sources/includes/nvdsinferserver/infer_options.h File Reference
Data Structures
class  nvdsinferserver::BufOptions
struct  nvdsinferserver::BufOptions::D::BasicValue
struct  nvdsinferserver::BufOptions::convertType< T * >
struct  nvdsinferserver::BufOptions::convertType< int64_t >
struct  nvdsinferserver::BufOptions::convertType< int32_t >
struct  nvdsinferserver::BufOptions::convertType< int16_t >
struct  nvdsinferserver::BufOptions::convertType< int8_t >
struct  nvdsinferserver::BufOptions::convertType< uint64_t >
struct  nvdsinferserver::BufOptions::convertType< uint32_t >
struct  nvdsinferserver::BufOptions::convertType< uint16_t >
struct  nvdsinferserver::BufOptions::convertType< uint8_t >
struct  nvdsinferserver::BufOptions::convertType< double >
struct  nvdsinferserver::BufOptions::convertType< float >
struct  nvdsinferserver::BufOptions::convertType< bool >
struct  nvdsinferserver::BufOptions::convertType< std::string >
struct  nvdsinferserver::BufOptions::convertType< std::vector< T > >
struct  nvdsinferserver::BufOptions::convertType< std::vector< T * > >
Namespaces
 nvdsinferserver
Macros
#define safeStr(str)   str.c_str()
Typedefs
using nvdsinferserver::SharedBufOptions = std::shared_ptr< BufOptions >
Functions
void dsInferLogPrint__ (NvDsInferLogLevel level, const char *fmt,...)
 Print the nvinferserver log messages as per the configured log level. More...
template<>
void nvdsinferserver::BufOptions::D::BasicValue::setV< std::string > (const std::string &v, OptionType t)
◆ safeStr
#define safeStr (   str)    str.c_str()
Function Documentation
◆ dsInferLogPrint__()
void dsInferLogPrint__ ( NvDsInferLogLevel  level,
const char *  fmt,
inline
Definition at line 27 of file sources/includes/nvdsinferserver/infer_options.h.
