deepstream::PreprocessBatchUserMetadata Class Reference
User metadata for preprocess batch.
This user metadata object is associated with a preprocess batch structure
Definition at line 532 of file service-maker/includes/metadata.hpp.
Inheritance diagram for deepstream::PreprocessBatchUserMetadata:
Collaboration diagram for deepstream::PreprocessBatchUserMetadata:
Public Types
typedef std::unique_ptr< AbstractIterator< UserMetadata > > Iterator
Public Member Functions
 PreprocessBatchUserMetadata (void *data=nullptr)
 PreprocessBatchUserMetadata (const UserMetadata &)
virtual ~PreprocessBatchUserMetadata ()
std::vector< unsigned int > getTargetUniqueIds () const
 @Brief Get the target unique ids More...
std::vector< RoiMetadatagetRois () const
 Get the roi list. More...
PreprocessTensorMetadata getPreprocessTensorMetadata () const
 Get the preprocess tensor metadata. More...
bool initPreprocessTensorMetadata (const std::string &name, unsigned int meta_id, unsigned int unique_id, Tensor *tensor)
 Initialize a preprocess tensor metadata. More...
virtual operator bool () override
 operator to check if a metadata is void More...
int metaType () const
 Get the meta type. More...
void setMetaType (int type)
 Set the meta type. More...
void * userData () const
 Get the user data pointer. More...
void setUserData (void *data, void *(*copy)(void *, void *), void(*release)(void *, void *))
 Set user data with copy and release functions. More...
Protected Member Functions
void get_ (void *&)
void get_ (void *&)
Protected Attributes
void * data_
Member Typedef Documentation
◆ Iterator [1/2]
Definition at line 103 of file service-maker/includes/metadata.hpp.
◆ Iterator [2/2]
Definition at line 103 of file 9.0/service-maker/includes/metadata.hpp.
◆ PreprocessBatchUserMetadata() [1/4]
deepstream::PreprocessBatchUserMetadata::PreprocessBatchUserMetadata ( void *  data = nullptr)
◆ PreprocessBatchUserMetadata() [2/4]
deepstream::PreprocessBatchUserMetadata::PreprocessBatchUserMetadata ( const UserMetadata )
◆ ~PreprocessBatchUserMetadata() [1/2]
virtual deepstream::PreprocessBatchUserMetadata::~PreprocessBatchUserMetadata ( )
virtual
◆ PreprocessBatchUserMetadata() [3/4]
◆ PreprocessBatchUserMetadata() [4/4]
◆ ~PreprocessBatchUserMetadata() [2/2]
virtual
Member Function Documentation
◆ get_() [1/2]
◆ get_() [2/2]
void deepstream::UserMetadata::get_ ( void *&  )
protectedinherited
◆ getPreprocessTensorMetadata() [1/2]
PreprocessTensorMetadata deepstream::PreprocessBatchUserMetadata::getPreprocessTensorMetadata ( ) const
◆ getPreprocessTensorMetadata() [2/2]
◆ getRois() [1/2]
std::vector<RoiMetadata> deepstream::PreprocessBatchUserMetadata::getRois ( ) const
Get the roi list.
◆ getRois() [2/2]
Get the roi list.
◆ getTargetUniqueIds() [1/2]
std::vector<unsigned int> deepstream::PreprocessBatchUserMetadata::getTargetUniqueIds ( ) const
◆ getTargetUniqueIds() [2/2]
◆ initPreprocessTensorMetadata() [1/2]
bool deepstream::PreprocessBatchUserMetadata::initPreprocessTensorMetadata ( const std::string &  name,
Tensor tensor
◆ initPreprocessTensorMetadata() [2/2]
Tensor tensor
◆ metaType() [1/2]
int deepstream::UserMetadata::metaType ( ) const
inherited
Get the meta type.
◆ metaType() [2/2]
inherited
Get the meta type.
◆ operator bool() [1/2]
virtual deepstream::UserMetadata::operator bool ( )
inlineoverridevirtualinherited
Reimplemented from deepstream::Metadata.
Definition at line 116 of file service-maker/includes/metadata.hpp.
References deepstream::Metadata::data_.
◆ operator bool() [2/2]
Definition at line 116 of file 9.0/service-maker/includes/metadata.hpp.
◆ setMetaType() [1/2]
void deepstream::UserMetadata::setMetaType ( int  type)
inherited
Set the meta type.
◆ setMetaType() [2/2]
inherited
Set the meta type.
◆ setUserData() [1/2]
void deepstream::UserMetadata::setUserData ( void *  data,
void *(*)(void *, void *)  copy,
void(*)(void *, void *)  release
inherited
Parameters
dataPointer to user data
copyCopy function for the user data (can be NULL)
releaseRelease function for the user data (can be NULL)
◆ setUserData() [2/2]
inherited
Parameters
◆ userData() [1/2]
void* deepstream::UserMetadata::userData ( ) const
inherited
◆ userData() [2/2]
inherited
Field Documentation
◆ data_
void * deepstream::Metadata::data_
protectedinherited
