deepstream::UserMetadata Class Reference
Base class of user defined metadata.
Definition at line 101 of file service-maker/includes/metadata.hpp.
Inheritance diagram for deepstream::UserMetadata:
Collaboration diagram for deepstream::UserMetadata:
Public Types
typedef std::unique_ptr< AbstractIterator< UserMetadata > > Iterator
Public Member Functions
 UserMetadata (void *)
 Constructor through opaque data pointer. More...
virtual ~UserMetadata ()
 Destructor. More...
virtual operator bool () override
 operator to check if a metadata is void More...
int metaType () const
 Get the meta type. More...
void setMetaType (int type)
 Set the meta type. More...
void * userData () const
 Get the user data pointer. More...
void setUserData (void *data, void *(*copy)(void *, void *), void(*release)(void *, void *))
 Set user data with copy and release functions. More...
 Destructor. More...
Protected Member Functions
void get_ (void *&)
void get_ (void *&)
Protected Attributes
void * data_
Friends
class BatchMetadata
class FrameMetadata
class ObjectMetadata
Member Typedef Documentation
◆ Iterator [1/2]
◆ Iterator [2/2]
◆ UserMetadata() [1/2]
deepstream::UserMetadata::UserMetadata ( void *  )
By default an empty user metadata object is created.
◆ ~UserMetadata() [1/2]
virtual deepstream::UserMetadata::~UserMetadata ( )
virtual
Destructor.
◆ UserMetadata() [2/2]
◆ ~UserMetadata() [2/2]
virtual
Destructor.
Member Function Documentation
◆ get_() [1/2]
◆ get_() [2/2]
void deepstream::UserMetadata::get_ ( void *&  )
protected
◆ metaType() [1/2]
int deepstream::UserMetadata::metaType ( ) const
Get the meta type.
◆ metaType() [2/2]
Get the meta type.
◆ operator bool() [1/2]
virtual deepstream::UserMetadata::operator bool ( )
inlineoverridevirtual
Reimplemented from deepstream::Metadata.
Definition at line 116 of file service-maker/includes/metadata.hpp.
References deepstream::Metadata::data_.
◆ operator bool() [2/2]
Definition at line 116 of file 9.0/service-maker/includes/metadata.hpp.
◆ setMetaType() [1/2]
void deepstream::UserMetadata::setMetaType ( int  type)
Set the meta type.
◆ setMetaType() [2/2]
Set the meta type.
◆ setUserData() [1/2]
void deepstream::UserMetadata::setUserData ( void *  data,
void *(*)(void *, void *)  copy,
void(*)(void *, void *)  release
Parameters
dataPointer to user data
copyCopy function for the user data (can be NULL)
releaseRelease function for the user data (can be NULL)
◆ setUserData() [2/2]
Parameters
◆ userData() [1/2]
void* deepstream::UserMetadata::userData ( ) const
◆ userData() [2/2]
Friends And Related Function Documentation
◆ BatchMetadata
BatchMetadata
friend
Definition at line 134 of file service-maker/includes/metadata.hpp.
◆ FrameMetadata
FrameMetadata
friend
Definition at line 135 of file service-maker/includes/metadata.hpp.
◆ ObjectMetadata
Definition at line 136 of file service-maker/includes/metadata.hpp.
Field Documentation
◆ data_
void * deepstream::Metadata::data_
protectedinherited
