deepstream::ObjectReidUserMetadata Class Reference
User metadata for object ReID (Re-Identification) features.
This class wraps NvDsObjReid structure for tracker ReID metadata. It can be used to read ReID features from tracker or set custom ReID features.
Definition at line 602 of file service-maker/includes/metadata.hpp.
Inheritance diagram for deepstream::ObjectReidUserMetadata:
Collaboration diagram for deepstream::ObjectReidUserMetadata:
Public Types
typedef std::unique_ptr< AbstractIterator< UserMetadata > > Iterator
Public Member Functions
 ObjectReidUserMetadata (void *data=nullptr)
 ObjectReidUserMetadata (const UserMetadata &user_meta)
ObjectReidUserMetadataoperator= (const ObjectReidUserMetadata &)
 Copy assignment operator. More...
virtual ~ObjectReidUserMetadata ()
unsigned int featureSize () const
 Get the ReID feature vector size. More...
const float * featureVector () const
 Get the ReID feature vector (CPU pointer) More...
void setFeatureVector (const float *features, unsigned int size)
 Set the ReID feature vector. More...
virtual operator bool () override
 operator to check if a metadata is void More...
int metaType () const
 Get the meta type. More...
void setMetaType (int type)
 Set the meta type. More...
void * userData () const
 Get the user data pointer. More...
void setUserData (void *data, void *(*copy)(void *, void *), void(*release)(void *, void *))
 Set user data with copy and release functions. More...
Protected Member Functions
void get_ (void *&)
void get_ (void *&)
Protected Attributes
void * data_
Member Typedef Documentation
◆ Iterator [1/2]
Definition at line 103 of file service-maker/includes/metadata.hpp.
◆ Iterator [2/2]
Definition at line 103 of file 9.0/service-maker/includes/metadata.hpp.
◆ ObjectReidUserMetadata() [1/4]
deepstream::ObjectReidUserMetadata::ObjectReidUserMetadata ( void *  data = nullptr)
◆ ObjectReidUserMetadata() [2/4]
deepstream::ObjectReidUserMetadata::ObjectReidUserMetadata ( const UserMetadata user_meta)
◆ ~ObjectReidUserMetadata() [1/2]
virtual deepstream::ObjectReidUserMetadata::~ObjectReidUserMetadata ( )
virtual
◆ ObjectReidUserMetadata() [3/4]
◆ ObjectReidUserMetadata() [4/4]
◆ ~ObjectReidUserMetadata() [2/2]
virtual
Member Function Documentation
◆ featureSize() [1/2]
unsigned int deepstream::ObjectReidUserMetadata::featureSize ( ) const
◆ featureSize() [2/2]
◆ featureVector() [1/2]
const float* deepstream::ObjectReidUserMetadata::featureVector ( ) const
◆ featureVector() [2/2]
◆ get_() [1/2]
◆ get_() [2/2]
void deepstream::UserMetadata::get_ ( void *&  )
protectedinherited
◆ metaType() [1/2]
int deepstream::UserMetadata::metaType ( ) const
inherited
Get the meta type.
◆ metaType() [2/2]
inherited
Get the meta type.
◆ operator bool() [1/2]
virtual deepstream::UserMetadata::operator bool ( )
inlineoverridevirtualinherited
Reimplemented from deepstream::Metadata.
Definition at line 116 of file service-maker/includes/metadata.hpp.
References deepstream::Metadata::data_.
◆ operator bool() [2/2]
Definition at line 116 of file 9.0/service-maker/includes/metadata.hpp.
◆ operator=() [1/2]
ObjectReidUserMetadata& deepstream::ObjectReidUserMetadata::operator= ( const ObjectReidUserMetadata )
◆ operator=() [2/2]
◆ setFeatureVector() [1/2]
void deepstream::ObjectReidUserMetadata::setFeatureVector ( const float *  features,
unsigned int  size
This allocates memory and copies the feature data. The memory will be managed by the metadata lifecycle.
Parameters
featuresPointer to feature array
sizeNumber of features
◆ setFeatureVector() [2/2]
unsigned int  size
Parameters
◆ setMetaType() [1/2]
void deepstream::UserMetadata::setMetaType ( int  type)
inherited
Set the meta type.
◆ setMetaType() [2/2]
inherited
Set the meta type.
◆ setUserData() [1/2]
void deepstream::UserMetadata::setUserData ( void *  data,
void *(*)(void *, void *)  copy,
void(*)(void *, void *)  release
inherited
Parameters
dataPointer to user data
copyCopy function for the user data (can be NULL)
releaseRelease function for the user data (can be NULL)
◆ setUserData() [2/2]
inherited
Parameters
◆ userData() [1/2]
void* deepstream::UserMetadata::userData ( ) const
inherited
◆ userData() [2/2]
inherited
Field Documentation
◆ data_
void * deepstream::Metadata::data_
protectedinherited
