deepstream::AnalyticsObjInfo Class Reference
Definition at line 628 of file service-maker/includes/metadata.hpp.
Inheritance diagram for deepstream::AnalyticsObjInfo:
Collaboration diagram for deepstream::AnalyticsObjInfo:
Public Types
typedef std::unique_ptr< AbstractIterator< UserMetadata > > Iterator
Public Member Functions
 AnalyticsObjInfo (void *data=nullptr)
 Constructor for AnalyticsObjInfo. More...
 AnalyticsObjInfo (const UserMetadata &user_meta)
 Copy constructor for AnalyticsObjInfo. More...
virtual ~AnalyticsObjInfo ()
 Destructor for AnalyticsObjInfo. More...
std::vector< std::string > getRoiStatus () const
 Get the ROI status. More...
std::vector< std::string > getOcStatus () const
 Get the overcrowding status. More...
std::vector< std::string > getLcStatus () const
 Get the line crossing status. More...
std::string getDirStatus () const
 Get the direction status. More...
unsigned int getUniqueId () const
 Get the unique identifier for this metadata. More...
std::string getObjStatus () const
 Get the object status. More...
virtual operator bool () override
 operator to check if a metadata is void More...
int metaType () const
 Get the meta type. More...
void setMetaType (int type)
 Set the meta type. More...
void * userData () const
 Get the user data pointer. More...
void setUserData (void *data, void *(*copy)(void *, void *), void(*release)(void *, void *))
 Set user data with copy and release functions. More...
Protected Member Functions
void get_ (void *&)
void get_ (void *&)
Protected Attributes
void * data_
Member Typedef Documentation
◆ Iterator [1/2]
Definition at line 103 of file service-maker/includes/metadata.hpp.
◆ Iterator [2/2]
Definition at line 103 of file 9.0/service-maker/includes/metadata.hpp.
◆ AnalyticsObjInfo() [1/4]
deepstream::AnalyticsObjInfo::AnalyticsObjInfo ( void *  data = nullptr)
Parameters
dataOptional pointer to data. Defaults to nullptr.
◆ AnalyticsObjInfo() [2/4]
deepstream::AnalyticsObjInfo::AnalyticsObjInfo ( const UserMetadata user_meta)
◆ ~AnalyticsObjInfo() [1/2]
virtual deepstream::AnalyticsObjInfo::~AnalyticsObjInfo ( )
virtual
◆ AnalyticsObjInfo() [3/4]
Parameters
◆ AnalyticsObjInfo() [4/4]
◆ ~AnalyticsObjInfo() [2/2]
virtual
Member Function Documentation
◆ get_() [1/2]
◆ get_() [2/2]
void deepstream::UserMetadata::get_ ( void *&  )
protectedinherited
◆ getDirStatus() [1/2]
std::string deepstream::AnalyticsObjInfo::getDirStatus ( ) const
◆ getDirStatus() [2/2]
◆ getLcStatus() [1/2]
std::vector<std::string> deepstream::AnalyticsObjInfo::getLcStatus ( ) const
◆ getLcStatus() [2/2]
◆ getObjStatus() [1/2]
std::string deepstream::AnalyticsObjInfo::getObjStatus ( ) const
◆ getObjStatus() [2/2]
◆ getOcStatus() [1/2]
std::vector<std::string> deepstream::AnalyticsObjInfo::getOcStatus ( ) const
◆ getOcStatus() [2/2]
◆ getRoiStatus() [1/2]
std::vector<std::string> deepstream::AnalyticsObjInfo::getRoiStatus ( ) const
Get the ROI status.
◆ getRoiStatus() [2/2]
Get the ROI status.
◆ getUniqueId() [1/2]
unsigned int deepstream::AnalyticsObjInfo::getUniqueId ( ) const
◆ getUniqueId() [2/2]
◆ metaType() [1/2]
int deepstream::UserMetadata::metaType ( ) const
inherited
Get the meta type.
◆ metaType() [2/2]
inherited
Get the meta type.
◆ operator bool() [1/2]
virtual deepstream::UserMetadata::operator bool ( )
inlineoverridevirtualinherited
Reimplemented from deepstream::Metadata.
Definition at line 116 of file service-maker/includes/metadata.hpp.
References deepstream::Metadata::data_.
◆ operator bool() [2/2]
Definition at line 116 of file 9.0/service-maker/includes/metadata.hpp.
◆ setMetaType() [1/2]
void deepstream::UserMetadata::setMetaType ( int  type)
inherited
Set the meta type.
◆ setMetaType() [2/2]
inherited
Set the meta type.
◆ setUserData() [1/2]
void deepstream::UserMetadata::setUserData ( void *  data,
void *(*)(void *, void *)  copy,
void(*)(void *, void *)  release
inherited
Parameters
dataPointer to user data
copyCopy function for the user data (can be NULL)
releaseRelease function for the user data (can be NULL)
◆ setUserData() [2/2]
inherited
Parameters
◆ userData() [1/2]
void* deepstream::UserMetadata::userData ( ) const
inherited
◆ userData() [2/2]
inherited
Field Documentation
◆ data_
void * deepstream::Metadata::data_
protectedinherited
