deepstream::PerfMonitor Class Reference
Definition at line 18 of file service-maker/includes/lib/perf_monitor.hpp.
Public Member Functions
 PerfMonitor (unsigned int batch_size, uint64_t interval, const std::string src_type, bool show_name=true)
 constructor for a performance monitor instance More...
virtual ~PerfMonitor ()
void apply (Element &element, const std::string &tips)
 Apply the performance monitory on an element. More...
void pause ()
 Pause the monitor. More...
void resume ()
 Resume the monitor. More...
void addStream (uint32_t source_id, const char *uri, const char *sensor_id, const char *sensor_name)
 Add a new stream. More...
void removeStream (uint32_t source_id)
void print (void *info)
void pause ()
void resume ()
Protected Attributes
unsigned int batch_size_
uint64_t interval_sec_
void * priv_
void * fps_data_
◆ PerfMonitor() [1/2]
deepstream::PerfMonitor::PerfMonitor ( unsigned int  batch_size,
uint64_t  interval,
bool  show_name = true
Parameters
[in]batch_sizebatch size of the pipeline
[in]intervalmonitor interval in seconds
[in]src_typetype name of the source bin
[in]show_nameshow the stream name in perf log
◆ ~PerfMonitor() [1/2]
virtual deepstream::PerfMonitor::~PerfMonitor ( )
virtual
◆ PerfMonitor() [2/2]
uint64_t  interval,
Parameters
◆ ~PerfMonitor() [2/2]
virtual
Member Function Documentation
◆ addStream() [1/2]
void deepstream::PerfMonitor::addStream ( uint32_t  source_id,
const char *  uri,
const char *  sensor_id,
const char *  sensor_name
Add a new stream.
◆ addStream() [2/2]
const char *  uri,
Add a new stream.
◆ apply() [1/2]
void deepstream::PerfMonitor::apply ( Element element,
const std::string &  tips
Parameters
[in]elementreference to the targeted element
[in]tipsname of the pad
◆ apply() [2/2]
Parameters
◆ pause() [1/2]
void deepstream::PerfMonitor::pause ( )
Pause the monitor.
◆ pause() [2/2]
Pause the monitor.
◆ print() [1/2]
void deepstream::PerfMonitor::print ( void *  info)
◆ print() [2/2]
◆ removeStream() [1/2]
void deepstream::PerfMonitor::removeStream ( uint32_t  source_id)
Add a new stream.
◆ removeStream() [2/2]
Add a new stream.
◆ resume() [1/2]
void deepstream::PerfMonitor::resume ( )
Resume the monitor.
◆ resume() [2/2]
Resume the monitor.
Field Documentation
◆ batch_size_
unsigned int deepstream::PerfMonitor::batch_size_
protected
Definition at line 66 of file service-maker/includes/lib/perf_monitor.hpp.
◆ fps_data_
void * deepstream::PerfMonitor::fps_data_
protected
Definition at line 69 of file service-maker/includes/lib/perf_monitor.hpp.
◆ interval_sec_
uint64_t deepstream::PerfMonitor::interval_sec_
protected
Definition at line 67 of file service-maker/includes/lib/perf_monitor.hpp.
◆ priv_
void * deepstream::PerfMonitor::priv_
protected
Definition at line 68 of file service-maker/includes/lib/perf_monitor.hpp.
