deepstream::Element Class Reference
Element class definition.
Element class derives from the Object class and is a reference based wrapper, supporting copying and moving.
Definition at line 49 of file service-maker/includes/element.hpp.
Inheritance diagram for deepstream::Element:
Collaboration diagram for deepstream::Element:
Public Types
enum  State {
  INVALID,
  EMPTY,
  READY,
  PAUSED,
  PLAYING,
  INVALID,
  EMPTY,
  READY,
  PAUSED,
  PLAYING
enum  State {
  INVALID,
  EMPTY,
  READY,
  PAUSED,
  PLAYING,
  INVALID,
  EMPTY,
  READY,
  PAUSED,
  PLAYING
Public Member Functions
 Element (const std::string &type_name, std::string name=std::string())
 Constructor. More...
 Element (const Object &)
 Downcast copy constructor from Object class. More...
 Element (Object &&)
 Downcast move constructor from Object class. More...
virtual ~Element ()
 Destructor. More...
Elementlink (Element &dst, std::pair< std::string, std::string > hint)
 Link two Element instances using hint. More...
Elementlink (Element &other)
 Link two Element instances directly. More...
BufferProbegetProbe (const std::string &name)
 Find the buffer probe attached to the elmenent by name. More...
ElementaddProbe (const std::string &plugin_name, const std::string &probe_name, const std::string probe_tip="")
 Create and add a buffer probe to the element. More...
template<typename... Args>
ElementaddProbe (const std::string &plugin_name, const std::string &probe_name, const std::string probe_tip="", const Args &... args)
 Template function for creating and adding buffer probe with properties. More...
ElementaddProbe (BufferProbe *probe, const std::string probe_tip="")
 Add a BufferProbe instance to the element. More...
SignalHandlergetSignalHandler (const std::string &name)
 Find the signal handler attached to the element by name. More...
ElementconnectSignal (const std::string &signal_name, SignalHandler *handler)
 Connect a signal handler to the element. More...
ElementconnectSignal (const std::string &plugin_name, const std::string &handler_name, const std::string &signal_names)
 Create and connect a handler to element's signal. More...
ElementconnectSignal (const std::string &plugin_name, const std::string &handler_name, const std::string &signal_names, const Args &... args)
 Template function for creating and connecting signal with properties. More...
const PipelinegetPipeline ()
bool setState (Element::State state)
 Set the Element in particular state. More...
 Element (Object &&)
virtual ~Element ()
 Destructor. More...
const std::string getName () const
 Return the name assigned during the construction. More...
 operator bool () const noexcept
 Check if the object is void. More...
bool operator== (const Object &other) noexcept
 Check if the two objects are the same. More...
GstObjectgive ()
 Give up the ownership and return the opaque pointer. More...
GstObjectgive ()
GstObjectgetGObject ()
 Return the opaque object pointer. More...
Objecttake (GstObject *object)
 Takes the ownership of a object through the opaque pointer. More...
Objectseize (GstObject *object)
 Seize a opaque object to prevent it from being destroyed somewhere. More...
Objectset (const YAML::Node &params)
 Set the properties from key/value pairs in the yaml format. More...
Objectset (const std::string &name, const Value &value)
template<typename T , typename... Args>
Objectset (const std::string &name, const T &value, const Args &... args)
ObjectgetProperty (const std::string &name, T &value, Args &... args)
 Template for getting multiple properties. More...
std::vector< std::string > listSignals (bool is_action)
 List all the supported signals from the object. More...
bool connectSignal (const std::string &signal_name, SignalHandler &handler)
 Connect a signal handler to the object. More...
void emitSignal (const std::string &signal_name, va_list args)
 Emit a signal. More...
static unsigned long type ()
 Return the object's type id. More...
Protected Member Functions
 Element (GstObject *object)
Elementadd_ (CustomObject *object)
template<class T >
T * find_ (const std::string &name)
template<class T >
virtual void set_ (const std::string &name, const Value &value)
virtual void set_ (const std::string &name, const YAML::Node &value)
virtual Value get_ (const std::string &name)
Protected Attributes
std::shared_ptr< std::unordered_map< std::string, std::unique_ptr< CustomObject > > > objects_
Pipelinepipeline_ =nullptr
GstObjectobject_
Friends
class Pipeline
Member Enumeration Documentation
◆ State [1/2]
Enumerator
INVALID
EMPTY
READY
PAUSED
PLAYING
INVALID
EMPTY
READY
PAUSED
PLAYING
Definition at line 52 of file service-maker/includes/element.hpp.
◆ State [2/2]
Enumerator
INVALID
EMPTY
READY
PAUSED
PLAYING
INVALID
EMPTY
READY
PAUSED
PLAYING
Definition at line 52 of file 9.0/service-maker/includes/element.hpp.
◆ Element() [1/8]
deepstream::Element::Element ( const std::string &  type_name,
std::string  name = std::string()
Constructor.
Parameters
[in]type_nameehe type name for a specific element defined with Deepstream SDK
[in]namename given to the Element instance
◆ Element() [2/8]
deepstream::Element::Element ( const Object )
◆ Element() [3/8]
deepstream::Element::Element ( Object &&  )
◆ ~Element() [1/2]
virtual deepstream::Element::~Element ( )
virtual
Destructor.
◆ Element() [4/8]
deepstream::Element::Element ( GstObject object)
protected
◆ Element() [5/8]
Constructor.
Parameters
◆ Element() [6/8]
◆ Element() [7/8]
◆ ~Element() [2/2]
virtual
Destructor.
◆ Element() [8/8]
protected
Member Function Documentation
◆ add_() [1/2]
Element& deepstream::Element::add_ ( CustomObject object)
protected
◆ add_() [2/2]
protected
◆ addProbe() [1/6]
Element& deepstream::Element::addProbe ( BufferProbe probe,
const std::string  probe_tip = ""
Once the probe is added, the element will take the ownership
Parameters
[in]probepointer to the buffer probe
[in]probe_tipextra information for adding the probe, e.g name of the pad
◆ addProbe() [2/6]
Parameters
◆ addProbe() [3/6]
Element& deepstream::Element::addProbe ( const std::string &  plugin_name,
const std::string &  probe_name,
A buffer probe will be automatically created by the factory in the plugin.
Parameters
[in]plugin_namename of the plugin where the factory for the buffer probe is defined
[in]probe_namename of the buffer probe to be added
◆ addProbe() [4/6]
Parameters
Referenced by addProbe().
◆ addProbe() [5/6]
const std::string  probe_tip = "",
inline
Definition at line 115 of file service-maker/includes/element.hpp.
References addProbe(), and getProbe().
◆ addProbe() [6/6]
inline
Definition at line 115 of file 9.0/service-maker/includes/element.hpp.
◆ connectSignal() [1/7]
Element& deepstream::Element::connectSignal ( const std::string &  plugin_name,
const std::string &  handler_name,
const std::string &  signal_names
A signal handler will be created automatically by the factory defined in the plugin
Parameters
[in]plugin_namename of the plugin where the factory of the signal handler is defined
[in]handler_namename of the signal handler to be added
[in]signal_namesnames of the signals for the handler to connect, separated by "/"
◆ connectSignal() [2/7]
Parameters
◆ connectSignal() [3/7]
const std::string &  signal_names,
inline
Definition at line 175 of file service-maker/includes/element.hpp.
References connectSignal(), and getSignalHandler().
◆ connectSignal() [4/7]
inline
Definition at line 175 of file 9.0/service-maker/includes/element.hpp.
◆ connectSignal() [5/7]
bool deepstream::Object::connectSignal ( const std::string &  signal_name,
SignalHandler handler
inherited
Parameters
[in]signal_namename of the signal to be connected
[in]handlerhandler for the signal
◆ connectSignal() [6/7]
Element& deepstream::Element::connectSignal ( const std::string &  signal_name,
A signal handler is responsible for handling the asynchronous signals emitted from the element. Signals behave like events and are defined by their names. Detailed information of signal types available within an element can be found from the Plugin Manual of Deepstream.
Once connected, the element takes the ownership of the signal handler
Parameters
[in]signal_namename of the signal to which the handler is connected
[in]probe_tippointer to the signal handler
Referenced by connectSignal().
◆ connectSignal() [7/7]
Parameters
◆ emitSignal() [1/2]
void deepstream::Object::emitSignal ( const std::string &  signal_name,
va_list  args
inherited
Emit a signal.
◆ emitSignal() [2/2]
va_list  args
inherited
Emit a signal.
◆ find_() [1/2]
template<class T >
T* deepstream::Element::find_ ( const std::string &  name)
inlineprotected
Definition at line 206 of file service-maker/includes/element.hpp.
References objects_.
◆ find_() [2/2]
template<class T >
inlineprotected
Definition at line 206 of file 9.0/service-maker/includes/element.hpp.
◆ get_() [1/2]
virtual Value deepstream::Object::get_ ( const std::string &  name)
protectedvirtualinherited
◆ get_() [2/2]
◆ getGObject() [1/2]
GstObject* deepstream::Object::getGObject ( )
inlineinherited
Definition at line 140 of file service-maker/includes/object.hpp.
References deepstream::Object::object_.
◆ getGObject() [2/2]
inlineinherited
Definition at line 140 of file 9.0/service-maker/includes/object.hpp.
◆ getName() [1/2]
const std::string deepstream::Object::getName ( ) const
inherited
◆ getName() [2/2]
inherited
◆ getPipeline() [1/2]
const Pipeline& deepstream::Element::getPipeline ( )
inline
Definition at line 187 of file service-maker/includes/element.hpp.
References pipeline_.
◆ getPipeline() [2/2]
inline
Definition at line 187 of file 9.0/service-maker/includes/element.hpp.
◆ getProbe() [1/2]
BufferProbe* deepstream::Element::getProbe ( const std::string &  name)
inline
Definition at line 95 of file 9.0/service-maker/includes/element.hpp.
◆ getProbe() [2/2]
inline
Definition at line 95 of file service-maker/includes/element.hpp.
◆ getProperty() [1/2]
Object& deepstream::Object::getProperty ( const std::string &  name,
T &  value,
Args &...  args
inlineinherited
◆ getProperty() [2/2]
T &  value,
Args &...  args
inlineinherited
Definition at line 171 of file 9.0/service-maker/includes/object.hpp.
References deepstream::Object::get_(), and deepstream::Object::getProperty().
◆ getSignalHandler() [1/2]
SignalHandler* deepstream::Element::getSignalHandler ( const std::string &  name)
inline
Definition at line 139 of file 9.0/service-maker/includes/element.hpp.
◆ getSignalHandler() [2/2]
inline
Definition at line 139 of file service-maker/includes/element.hpp.
◆ give() [1/2]
GstObject* deepstream::Object::give ( )
inherited
◆ give() [2/2]
inherited
◆ link() [1/4]
Element& deepstream::Element::link ( Element dst,
Parameters
[in]dsttarget element to which this element links
[in]hinthint for the link, providing the source pad name and target pad name
Returns
target element
◆ link() [2/4]
Parameters
Returns
target element
◆ link() [3/4]
Element& deepstream::Element::link ( Element other)
Parameters
Returns
target element
◆ link() [4/4]
Parameters
Returns
target element
◆ listSignals() [1/2]
std::vector<std::string> deepstream::Object::listSignals ( bool  is_action)
inherited
◆ listSignals() [2/2]
inherited
◆ operator bool() [1/2]
deepstream::Object::operator bool ( ) const
inlineexplicitnoexceptinherited
Definition at line 131 of file 9.0/service-maker/includes/object.hpp.
◆ operator bool() [2/2]
Definition at line 131 of file service-maker/includes/object.hpp.
◆ operator==() [1/2]
bool deepstream::Object::operator== ( const Object other)
inlinenoexceptinherited
Definition at line 134 of file service-maker/includes/object.hpp.
◆ operator==() [2/2]
Definition at line 134 of file 9.0/service-maker/includes/object.hpp.
◆ seize() [1/2]
Object& deepstream::Object::seize ( GstObject object)
inherited
◆ seize() [2/2]
inherited
◆ set() [1/6]
Object& deepstream::Object::set ( const std::string &  name,
const T &  value,
inlineinherited
◆ set() [2/6]
const T &  value,
inlineinherited
◆ set() [3/6]
const Value value
inlineinherited
Definition at line 154 of file service-maker/includes/object.hpp.
References deepstream::Object::set_().
◆ set() [4/6]
const Value value
inlineinherited
Definition at line 154 of file 9.0/service-maker/includes/object.hpp.
◆ set() [5/6]
Object& deepstream::Object::set ( const YAML::Node &  params)
inherited
◆ set() [6/6]
inherited
Referenced by deepstream::Pipeline::add(), and deepstream::Object::set().
◆ set_() [1/4]
virtual void deepstream::Object::set_ ( const std::string &  name,
const Value value
◆ set_() [2/4]
const Value value
◆ set_() [3/4]
const YAML::Node &  value
◆ set_() [4/4]
◆ setState() [1/2]
bool deepstream::Element::setState ( Element::State  state)
◆ setState() [2/2]
◆ take() [1/2]
Object& deepstream::Object::take ( GstObject object)
inherited
◆ take() [2/2]
inherited
◆ type() [1/2]
static unsigned long deepstream::Object::type ( )
staticinherited
◆ type() [2/2]
staticinherited
Friends And Related Function Documentation
◆ Pipeline
Pipeline
friend
Definition at line 218 of file service-maker/includes/element.hpp.
Field Documentation
◆ object_
GstObject * deepstream::Object::object_
protectedinherited
◆ objects_
std::shared_ptr< std::unordered_map< std::string, std::unique_ptr< CustomObject > > > deepstream::Element::objects_
protected
Definition at line 201 of file service-maker/includes/element.hpp.
Referenced by find_().
◆ pipeline_
Pipeline * deepstream::Element::pipeline_ =nullptr
protected
Definition at line 203 of file service-maker/includes/element.hpp.
Referenced by getPipeline().
