7.1 Release
GstCommonBufferAPI Class Reference
Definition at line 32 of file gstnvstreammux_impl.h.
Public Member Functions
 GstCommonBufferAPI (GstElement *a_mux)
void add_component_latency_metadata (std::shared_ptr< BufferWrapper > src_buffer, GstBuffer *gst_batch_buffer, NvDsBatchMeta *batch_meta, unsigned int source_id, unsigned int pad_index, unsigned int frame_number)
void update_component_latency_metadata (NvDsBatchMeta *dest_batch_meta)
◆ GstCommonBufferAPI()
GstCommonBufferAPI::GstCommonBufferAPI ( GstElement *  a_mux)
inline
Definition at line 36 of file gstnvstreammux_impl.h.
Member Function Documentation
◆ add_component_latency_metadata()
void GstCommonBufferAPI::add_component_latency_metadata ( std::shared_ptr< BufferWrapper src_buffer,
GstBuffer gst_batch_buffer,
NvDsBatchMeta batch_meta,
◆ update_component_latency_metadata()
void GstCommonBufferAPI::update_component_latency_metadata ( NvDsBatchMeta dest_batch_meta)
