7.1 Release
nvdsinfer::BackendContext Class Referenceabstract
Abstract interface for managing the actual inferencing implementation.
This interface abstracts away the low-level implementation details required for inferencing with implicit batch dimensions network/full dimensions network on GPU and inferencing on DLA.
Actual instance of a BackendContext can be created using createBackendContext function. This function will create the appropriate BackendContext (ImplicitTrtBackendContext/FullDimTrtBackendContext/DlaTrtBackendContext) based on the parameters used to build the network/engine.
Definition at line 167 of file nvdsinfer_backend.h.
Inheritance diagram for nvdsinfer::BackendContext:
Public Member Functions
 BackendContext ()=default
virtual ~BackendContext ()=default
virtual NvDsInferStatus initialize ()=0
virtual int getNumBoundLayers ()=0
virtual const NvDsInferBatchDimsLayerInfo & getLayerInfo (int bindingIdx)=0
virtual bool isOutputLayer (const std::string &bindingName)=0
virtual bool canSupportBatchDims (int bindingIdx, const NvDsInferBatchDims &batchDims)=0
virtual NvDsInferBatchDims getMaxBatchDims (int bindingIdx)=0
virtual NvDsInferBatchDims getMinBatchDims (int bindingIdx)=0
virtual NvDsInferBatchDims getOptBatchDims (int bindingIdx)=0
virtual NvDsInferStatus enqueueBuffer (const std::shared_ptr< InferBatchBuffer > &buffer, CudaStream &stream, CudaEvent *consumeEvent)=0
◆ BackendContext()
nvdsinfer::BackendContext::BackendContext ( )
default
◆ ~BackendContext()
virtual nvdsinfer::BackendContext::~BackendContext ( )
virtualdefault
Member Function Documentation
◆ canSupportBatchDims()
virtual bool nvdsinfer::BackendContext::canSupportBatchDims ( int  bindingIdx,
const NvDsInferBatchDims &  batchDims
pure virtual
◆ enqueueBuffer()
virtual NvDsInferStatus nvdsinfer::BackendContext::enqueueBuffer ( const std::shared_ptr< InferBatchBuffer > &  buffer,
CudaStream stream,
CudaEvent consumeEvent
pure virtual
◆ getLayerInfo()
virtual const NvDsInferBatchDimsLayerInfo& nvdsinfer::BackendContext::getLayerInfo ( int  bindingIdx)
pure virtual
◆ getMaxBatchDims()
virtual NvDsInferBatchDims nvdsinfer::BackendContext::getMaxBatchDims ( int  bindingIdx)
pure virtual
◆ getMinBatchDims()
virtual NvDsInferBatchDims nvdsinfer::BackendContext::getMinBatchDims ( int  bindingIdx)
pure virtual
◆ getNumBoundLayers()
virtual int nvdsinfer::BackendContext::getNumBoundLayers ( )
pure virtual
◆ getOptBatchDims()
virtual NvDsInferBatchDims nvdsinfer::BackendContext::getOptBatchDims ( int  bindingIdx)
pure virtual
◆ initialize()
virtual NvDsInferStatus nvdsinfer::BackendContext::initialize ( )
pure virtual
◆ isOutputLayer()
virtual bool nvdsinfer::BackendContext::isOutputLayer ( const std::string &  bindingName)
pure virtual
