deepstream::ObjectImageFootLocationUserMetadata Class Reference
Definition at line 561 of file service-maker/includes/metadata.hpp.
Inheritance diagram for deepstream::ObjectImageFootLocationUserMetadata:
Collaboration diagram for deepstream::ObjectImageFootLocationUserMetadata:
Public Types
typedef std::unique_ptr< AbstractIterator< UserMetadata > > Iterator
Public Member Functions
 ObjectImageFootLocationUserMetadata (void *data=nullptr)
 ObjectImageFootLocationUserMetadata (const UserMetadata &user_meta)
virtual ~ObjectImageFootLocationUserMetadata ()
std::pair< float, float > getImageFootLocation () const
 Get the image foot location of the object. More...
virtual operator bool () override
 operator to check if a metadata is void More...
int metaType () const
 Get the meta type. More...
void setMetaType (int type)
 Set the meta type. More...
void * userData () const
 Get the user data pointer. More...
void setUserData (void *data, void *(*copy)(void *, void *), void(*release)(void *, void *))
 Set user data with copy and release functions. More...
Protected Member Functions
void get_ (void *&)
void get_ (void *&)
Protected Attributes
void * data_
Member Typedef Documentation
◆ Iterator [1/2]
Definition at line 103 of file service-maker/includes/metadata.hpp.
◆ Iterator [2/2]
Definition at line 103 of file 9.0/service-maker/includes/metadata.hpp.
◆ ObjectImageFootLocationUserMetadata() [1/4]
deepstream::ObjectImageFootLocationUserMetadata::ObjectImageFootLocationUserMetadata ( void *  data = nullptr)
◆ ObjectImageFootLocationUserMetadata() [2/4]
deepstream::ObjectImageFootLocationUserMetadata::ObjectImageFootLocationUserMetadata ( const UserMetadata user_meta)
◆ ~ObjectImageFootLocationUserMetadata() [1/2]
virtual deepstream::ObjectImageFootLocationUserMetadata::~ObjectImageFootLocationUserMetadata ( )
virtual
◆ ObjectImageFootLocationUserMetadata() [3/4]
◆ ObjectImageFootLocationUserMetadata() [4/4]
◆ ~ObjectImageFootLocationUserMetadata() [2/2]
virtual
Member Function Documentation
◆ get_() [1/2]
◆ get_() [2/2]
void deepstream::UserMetadata::get_ ( void *&  )
protectedinherited
◆ getImageFootLocation() [1/2]
std::pair<float, float> deepstream::ObjectImageFootLocationUserMetadata::getImageFootLocation ( ) const
◆ getImageFootLocation() [2/2]
Referenced by deepstream::NvDsKittiDump::generateTrackerKittiDump().
◆ metaType() [1/2]
int deepstream::UserMetadata::metaType ( ) const
inherited
Get the meta type.
◆ metaType() [2/2]
inherited
Get the meta type.
◆ operator bool() [1/2]
virtual deepstream::UserMetadata::operator bool ( )
inlineoverridevirtualinherited
Reimplemented from deepstream::Metadata.
Definition at line 116 of file 9.0/service-maker/includes/metadata.hpp.
References deepstream::Metadata::data_.
◆ operator bool() [2/2]
Definition at line 116 of file service-maker/includes/metadata.hpp.
◆ setMetaType() [1/2]
void deepstream::UserMetadata::setMetaType ( int  type)
inherited
Set the meta type.
◆ setMetaType() [2/2]
inherited
Set the meta type.
◆ setUserData() [1/2]
void deepstream::UserMetadata::setUserData ( void *  data,
void *(*)(void *, void *)  copy,
void(*)(void *, void *)  release
inherited
Parameters
dataPointer to user data
copyCopy function for the user data (can be NULL)
releaseRelease function for the user data (can be NULL)
◆ setUserData() [2/2]
inherited
Parameters
◆ userData() [1/2]
void* deepstream::UserMetadata::userData ( ) const
inherited
◆ userData() [2/2]
inherited
Field Documentation
◆ data_
void * deepstream::Metadata::data_
protectedinherited
