7.1 Release
INFER_EXPORT_API::BufferPool< UniPtr > Class Template Reference
template<class UniPtr>
class INFER_EXPORT_API::BufferPool< UniPtr >
Template class for buffer pool of the specified buffer type.
Template Parameters
UniPtrUnique pointer type of the buffers in the pool.
Definition at line 405 of file infer_utils.h.
Inheritance diagram for INFER_EXPORT_API::BufferPool< UniPtr >:
Collaboration diagram for INFER_EXPORT_API::BufferPool< UniPtr >:
Public Types
using ItemType = typename UniPtr::element_type
using RecylePtr = std::unique_ptr< ItemType, std::function< void(ItemType *)> >
Public Member Functions
 BufferPool (const std::string &name)
 Constructor. More...
virtual ~BufferPool ()
 Destructor. More...
bool setBuffer (UniPtr buf)
 Add a buffer to the pool. More...
int size ()
 Get the number of free buffers. More...
RecylePtr acquireBuffer ()
 Acquire a buffer from the pool. More...
Member Typedef Documentation
◆ ItemType
template<class UniPtr >
using INFER_EXPORT_API::BufferPool< UniPtr >::ItemType = typename UniPtr::element_type
Definition at line 407 of file infer_utils.h.
◆ RecylePtr
using INFER_EXPORT_API::BufferPool< UniPtr >::RecylePtr = std::unique_ptr<ItemType, std::function<void(ItemType*)> >
Definition at line 408 of file infer_utils.h.
◆ BufferPool()
INFER_EXPORT_API::BufferPool< UniPtr >::BufferPool ( const std::string &  name)
inline
Constructor.
Name the pool.
Definition at line 412 of file infer_utils.h.
◆ ~BufferPool()
virtual INFER_EXPORT_API::BufferPool< UniPtr >::~BufferPool ( )
inlinevirtual
Destructor.
Print debug message of number of free buffers.
Definition at line 417 of file infer_utils.h.
References InferDebug, and INFER_EXPORT_API::safeStr().
Member Function Documentation
◆ acquireBuffer()
RecylePtr INFER_EXPORT_API::BufferPool< UniPtr >::acquireBuffer ( )
inline
This function pops a buffer from the pool queue. A deleter function is associate with the buffer pointer to return the buffer to the pool when it is no longer needed.
Returns
A unique pointer with corresponding deleter function.
Definition at line 450 of file infer_utils.h.
◆ setBuffer()
bool INFER_EXPORT_API::BufferPool< UniPtr >::setBuffer ( UniPtr  buf)
inline
Parameters
[in]bufUnique pointer to a buffer to be added to the pool.
Returns
Boolean error status.
Definition at line 428 of file infer_utils.h.
◆ size()
int INFER_EXPORT_API::BufferPool< UniPtr >::size ( )
inline
Definition at line 439 of file infer_utils.h.
