Define structures that hold metadata.
Data Structures | |
| struct | _NvDsComp_BboxInfo |
| Holds unclipped positional bounding box coordinates of the object processed by the component. More... | |
| struct | _NvDsSensorInfo_meta |
| struct | _NvDsMetaPool |
| Holds information about a given metadata pool. More... | |
| struct | _NvDsBaseMeta |
| Holds information about base metadata of a given metadata type. More... | |
| struct | _NvDsBatchMeta |
| Holds information about a formed batch containing frames from different sources. More... | |
| struct | _NvDsFrameMeta |
| Holds metadata for a frame in a batch. More... | |
| struct | _NvDsObjectMeta |
| Holds metadata for an object in the frame. More... | |
| struct | _NvDsClassifierMeta |
| Holds classifier metadata for an object. More... | |
| struct | _NvDsLabelInfo |
| Holds label metadata for the classifier. More... | |
| struct | NvDsDisplayMeta |
| Holds display metadata that the user can specify in the frame. More... | |
| struct | _NvDsUserMeta |
| Holds user metadata. More... | |
| struct | _NvDsAudioFrameMeta |
| Holds metadata for a audio frame in a batch. More... | |
Macros | |
| #define | MAX_USER_FIELDS 4 |
| Defines the number of additional fields available to the user in the metadata structure. More... | |
| #define | MAX_RESERVED_FIELDS 4 |
| #define | MAX_LABEL_SIZE 128 |
| Defines the maximum size of an array for storing a text result. More... | |
| #define | MAX_ELEMENTS_IN_DISPLAY_META 16 |
| Defines the maximum number of elements that a given display meta can hold. More... | |
| #define | UNTRACKED_OBJECT_ID 0xFFFFFFFFFFFFFFFF |
| Defines an untracked object ID. More... | |
Typedefs | |
| typedef GList | NvDsFrameMetaList |
| typedef GList | NvDsUserMetaList |
| typedef GList | NvDsObjectMetaList |
| typedef GList | NvDisplayMetaList |
| typedef GList | NvDsClassifierMetaList |
| typedef GList | NvDsLabelInfoList |
| typedef GList | NvDsMetaList |
| typedef void | NvDsElementMeta |
| typedef gpointer(* | NvDsMetaCopyFunc) (gpointer data, gpointer user_data) |
| Defines the type of a callback to copy metadata. More... | |
| typedef void(* | NvDsMetaReleaseFunc) (gpointer data, gpointer user_data) |
| Defines the type of a callback to free metadata. More... | |
| typedef struct _NvDsComp_BboxInfo | NvDsComp_BboxInfo |
| typedef struct _NvDsSensorInfo_meta | NvDsSensorInfo_meta |
| typedef struct _NvDsMetaPool | NvDsMetaPool |
| typedef struct _NvDsBaseMeta | NvDsBaseMeta |
| typedef struct _NvDsBatchMeta | NvDsBatchMeta |
| typedef struct _NvDsFrameMeta | NvDsFrameMeta |
| typedef struct _NvDsObjectMeta | NvDsObjectMeta |
| typedef struct _NvDsClassifierMeta | NvDsClassifierMeta |
| typedef struct _NvDsLabelInfo | NvDsLabelInfo |
| typedef struct NvDsDisplayMeta | NvDsDisplayMeta |
| typedef struct _NvDsUserMeta | NvDsUserMeta |
| typedef struct _NvDsAudioFrameMeta | NvDsAudioFrameMeta |
Functions | |
| void | nvds_acquire_meta_lock (NvDsBatchMeta *batch_meta) |
| Acquires a lock before updating metadata. More... | |
| void | nvds_release_meta_lock (NvDsBatchMeta *batch_meta) |
| Releases the lock after updating metadata. More... | |
| NvDsBatchMeta * | nvds_create_batch_meta (guint max_batch_size) |
| Creates a batch metadata structure for a batch of specified size. More... | |
| gboolean | nvds_destroy_batch_meta (NvDsBatchMeta *batch_meta) |
| Destroys a batch metadata structure. More... | |
| NvDsFrameMeta * | nvds_acquire_frame_meta_from_pool (NvDsBatchMeta *batch_meta) |
| Acquires a frame meta from a batch's frame meta pool. More... | |
| void | nvds_add_frame_meta_to_batch (NvDsBatchMeta *batch_meta, NvDsFrameMeta *frame_meta) |
| Adds a frame meta to a batch meta. More... | |
| void | nvds_remove_frame_meta_from_batch (NvDsBatchMeta *batch_meta, NvDsFrameMeta *frame_meta) |
| Removes a frame meta from a batch meta. More... | |
| NvDsObjectMeta * | nvds_acquire_obj_meta_from_pool (NvDsBatchMeta *batch_meta) |
| Acquires an object meta from a batch meta's object meta pool. More... | |
| void | nvds_add_obj_meta_to_frame (NvDsFrameMeta *frame_meta, NvDsObjectMeta *obj_meta, NvDsObjectMeta *obj_parent) |
| Adds an object meta to a frame meta. More... | |
| void | nvds_remove_obj_meta_from_frame (NvDsFrameMeta *frame_meta, NvDsObjectMeta *obj_meta) |
| Removes an object meta from the frame meta to which it is attached. More... | |
| NvDsClassifierMeta * | nvds_acquire_classifier_meta_from_pool (NvDsBatchMeta *batch_meta) |
| Acquires a classifier meta from a batch meta's classifier meta pool. More... | |
| void | nvds_add_classifier_meta_to_roi (NvDsRoiMeta *roi_meta, NvDsClassifierMeta *classifier_meta) |
| Adds a classifier meta to the appropriate roi meta. More... | |
| void | nvds_remove_classifier_meta_from_roi (NvDsRoiMeta *roi_meta, NvDsClassifierMeta *classifier_meta) |
| Removes a classifier meta from the roi meta to which it is attached. More... | |
| void | nvds_add_classifier_meta_to_object (NvDsObjectMeta *obj_meta, NvDsClassifierMeta *classifier_meta) |
| Adds a classifier meta to the appropriate object meta. More... | |
| void | nvds_remove_classifier_meta_from_obj (NvDsObjectMeta *obj_meta, NvDsClassifierMeta *classifier_meta) |
| Removes a classifier meta from the object meta to which it is attached. More... | |
| NvDsDisplayMeta * | nvds_acquire_display_meta_from_pool (NvDsBatchMeta *batch_meta) |
| Acquires a display meta from a batch meta's display meta pool. More... | |
| void | nvds_add_display_meta_to_frame (NvDsFrameMeta *frame_meta, NvDsDisplayMeta *display_meta) |
| Adds a display meta to the appropriate frame meta. More... | |
| void | nvds_remove_display_meta_from_frame (NvDsFrameMeta *frame_meta, NvDsDisplayMeta *display_meta) |
| Removes a display meta from the frame meta to which it is attached. More... | |
| NvDsLabelInfo * | nvds_acquire_label_info_meta_from_pool (NvDsBatchMeta *batch_meta) |
| Acquires a label info meta from a batch meta's label info meta pool. More... | |
| void | nvds_add_label_info_meta_to_classifier (NvDsClassifierMeta *classifier_meta, NvDsLabelInfo *label_info_meta) |
| Adds a label info meta to a classifier meta. More... | |
| void | nvds_remove_label_info_meta_from_classifier (NvDsClassifierMeta *classifier_meta, NvDsLabelInfo *label_info_meta) |
| Removes a label info meta from the classifier meta to which it is attached. More... | |
| void | nvds_add_user_meta_to_batch (NvDsBatchMeta *batch_meta, NvDsUserMeta *user_meta) |
| Add a user meta to a batch meta. More... | |
| void | nvds_add_user_meta_to_frame (NvDsFrameMeta *frame_meta, NvDsUserMeta *user_meta) |
| Add a user meta to a frame meta. More... | |
| void | nvds_add_user_meta_to_roi (NvDsRoiMeta *roi_meta, NvDsUserMeta *user_meta) |
| Add a user meta user to an roi meta. More... | |
| void | nvds_add_user_meta_to_obj (NvDsObjectMeta *obj_meta, NvDsUserMeta *user_meta) |
| Add a user meta user to an object meta. More... | |
| NvDsUserMeta * | nvds_acquire_user_meta_from_pool (NvDsBatchMeta *batch_meta) |
| Acquires a user meta from a batch meta's user meta pool. More... | |
| void | nvds_remove_user_meta_from_batch (NvDsBatchMeta *batch_meta, NvDsUserMeta *user_meta) |
| Removes a user meta from a batch meta to which it is attached. More... | |
| void | nvds_remove_user_meta_from_frame (NvDsFrameMeta *frame_meta, NvDsUserMeta *user_meta) |
| Removes a user meta from a frame meta to which it is attached. More... | |
| void | nvds_remove_user_meta_from_roi (NvDsRoiMeta *obj_meta, NvDsUserMeta *user_meta) |
| Removes a user meta from an roi meta to which it is attached. More... | |
| void | nvds_remove_user_meta_from_object (NvDsObjectMeta *obj_meta, NvDsUserMeta *user_meta) |
| Removes a user meta from an object meta to which it is attached. More... | |
| gboolean | nvds_get_current_metadata_info (NvDsBatchMeta *batch_meta) |
| A debugging function; prints current metadata information available after inference. More... | |
| gpointer | nvds_batch_meta_copy_func (gpointer data, gpointer user_data) |
| Copies or transforms meta data from one buffer to another. More... | |
| void | nvds_batch_meta_release_func (gpointer data, gpointer user_data) |
| Releases metadata from a batch meta. More... | |
| NvDsFrameMeta * | nvds_get_nth_frame_meta (NvDsFrameMetaList *frame_meta_list, guint index) |
| Returns a pointer to a specified frame meta in the frame meta list. More... | |
| void | nvds_clear_frame_meta_list (NvDsBatchMeta *batch_meta, NvDsFrameMetaList *meta_list) |
| Removes all of the frame metadata attached to a batch meta. More... | |
| void | nvds_clear_obj_meta_list (NvDsFrameMeta *frame_meta, NvDsObjectMetaList *meta_list) |
| Removes all the object metadata attached to a frame meta. More... | |
| void | nvds_clear_classifier_meta_list (NvDsObjectMeta *obj_meta, NvDsClassifierMetaList *meta_list) |
| Removes all of the classifier metadata attached to an object meta. More... | |
| void | nvds_clear_label_info_meta_list (NvDsClassifierMeta *classifier_meta, NvDsLabelInfoList *meta_list) |
| Removes all of the label info metadata attached to a classifier meta. More... | |
| void | nvds_clear_display_meta_list (NvDsFrameMeta *frame_meta, NvDisplayMetaList *meta_list) |
| Removes all of the display metadata attached to a frame meta. More... | |
| void | nvds_clear_batch_user_meta_list (NvDsBatchMeta *batch_meta, NvDsUserMetaList *meta_list) |
| Removes all of the user metadata attached to the batch meta. More... | |
| void | nvds_clear_frame_user_meta_list (NvDsFrameMeta *frame_meta, NvDsUserMetaList *meta_list) |
| Removes all of the user metadata attached to the frame meta. More... | |
| void | nvds_clear_obj_user_meta_list (NvDsObjectMeta *object_meta, NvDsUserMetaList *meta_list) |
| Removes all of the user metadata attached to an object meta. More... | |
| NvDsMetaList * | nvds_clear_meta_list (NvDsBatchMeta *batch_meta, NvDsMetaList *meta_list, NvDsMetaPool *meta_pool) |
| Removes all of the metadata elements attached to a metadata list. More... | |
| void | nvds_copy_frame_meta (NvDsFrameMeta *src_frame_meta, NvDsFrameMeta *dst_frame_meta) |
| Makes a deep copy of a frame meta to another frame meta. More... | |
| void | nvds_copy_obj_meta (NvDsObjectMeta *src_object_meta, NvDsObjectMeta *dst_object_meta) |
| Makes a deep copy of an object meta to another object meta. More... | |
| void | nvds_copy_classifier_meta (NvDsClassifierMeta *src_classifier_meta, NvDsClassifierMeta *dst_classifier_meta) |
| Makes a deep copy of a classifier meta to another classifier meta. More... | |
| void | nvds_copy_label_info_meta (NvDsLabelInfo *src_label_info, NvDsLabelInfo *dst_label_info) |
| Makes a deep copy of a label info meta to another label info meta. More... | |
| void | nvds_copy_display_meta (NvDsDisplayMeta *src_display_meta, NvDsDisplayMeta *dst_display_meta) |
| Makes a deep copy of a display meta to another display meta. More... | |
| void | nvds_copy_batch_user_meta_list (NvDsUserMetaList *src_user_meta_list, NvDsBatchMeta *dst_batch_meta) |
| Makes a deep copy of a user meta list to the user meta list in a specified batch meta. More... | |
| void | nvds_copy_frame_user_meta_list (NvDsUserMetaList *src_user_meta_list, NvDsFrameMeta *dst_frame_meta) |
| Makes a deep copy of a source user meta list to the user meta list in a specified frame meta. More... | |
| void | nvds_copy_obj_user_meta_list (NvDsUserMetaList *src_user_meta_list, NvDsObjectMeta *dst_object_meta) |
| Makes a deep copy of a source user meta list to the user meta list in a specified object meta. More... | |
| void | nvds_copy_display_meta_list (NvDisplayMetaList *src_display_meta_list, NvDsFrameMeta *dst_frame_meta) |
| Makes a deep copy of a source display meta list to the display meta list in a specified frame meta. More... | |
| void | nvds_copy_frame_meta_list (NvDsFrameMetaList *src_frame_meta_list, NvDsBatchMeta *dst_batch_meta) |
| Makes a deep copy of a source frame meta list to the frame meta list in a specified batch meta. More... | |
| void | nvds_copy_obj_meta_list (NvDsObjectMetaList *src_obj_meta_list, NvDsFrameMeta *dst_frame_meta) |
| Makes a deep copy of a source object meta list to the object meta list in a specified frame meta. More... | |
| void | nvds_copy_classification_list (NvDsClassifierMetaList *src_classifier_meta_list, NvDsObjectMeta *dst_object_meta) |
| Makes a deep copy of a source classifier meta list to the classifier meta list in a specified object meta. More... | |
| void | nvds_copy_label_info_list (NvDsLabelInfoList *src_label_info_list, NvDsClassifierMeta *dst_classifier_meta) |
| Makes a deep copy of a source label info meta list to the label info meta list in a specified classifier meta. More... | |
| NvDsMetaType | nvds_get_user_meta_type (gchar *meta_descriptor) |
| Generates a unique user metadata type from a specified string describing user-specific metadata. More... | |
| NvDsBatchMeta * | nvds_create_audio_batch_meta (guint max_batch_size) |
| Creates a batch metadata structure for a audio batch of specified size. More... | |
| gboolean | nvds_destroy_audio_batch_meta (NvDsBatchMeta *batch_meta) |
| NvDsAudioFrameMeta * | nvds_acquire_audio_frame_meta_from_pool (NvDsBatchMeta *batch_meta) |
| Acquires a audio frame meta from a batch's audio frame meta pool. More... | |
| void | nvds_add_audio_frame_meta_to_audio_batch (NvDsBatchMeta *batch_meta, NvDsAudioFrameMeta *frame_meta) |
| Adds a audio frame meta to a batch meta. More... | |
| void | nvds_remove_audio_frame_meta_from_audio_batch (NvDsBatchMeta *batch_meta, NvDsAudioFrameMeta *frame_meta) |
| Removes a audio frame meta from a batch meta. More... | |
| void | nvds_add_classifier_meta_to_audio_frame (NvDsAudioFrameMeta *frame_meta, NvDsClassifierMeta *classifier_meta) |
| Adds a classifier meta the audio frame meta. More... | |
| void | nvds_remove_classifier_meta_from_audio_frame (NvDsAudioFrameMeta *frame_meta, NvDsClassifierMeta *classifier_meta) |
| Removes a classifier meta from the audio frame meta to which it is attached. More... | |
| void | nvds_add_user_meta_to_audio_batch (NvDsBatchMeta *batch_meta, NvDsUserMeta *user_meta) |
| Add a user meta to a audio batch meta. More... | |
| void | nvds_add_user_meta_to_audio_frame (NvDsAudioFrameMeta *frame_meta, NvDsUserMeta *user_meta) |
| Add a user meta to a audio frame meta. More... | |
| void | nvds_remove_user_meta_from_audio_batch (NvDsBatchMeta *batch_meta, NvDsUserMeta *user_meta) |
| Removes a user meta from a audio batch meta to which it is attached. More... | |
| void | nvds_remove_user_meta_from_audio_frame (NvDsAudioFrameMeta *frame_meta, NvDsUserMeta *user_meta) |
| Removes a user meta from a audio frame meta to which it is attached. More... | |
| gpointer | nvds_audio_batch_meta_copy_func (gpointer data, gpointer user_data) |
| void | nvds_audio_batch_meta_release_func (gpointer data, gpointer user_data) |
| NvDsAudioFrameMeta * | nvds_get_nth_audio_frame_meta (NvDsFrameMetaList *frame_meta_list, guint index) |
| void | nvds_clear_audio_frame_meta_list (NvDsBatchMeta *batch_meta, NvDsFrameMetaList *meta_list) |
| void | nvds_clear_audio_classifier_meta_list (NvDsAudioFrameMeta *frame_meta, NvDsClassifierMetaList *meta_list) |
| Removes all of the classifier metadata attached to an audio frame meta. More... | |
| void | nvds_clear_audio_batch_user_meta_list (NvDsBatchMeta *batch_meta, NvDsUserMetaList *meta_list) |
| Removes all of the user metadata attached to the audio batch meta. More... | |
| void | nvds_clear_audio_frame_user_meta_list (NvDsAudioFrameMeta *frame_meta, NvDsUserMetaList *meta_list) |
| Removes all of the user metadata attached to the audio frame meta. More... | |
| void | nvds_copy_audio_batch_user_meta_list (NvDsUserMetaList *src_user_meta_list, NvDsBatchMeta *dst_batch_meta) |
| Makes a deep copy of a user meta list to the user meta list in a specified audio batch meta. More... | |
| void | nvds_copy_audio_frame_meta (NvDsAudioFrameMeta *src_frame_meta, NvDsAudioFrameMeta *dst_frame_meta) |
| void | nvds_copy_audio_frame_user_meta_list (NvDsUserMetaList *src_user_meta_list, NvDsAudioFrameMeta *dst_frame_meta) |
| Makes a deep copy of a source user meta list to the user meta list in a specified audio frame meta. More... | |
| void | nvds_copy_audio_frame_meta_list (NvDsFrameMetaList *src_frame_meta_list, NvDsBatchMeta *dst_batch_meta) |
| void | nvds_copy_audio_classification_list (NvDsClassifierMetaList *src_classifier_meta_list, NvDsAudioFrameMeta *dst_frame_meta) |
| #define MAX_ELEMENTS_IN_DISPLAY_META 16 |
Definition at line 52 of file nvdsmeta.h.
| #define MAX_LABEL_SIZE 128 |
Definition at line 49 of file nvdsmeta.h.
| #define MAX_RESERVED_FIELDS 4 |
Definition at line 47 of file nvdsmeta.h.
| #define MAX_USER_FIELDS 4 |
Definition at line 45 of file nvdsmeta.h.
| #define UNTRACKED_OBJECT_ID 0xFFFFFFFFFFFFFFFF |
Definition at line 54 of file nvdsmeta.h.
| typedef GList NvDisplayMetaList |
Definition at line 59 of file nvdsmeta.h.
| typedef struct _NvDsAudioFrameMeta NvDsAudioFrameMeta |
| typedef struct _NvDsBaseMeta NvDsBaseMeta |
| typedef struct _NvDsBatchMeta NvDsBatchMeta |
NOTE: Both Video and Audio metadata uses the same NvDsBatchMeta type. NOTE: Audio batch metadata is formed within nvinferaudio plugin and will not be corresponding to any one buffer output from nvinferaudio. The NvDsBatchMeta for audio is attached to the last input buffer when the audio batch buffering reach configurable threshold (audio frame length) and this is when inference output is available.
| typedef struct _NvDsClassifierMeta NvDsClassifierMeta |
| typedef GList NvDsClassifierMetaList |
Definition at line 60 of file nvdsmeta.h.
| typedef struct _NvDsComp_BboxInfo NvDsComp_BboxInfo |
| typedef struct NvDsDisplayMeta NvDsDisplayMeta |
| typedef void NvDsElementMeta |
Definition at line 63 of file nvdsmeta.h.
| typedef struct _NvDsFrameMeta NvDsFrameMeta |
| typedef GList NvDsFrameMetaList |
Definition at line 56 of file nvdsmeta.h.
| typedef struct _NvDsLabelInfo NvDsLabelInfo |
| typedef GList NvDsLabelInfoList |
Definition at line 61 of file nvdsmeta.h.
| typedef gpointer(* NvDsMetaCopyFunc) (gpointer data, gpointer user_data) |
The callback is passed pointers to source metadata. It allocates the required memory, copies the content from the source metadata and returns a pointer to the destination.
| [in] | data | A pointer to the source metadata. |
| [in] | user_data | A pointer to user-specific data. |
Definition at line 79 of file nvdsmeta.h.
| typedef GList NvDsMetaList |
Definition at line 62 of file nvdsmeta.h.
| typedef struct _NvDsMetaPool NvDsMetaPool |
| typedef void(* NvDsMetaReleaseFunc) (gpointer data, gpointer user_data) |
The callback is passed a pointer to metadata created by NvDsMetaCopyFunc(). It frees the metadata and any other resources that the metadata uses.
| [in] | data | A pointer to the metadata to be freed. |
Definition at line 91 of file nvdsmeta.h.
| typedef struct _NvDsObjectMeta NvDsObjectMeta |
| typedef GList NvDsObjectMetaList |
Definition at line 58 of file nvdsmeta.h.
| typedef struct _NvDsSensorInfo_meta NvDsSensorInfo_meta |
| typedef struct _NvDsUserMeta NvDsUserMeta |
| typedef GList NvDsUserMetaList |
Definition at line 57 of file nvdsmeta.h.
| enum NvDsMetaType |
Specifies the type of metadata.
All metadata types are subtypes of NvDsMetaType. Members that represent NVIDIA-defined types are in the range from NVDS_BATCH_META to NVDS_START_USER_META. User-defined types may be assigned values greater than or equal to NVDS_START_USER_META.
| Enumerator | |
| NVDS_INVALID_META | |
| NVDS_BATCH_META | Specifies metadata type for formed batch. |
| NVDS_FRAME_META | Specifies metadata type for frame. |
| NVDS_OBJ_META | Specifies metadata type for a detected object. |
| NVDS_DISPLAY_META | Specifies metadata type for display. |
| NVDS_CLASSIFIER_META | Specifies metadata type for an object classifier. |
| NVDS_LABEL_INFO_META | Specifies metadata type for a label assigned by a classifier. |
| NVDS_USER_META | Reserved for internal use. |
| NVDS_PAYLOAD_META | Specifies metadata type for a payload generated by a message converter. |
| NVDS_EVENT_MSG_META | Specifies metadata type for a payload generated by a message broker. |
| NVDS_OPTICAL_FLOW_META | Specifies metadata type for an optical flow. |
| NVDS_LATENCY_MEASUREMENT_META | Specifies metadata type for a latency measurement. |
| NVDSINFER_TENSOR_OUTPUT_META | Specifies metadata type for raw inference output attached by Gst-nvinfer.
| NVDSINFER_SEGMENTATION_META | Specifies metadata type for segmentation model output attached by Gst-nvinfer.
| NVDS_CROP_IMAGE_META | Specifies metadata type for JPEG-encoded object crops. See the deepstream-image-meta-test app for details. |
| NVDS_TRACKER_PAST_FRAME_META | Metadata type to be set for tracking previous frames. |
| NVDS_TRACKER_BATCH_REID_META | The ReID vectors for the whole batch generated by tracker. |
| NVDS_TRACKER_OBJ_REID_META | The ReID information for a single object generated by tracker. |
| NVDS_TRACKER_TERMINATED_LIST_META | Information on all terminated Tracks. |
| NVDS_TRACKER_SHADOW_LIST_META | Information on all terminated Tracks. |
| NVDS_OBJ_VISIBILITY | Specifies the visibility of an object. |
| NVDS_OBJ_IMAGE_FOOT_LOCATION | Specifies the foot location of an object on a frame. |
| NVDS_OBJ_WORLD_FOOT_LOCATION | Specifies the foot location of an object on the estimated world ground. |
| NVDS_OBJ_IMAGE_CONVEX_HULL | Specifies the convex hull of an object on a frame. |
| NVDS_OBJ_3D_META | Specifies the 3D object metadata. |
| NVDS_AUDIO_BATCH_META | Specifies metadata type for formed audio batch. |
| NVDS_AUDIO_FRAME_META | Specifies metadata type for audio frame. |
| NVDS_PREPROCESS_FRAME_META | Specifies metadata type for preprocess scale&converted ROIs attached by Gst-nvdspreprocess.
| NVDS_PREPROCESS_BATCH_META | Specifies metadata type for preprocess batch level attached by Gst-nvdspreprocess.
| NVDS_CUSTOM_MSG_BLOB | Specifies user defined custom message blob to be part of payload generated. |
| NVDS_ROI_META | |
| NVDS_CUSTOM_MSG_SPARSE4D | Specifies type for Sparse4D. |
| NVDS_FRAME_META_NVDSANALYTICS | Specifies metadata type for nvdsanalytics frame. |
| NVDS_OBJ_META_NVDSANALYTICS | Specifies metadata type for nvdsanalytics object. |
| NVDS_RESERVED_META | Reserved field. |
| NVDS_GST_CUSTOM_META | Specifies the start of a range of enum values that represent types of NVIDIA-defined Gst metas. The range is from NVDS_GST_CUSTOM_META to NVDS_GST_CUSTOM_META+4096, inclusive. |
| NVDS_START_USER_META | Start adding user specific meta types from here. Specifies the start of a range of enum values that represent custom (application-specific) Gst meta types. A custom meta type may be assigned any enum value equal to or larger than this. Such Gst metas may be attached by GStreamer plugins upstream from Gst-nvstreammux. They may have any contents that is a superset of the metadata in an NvDsFrameMeta. |
| NVDS_FORCE32_META | |
Definition at line 100 of file nvdsmeta.h.
| NvDsAudioFrameMeta* nvds_acquire_audio_frame_meta_from_pool | ( | NvDsBatchMeta * | batch_meta | ) |
You must acquire a audio frame meta before you can fill it with audio frame metadata.
| [in] | batch_meta | A pointer to batch meta from which to acquire a audio frame meta. |
| NvDsClassifierMeta* nvds_acquire_classifier_meta_from_pool | ( | NvDsBatchMeta * | batch_meta | ) |
You must acquire a classifier meta from the classifier meta pool before you can fill it with classifier metadata.
| [in] | batch_meta | A pointer to the batch meta from which to acquire a classifier meta. |
| NvDsDisplayMeta* nvds_acquire_display_meta_from_pool | ( | NvDsBatchMeta * | batch_meta | ) |
You must acquire a display meta before you can fill it with display metadata.
| [in] | batch_meta | A pointer to the batch meta from which to acquire a display meta. |
| NvDsFrameMeta* nvds_acquire_frame_meta_from_pool | ( | NvDsBatchMeta * | batch_meta | ) |
You must acquire a frame meta before you can fill it with frame metadata.
| [in] | batch_meta | A pointer to batch meta from which to acquire a frame meta. |
| NvDsLabelInfo* nvds_acquire_label_info_meta_from_pool | ( | NvDsBatchMeta * | batch_meta | ) |
You must acquire a label info meta before you can fill it and add it to a classifier meta.
| [in] | batch_meta | A pointer to the batch meta from which to acquire a label info meta. |
| void nvds_acquire_meta_lock | ( | NvDsBatchMeta * | batch_meta | ) |
| [in] | batch_meta | A pointer to the NvDsBatchMeta structure to be locked. |
| NvDsObjectMeta* nvds_acquire_obj_meta_from_pool | ( | NvDsBatchMeta * | batch_meta | ) |
You must acquire an object meta before you can fill it with object metadata.
| [in] | batch_meta | A pointer to the batch meta from which to acquire an object meta. |
| NvDsUserMeta* nvds_acquire_user_meta_from_pool | ( | NvDsBatchMeta * | batch_meta | ) |
You must acquire a user meta before you can fill it with user metdata and add it to a batch, frame, or object meta (call nvds_add_user_data_to_batch(), nvds_add_user_data_to_frame(), or nvds_add_user_data_to_obj()).
| [in] | batch_meta | A pointer to the batch meta from which to acquire a user meta. |
| void nvds_add_audio_frame_meta_to_audio_batch | ( | NvDsBatchMeta * | batch_meta, |
| NvDsAudioFrameMeta * | frame_meta | ||
| [in] | batch_meta | A pointer to the NvDsBatchMeta to which frame_meta is to be added. |
| [in] | frame_meta | A pointer to a frame meta to be added to batch_meta. |
| void nvds_add_classifier_meta_to_audio_frame | ( | NvDsAudioFrameMeta * | frame_meta, |
| NvDsClassifierMeta * | classifier_meta | ||
You must acquire a classifier meta with nvds_acquire_classifier_meta_from_pool() and fill it with classifier metadata before you add it to the audio frame metadata.
| [in] | frame_meta | A pointer to the frame meta to which classifier_meta is to be added. |
| [in] | classifier_meta | A pointer to the classifier meta to be added to obj_meta. |
| void nvds_add_classifier_meta_to_object | ( | NvDsObjectMeta * | obj_meta, |
You must acquire a classifier meta with nvds_acquire_classifier_meta_from_pool() and fill it with classifier metadata before you add it to the object metadata.
| [in] | obj_meta | A pointer to the object meta to which classifier_meta is to be added. |
| void nvds_add_classifier_meta_to_roi | ( | NvDsRoiMeta * | roi_meta, |
You must acquire a classifier meta with nvds_acquire_classifier_meta_from_pool() and fill it with classifier metadata before you add it to the roi metadata.
| [in] | roi_meta | A pointer to the roi meta to which classifier_meta is to be added. |
| [in] | classifier_meta | A pointer to the classifier meta to be added to roi_meta. |
| void nvds_add_display_meta_to_frame | ( | NvDsFrameMeta * | frame_meta, |
| NvDsDisplayMeta * | display_meta | ||
You must acquire a display meta with nvds_)acquire_display_meta_from_pool() and fill it with display metadata before you can add it to the frame meta.
| [in] | frame_meta | A pointer to frame meta to which display_meta is to be added. |
| [in] | display_meta | A pointer to the display meta to be added to frame_meta. |
| void nvds_add_frame_meta_to_batch | ( | NvDsBatchMeta * | batch_meta, |
| NvDsFrameMeta * | frame_meta | ||
| void nvds_add_label_info_meta_to_classifier | ( | NvDsClassifierMeta * | classifier_meta, |
| NvDsLabelInfo * | label_info_meta | ||
| [in] | classifier_meta | A pointer to the classifier meta to which label_info_meta is to be added. |
| [in] | label_info_meta | A pointer to the label info meta to be added to classifier_meta. |
| void nvds_add_obj_meta_to_frame | ( | NvDsFrameMeta * | frame_meta, |
| NvDsObjectMeta * | obj_meta, | ||
| NvDsObjectMeta * | obj_parent | ||
You must acquire the object meta with nvds_acquire_object_meta_from_pool() and fill it with metadata before you add to to the frame meta.
| [in] | frame_meta | A pointer to the frame meta to which obj_meta is to be added. |
| [in] | obj_meta | A pointer to an object meta to be added to frame_meta. |
| [in] | obj_parent | A pointer to the this object meta's parent object meta. This pointer is stored in obj_meta->parent. |
| void nvds_add_user_meta_to_audio_batch | ( | NvDsBatchMeta * | batch_meta, |
| NvDsUserMeta * | user_meta | ||
| [in] | batch_meta | A pointer to batch meta to which user_meta is to be added. |
| [in] | user_meta | A pointer to a user meta to be added to batch_meta. |
| void nvds_add_user_meta_to_audio_frame | ( | NvDsAudioFrameMeta * | frame_meta, |
| [in] | frame_meta | A pointer to the frame meta to which user_meta is to be added. |
| [in] | user_meta | A pointer to a user meta to be added to frame_meta. |
| void nvds_add_user_meta_to_batch | ( | NvDsBatchMeta * | batch_meta, |
| void nvds_add_user_meta_to_frame | ( | NvDsFrameMeta * | frame_meta, |
| void nvds_add_user_meta_to_obj | ( | NvDsObjectMeta * | obj_meta, |
| [in] | obj_meta | A pointer to the object meta to which user_meta is to be added. |
| [in] | user_meta | A pointer to the user meta to be added to obj_meta. |
| void nvds_add_user_meta_to_roi | ( | NvDsRoiMeta * | roi_meta, |
| [in] | roi_meta | A pointer to the roi meta to which user_meta is to be added. |
| [in] | user_meta | A pointer to the user meta to be added to roi_meta. |
| gpointer nvds_audio_batch_meta_copy_func | ( | gpointer | data, |
| gpointer | user_data | ||
| [in] | data | A pointer to a batch meta (of type NvDsBatchMeta), cast to gpointer. |
| [in] | user_data | Currently not in use and should be set to NULL. |
| void nvds_audio_batch_meta_release_func | ( | gpointer | data, |
| [in] | data | A pointer to a batch meta (type NvDsBatchMeta), cast to gpointer. |
| gpointer nvds_batch_meta_copy_func | ( | gpointer | data, |
| void nvds_batch_meta_release_func | ( | gpointer | data, |
| void nvds_clear_audio_batch_user_meta_list | ( | NvDsBatchMeta * | batch_meta, |
| NvDsUserMetaList * | meta_list | ||
| [in] | batch_meta | A pointer to the audio batch meta whose user meta list is to be cleared. |
| [in] | meta_list | A pointer to the user meta list to be cleared |
| void nvds_clear_audio_classifier_meta_list | ( | NvDsAudioFrameMeta * | frame_meta, |
| NvDsClassifierMetaList * | meta_list | ||
| [in] | frame_meta | A pointer to NvDsAudioFrameMeta from which NvDsClassifierMetaList needs to be cleared |
| [in] | meta_list | A pointer to NvDsClassifierMetaList which needs to be cleared |
| void nvds_clear_audio_frame_meta_list | ( | NvDsBatchMeta * | batch_meta, |
| NvDsFrameMetaList * | meta_list | ||
| [in] | batch_meta | A pointer to the batch whose frame meta list is to be cleared. |
| [in] | meta_list | A pointer to the frame meta list to be cleared. |
| void nvds_clear_audio_frame_user_meta_list | ( | NvDsAudioFrameMeta * | frame_meta, |
| [in] | frame_meta | A pointer to the audio frame meta whose user meta list is to be cleared. |
| [in] | meta_list | A pointer to the user meta list to be cleared. |
| void nvds_clear_batch_user_meta_list | ( | NvDsBatchMeta * | batch_meta, |
| [in] | batch_meta | A pointer to the batch meta whose user meta list is to be cleared. |
| void nvds_clear_classifier_meta_list | ( | NvDsObjectMeta * | obj_meta, |
| [in] | obj_meta | A pointer to NvDsObjectMeta from which NvDsClassifierMetaList needs to be cleared |
| void nvds_clear_display_meta_list | ( | NvDsFrameMeta * | frame_meta, |
| NvDisplayMetaList * | meta_list | ||
| [in] | frame_meta | A pointer to the frame meta whose display meta list is to be cleared. |
| [in] | meta_list | A pointer to the display meta list to be cleared. |
| void nvds_clear_frame_meta_list | ( | NvDsBatchMeta * | batch_meta, |
| void nvds_clear_frame_user_meta_list | ( | NvDsFrameMeta * | frame_meta, |
| [in] | frame_meta | A pointer to the frame meta whose user meta list is to be cleared. |
| void nvds_clear_label_info_meta_list | ( | NvDsClassifierMeta * | classifier_meta, |
| NvDsLabelInfoList * | meta_list | ||
| [in] | classifier_meta | A pointer to the classifier meta whose label info meta list is to be cleared. |
| [in] | meta_list | A pointer to the label info meta list to be cleared. |
| NvDsMetaList* nvds_clear_meta_list | ( | NvDsBatchMeta * | batch_meta, |
| NvDsMetaList * | meta_list, | ||
| NvDsMetaPool * | meta_pool | ||
| [in] | batch_meta | A pointer to a batch meta. |
| [in] | meta_list | A pointer to meta list to be cleared. |
| [in] | meta_pool | A pointer to the meta pool that contains meta_list. |
| void nvds_clear_obj_meta_list | ( | NvDsFrameMeta * | frame_meta, |
| NvDsObjectMetaList * | meta_list | ||
| [in] | frame_meta | A pointer to the frame meta whose object meta list is to be cleared. |
| [in] | meta_list | A pointer to the object meta list to be cleared. |
| void nvds_clear_obj_user_meta_list | ( | NvDsObjectMeta * | object_meta, |
| [in] | object_meta | A pointer to the object meta whose user meta list is to be cleared. |
| void nvds_copy_audio_batch_user_meta_list | ( | NvDsUserMetaList * | src_user_meta_list, |
| NvDsBatchMeta * | dst_batch_meta | ||
| [in] | src_user_meta_list | A pointer to the source user meta list. |
| [in] | dst_batch_meta | A pointer to the destination batch meta. |
| void nvds_copy_audio_classification_list | ( | NvDsClassifierMetaList * | src_classifier_meta_list, |
| NvDsAudioFrameMeta * | dst_frame_meta | ||
| [in] | src_classifier_meta_list | A pointer to the source classifier meta list. |
| [in] | dst_frame_meta | A pointer to the destination audio frame meta. |
| void nvds_copy_audio_frame_meta | ( | NvDsAudioFrameMeta * | src_frame_meta, |
| [in] | src_frame_meta | A pointer to the source frame meta. |
| [in] | dst_frame_meta | A pointer to the destination frame meta. |
| void nvds_copy_audio_frame_meta_list | ( | NvDsFrameMetaList * | src_frame_meta_list, |
| [in] | src_frame_meta_list | A pointer to the source frame meta list. |
| void nvds_copy_audio_frame_user_meta_list | ( | NvDsUserMetaList * | src_user_meta_list, |
| void nvds_copy_batch_user_meta_list | ( | NvDsUserMetaList * | src_user_meta_list, |
| void nvds_copy_classification_list | ( | NvDsClassifierMetaList * | src_classifier_meta_list, |
| NvDsObjectMeta * | dst_object_meta | ||
| [in] | dst_object_meta | A pointer to the destination object meta. |
| void nvds_copy_classifier_meta | ( | NvDsClassifierMeta * | src_classifier_meta, |
| NvDsClassifierMeta * | dst_classifier_meta | ||
| [in] | src_classifier_meta | A pointer to the source classifier meta. |
| [in] | dst_classifier_meta | A pointer to the destination classifier meta. |
| void nvds_copy_display_meta | ( | NvDsDisplayMeta * | src_display_meta, |
| NvDsDisplayMeta * | dst_display_meta | ||
| [in] | src_display_meta | A pointer to the source display meta. |
| [in] | dst_display_meta | A pointer to destination display meta. |
| void nvds_copy_display_meta_list | ( | NvDisplayMetaList * | src_display_meta_list, |
| NvDsFrameMeta * | dst_frame_meta | ||
| [in] | src_display_meta_list | A pointer to the source display meta list. |
| void nvds_copy_frame_meta | ( | NvDsFrameMeta * | src_frame_meta, |
| void nvds_copy_frame_meta_list | ( | NvDsFrameMetaList * | src_frame_meta_list, |
| void nvds_copy_frame_user_meta_list | ( | NvDsUserMetaList * | src_user_meta_list, |
| void nvds_copy_label_info_list | ( | NvDsLabelInfoList * | src_label_info_list, |
| [in] | src_label_info_list | A pointer to the source label info meta list. |
| void nvds_copy_label_info_meta | ( | NvDsLabelInfo * | src_label_info, |
| NvDsLabelInfo * | dst_label_info | ||
| [in] | src_label_info | A pointer to the source label info meta. |
| [in] | dst_label_info | A pointer to the destination label info meta. |
| void nvds_copy_obj_meta | ( | NvDsObjectMeta * | src_object_meta, |
| [in] | src_object_meta | A pointer to the source object meta. |
| void nvds_copy_obj_meta_list | ( | NvDsObjectMetaList * | src_obj_meta_list, |
| [in] | src_obj_meta_list | A pointer to the source object meta list. |
| void nvds_copy_obj_user_meta_list | ( | NvDsUserMetaList * | src_user_meta_list, |
| NvDsBatchMeta* nvds_create_audio_batch_meta | ( | guint | max_batch_size | ) |
| [in] | max_batch_size | The maximum number of frames in the batch. @ return A pointer to the created structure. |
| NvDsBatchMeta* nvds_create_batch_meta | ( | guint | max_batch_size | ) |
| gboolean nvds_destroy_audio_batch_meta | ( | NvDsBatchMeta * | batch_meta | ) |
| [in] | batch_meta | A pointer to audio batch metadata structure to be destroyed. |
| gboolean nvds_destroy_batch_meta | ( | NvDsBatchMeta * | batch_meta | ) |
| [in] | batch_meta | A pointer to batch metadata structure to be destroyed. |
| gboolean nvds_get_current_metadata_info | ( | NvDsBatchMeta * | batch_meta | ) |
This function should be called after inference.
| [in] | batch_meta | A pointer to a batch meta from which to print information. |
| NvDsAudioFrameMeta* nvds_get_nth_audio_frame_meta | ( | NvDsFrameMetaList * | frame_meta_list, |
| guint | index | ||
| [in] | frame_meta_list | A pointer to a list of pointers to frame metas. |
| [in] | index | The index of the frame meta to be returned. |
| NvDsFrameMeta* nvds_get_nth_frame_meta | ( | NvDsFrameMetaList * | frame_meta_list, |
| guint | index | ||
| NvDsMetaType nvds_get_user_meta_type | ( | gchar * | meta_descriptor | ) |
| [in] | meta_descriptor | A pointer to a string describing user-specific metadata. The string must be in the format ORG_NAME.COMPONENT_NAME.METADATA_DESCRIPTION, e.g. NVIDIA.NVINFER.TENSOR_METADATA. |
| void nvds_release_meta_lock | ( | NvDsBatchMeta * | batch_meta | ) |
| [in] | batch_meta | A pointer to NvDsBatchMeta structure to be unlocked. |
| void nvds_remove_audio_frame_meta_from_audio_batch | ( | NvDsBatchMeta * | batch_meta, |
| [in] | batch_meta | A pointer to the batch meta from which frame_meta is to be removed. |
| [in] | frame_meta | A pointer to the frame meta to be removed from batch_meta. |
| void nvds_remove_classifier_meta_from_audio_frame | ( | NvDsAudioFrameMeta * | frame_meta, |
| [in] | frame_meta | A pointer to the frame meta from which classifier_meta is to be removed. |
| [in] | classifier_meta | A pointer to the classifier meta to be removed from frame_meta. |
| void nvds_remove_classifier_meta_from_obj | ( | NvDsObjectMeta * | obj_meta, |
| [in] | obj_meta | A pointer to the object meta from which classifier_meta is to be removed. |
| [in] | classifier_meta | A pointer to the classifier meta to be removed from obj_meta. |
| void nvds_remove_classifier_meta_from_roi | ( | NvDsRoiMeta * | roi_meta, |
| [in] | roi_meta | A pointer to the roi meta from which classifier_meta is to be removed. |
| [in] | classifier_meta | A pointer to the classifier meta to be removed from roi_meta. |
| void nvds_remove_display_meta_from_frame | ( | NvDsFrameMeta * | frame_meta, |
| [in] | frame_meta | A pointer to the frame meta from which display_meta is to be removed. |
| [in] | display_meta | A pointer to the display meta to be removed from frame_meta. |
| void nvds_remove_frame_meta_from_batch | ( | NvDsBatchMeta * | batch_meta, |
| void nvds_remove_label_info_meta_from_classifier | ( | NvDsClassifierMeta * | classifier_meta, |
| [in] | classifier_meta | A pointer to the classifier meta from which label_info_meta is to be removed. |
| [in] | label_info_meta | A pointer to the label info meta to be removed from classifier_meta. |
| void nvds_remove_obj_meta_from_frame | ( | NvDsFrameMeta * | frame_meta, |
| NvDsObjectMeta * | obj_meta | ||
| [in] | frame_meta | A pointer to frame meta from which obj_meta is to be removed. |
| [in] | obj_meta | A pointer to the object meta to be removed from frame_meta. |
| void nvds_remove_user_meta_from_audio_batch | ( | NvDsBatchMeta * | batch_meta, |
| [in] | batch_meta | A pointer to the audio batch meta from which user_meta is to be removed. |
| [in] | user_meta | A pointer to the user meta to be removed from batch_meta. |
returns acquired NvDsUserMeta pointer from user meta pool
| void nvds_remove_user_meta_from_audio_frame | ( | NvDsAudioFrameMeta * | frame_meta, |
| [in] | frame_meta | A pointer to the frame meta from which user_meta is to be removed. |
| [in] | user_meta | A pointer to the user meta to be removed from frame_meta. |
| void nvds_remove_user_meta_from_batch | ( | NvDsBatchMeta * | batch_meta, |
| [in] | batch_meta | A pointer to the batch meta from which user_meta is to be removed. |
| void nvds_remove_user_meta_from_frame | ( | NvDsFrameMeta * | frame_meta, |
| void nvds_remove_user_meta_from_object | ( | NvDsObjectMeta * | obj_meta, |
| [in] | obj_meta | A pointer to the object meta from which user_meta is to be removed. |
| [in] | user_meta | A pointer to the user to be removed from obj_meta. |
| void nvds_remove_user_meta_from_roi | ( | NvDsRoiMeta * | obj_meta, |
| [in] | roi_meta | A pointer to the roi meta from which user_meta is to be removed. |
| [in] | user_meta | A pointer to the user to be removed from roi_meta. |
