DTracking | NvDs3DTracking |
| typedef struct NvDsEventMsgMeta | NvDsEventMsgMeta |
| typedef struct _NvDsEvent | NvDsEvent |
| typedef struct _NvDsCustomMsgInfo | NvDsCustomMsgInfo |
| typedef struct NvDsPayload | NvDsPayload |
