deepstream::SegmentationUserMetadata Class Reference
A class to handle user metadata for segmentation.
This class extends the UserMetadata class and provides additional functionality specific to segmentation metadata.
Definition at line 314 of file service-maker/includes/metadata.hpp.
Inheritance diagram for deepstream::SegmentationUserMetadata:
Collaboration diagram for deepstream::SegmentationUserMetadata:
Public Types
typedef std::unique_ptr< AbstractIterator< UserMetadata > > Iterator
Public Member Functions
 SegmentationUserMetadata (void *data=nullptr)
 Constructor for SegmentationUserMetadata. More...
 SegmentationUserMetadata (const UserMetadata &other)
 Copy constructor for SegmentationUserMetadata. More...
virtual ~SegmentationUserMetadata ()
 Destructor for SegmentationUserMetadata. More...
unsigned int uniqueId () const
 Get the unique identifier for this metadata. More...
unsigned int getClasses () const
 Get the number of classes in the segmentation. More...
unsigned int getWidth () const
 Get the width of the segmentation map. More...
unsigned int getHeight () const
 Get the height of the segmentation map. More...
const int * getClassMap () const
 Get the class map for the segmentation. More...
const float * getClassProbabilitiesMap () const
 Get the class probabilities map for the segmentation. More...
virtual operator bool () override
 operator to check if a metadata is void More...
int metaType () const
 Get the meta type. More...
void setMetaType (int type)
 Set the meta type. More...
void * userData () const
 Get the user data pointer. More...
void setUserData (void *data, void *(*copy)(void *, void *), void(*release)(void *, void *))
 Set user data with copy and release functions. More...
Protected Member Functions
void get_ (void *&)
void get_ (void *&)
Protected Attributes
void * data_
Member Typedef Documentation
◆ Iterator [1/2]
Definition at line 103 of file service-maker/includes/metadata.hpp.
◆ Iterator [2/2]
Definition at line 103 of file 9.0/service-maker/includes/metadata.hpp.
◆ SegmentationUserMetadata() [1/4]
deepstream::SegmentationUserMetadata::SegmentationUserMetadata ( void *  data = nullptr)
Parameters
dataOptional pointer to data. Defaults to nullptr.
◆ SegmentationUserMetadata() [2/4]
deepstream::SegmentationUserMetadata::SegmentationUserMetadata ( const UserMetadata other)
◆ ~SegmentationUserMetadata() [1/2]
virtual deepstream::SegmentationUserMetadata::~SegmentationUserMetadata ( )
virtual
◆ SegmentationUserMetadata() [3/4]
Parameters
◆ SegmentationUserMetadata() [4/4]
◆ ~SegmentationUserMetadata() [2/2]
virtual
Member Function Documentation
◆ get_() [1/2]
◆ get_() [2/2]
void deepstream::UserMetadata::get_ ( void *&  )
protectedinherited
◆ getClasses() [1/2]
unsigned int deepstream::SegmentationUserMetadata::getClasses ( ) const
◆ getClasses() [2/2]
◆ getClassMap() [1/2]
const int* deepstream::SegmentationUserMetadata::getClassMap ( ) const
◆ getClassMap() [2/2]
◆ getClassProbabilitiesMap() [1/2]
const float* deepstream::SegmentationUserMetadata::getClassProbabilitiesMap ( ) const
◆ getClassProbabilitiesMap() [2/2]
◆ getHeight() [1/2]
unsigned int deepstream::SegmentationUserMetadata::getHeight ( ) const
◆ getHeight() [2/2]
◆ getWidth() [1/2]
unsigned int deepstream::SegmentationUserMetadata::getWidth ( ) const
◆ getWidth() [2/2]
◆ metaType() [1/2]
int deepstream::UserMetadata::metaType ( ) const
inherited
Get the meta type.
◆ metaType() [2/2]
inherited
Get the meta type.
◆ operator bool() [1/2]
virtual deepstream::UserMetadata::operator bool ( )
inlineoverridevirtualinherited
Reimplemented from deepstream::Metadata.
Definition at line 116 of file 9.0/service-maker/includes/metadata.hpp.
References deepstream::Metadata::data_.
◆ operator bool() [2/2]
Definition at line 116 of file service-maker/includes/metadata.hpp.
◆ setMetaType() [1/2]
void deepstream::UserMetadata::setMetaType ( int  type)
inherited
Set the meta type.
◆ setMetaType() [2/2]
inherited
Set the meta type.
◆ setUserData() [1/2]
void deepstream::UserMetadata::setUserData ( void *  data,
void *(*)(void *, void *)  copy,
void(*)(void *, void *)  release
inherited
Parameters
dataPointer to user data
copyCopy function for the user data (can be NULL)
releaseRelease function for the user data (can be NULL)
◆ setUserData() [2/2]
inherited
Parameters
◆ uniqueId() [1/2]
unsigned int deepstream::SegmentationUserMetadata::uniqueId ( ) const
◆ uniqueId() [2/2]
◆ userData() [1/2]
void* deepstream::UserMetadata::userData ( ) const
inherited
◆ userData() [2/2]
inherited
Field Documentation
◆ data_
void * deepstream::Metadata::data_
protectedinherited
