Gst-infer API Common Elements
Defines common elements used in the API exposed by the Gst-inference plugin.
Data Structures
struct  NvDsInferDims
 Holds the dimensions of a layer. More...
struct  NvDsInferDimsCHW
 Holds the dimensions of a three-dimensional layer. More...
struct  NvDsInferLayerInfo
 Holds information about one layer in the model. More...
struct  NvDsInferNetworkInfo
 Holds information about the model network. More...
struct  NvDsInferObjectDetectionInfo
 Holds information about one parsed object from a detector's output. More...
struct  NvDsInferInstanceMaskInfo
 Holds information about one parsed object and instance mask from a detector's output. More...
struct  NvDsInferAttribute
 Holds information about one classified attribute. More...
Macros
#define NVDSINFER_MAX_DIMS   8
#define _DS_DEPRECATED_(STR)   __attribute__ ((deprecated (STR)))
#define getDimsCHWFromDims(dimsCHW, dims)
 Sets values on a NvDsInferDimsCHW structure from a NvDsInferDims structure. More...
#define getDimsHWCFromDims(dimsCHW, dims)
Typedefs
typedef NvDsInferObjectDetectionInfo NvDsInferParseObjectInfo
 A typedef defined to maintain backward compatibility. More...
Enumerations
enum  NvDsInferDataType {
  FLOAT = 0,
  HALF = 1,
  INT8 = 2,
  INT32 = 3,
  INT64 = 4,
  UINT8 = 5,
  FLOAT = 0,
  HALF = 1,
  INT8 = 2,
  INT32 = 3,
  INT64 = 4,
  UINT8 = 5
 Specifies the data type of a layer. More...
enum  NvDsInferStatus {
  NVDSINFER_SUCCESS = 0,
  NVDSINFER_CONFIG_FAILED,
  NVDSINFER_CUSTOM_LIB_FAILED,
  NVDSINFER_INVALID_PARAMS,
  NVDSINFER_OUTPUT_PARSING_FAILED,
  NVDSINFER_CUDA_ERROR,
  NVDSINFER_TENSORRT_ERROR,
  NVDSINFER_RESOURCE_ERROR,
  NVDSINFER_TRITON_ERROR,
  NVDSINFER_TRTIS_ERROR = NVDSINFER_TRITON_ERROR,
  NVDSINFER_MEM_ERROR,
  NVDSINFER_UNKNOWN_ERROR,
 Enum for the status codes returned by NvDsInferContext. More...
enum  NvDsInferLogLevel {
  NVDSINFER_LOG_ERROR = 0,
  NVDSINFER_LOG_WARNING,
  NVDSINFER_LOG_INFO,
  NVDSINFER_LOG_DEBUG,
  NVDSINFER_LOG_INFO,
  NVDSINFER_LOG_DEBUG
 Enum for the log levels of NvDsInferContext. More...
  FLOAT = 0,
  HALF = 1,
  INT8 = 2,
  INT32 = 3,
  INT64 = 4,
  UINT8 = 5,
  FLOAT = 0,
  HALF = 1,
  INT8 = 2,
  INT32 = 3,
  INT64 = 4,
  UINT8 = 5
  NVDSINFER_LOG_INFO,
  NVDSINFER_LOG_INFO,
  NVDSINFER_LOG_DEBUG
Functions
const char * NvDsInferStatus2Str (NvDsInferStatus status)
 Get the string name for the status. More...
◆ _DS_DEPRECATED_ [1/2]
#define _DS_DEPRECATED_ (   STR)    __attribute__ ((deprecated (STR)))
Definition at line 41 of file sources/includes/nvdsinfer.h.
◆ _DS_DEPRECATED_ [2/2]
Definition at line 41 of file 9.0/sources/includes/nvdsinfer.h.
◆ getDimsCHWFromDims [1/2]
#define getDimsCHWFromDims (   dimsCHW,
  dims
Value:
do { \
(dimsCHW).c = (dims).d[0]; \
(dimsCHW).h = (dims).d[1]; \
(dimsCHW).w = (dims).d[2]; \
} while (0)
Definition at line 128 of file 9.0/sources/includes/nvdsinfer.h.
◆ getDimsCHWFromDims [2/2]
  dims
Value:
do { \
} while (0)
Definition at line 128 of file sources/includes/nvdsinfer.h.
◆ getDimsHWCFromDims [1/2]
#define getDimsHWCFromDims (   dimsCHW,
  dims
Value:
do { \
(dimsCHW).h = (dims).d[0]; \
(dimsCHW).w = (dims).d[1]; \
(dimsCHW).c = (dims).d[2]; \
} while (0)
Definition at line 135 of file sources/includes/nvdsinfer.h.
◆ getDimsHWCFromDims [2/2]
  dims
Value:
do { \
} while (0)
Definition at line 135 of file 9.0/sources/includes/nvdsinfer.h.
◆ NVDSINFER_MAX_DIMS [1/2]
Definition at line 39 of file sources/includes/nvdsinfer.h.
◆ NVDSINFER_MAX_DIMS [2/2]
Definition at line 39 of file 9.0/sources/includes/nvdsinfer.h.
Typedef Documentation
◆ NvDsInferParseObjectInfo [1/2]
Definition at line 171 of file sources/includes/nvdsinfer.h.
◆ NvDsInferParseObjectInfo [2/2]
Definition at line 171 of file 9.0/sources/includes/nvdsinfer.h.
◆ NvDsInferDataType [1/2]
Enumerator
FLOAT
Specifies FP32 format.
HALF
Specifies FP16 format.
INT8
Specifies INT8 format.
INT32
Specifies INT32 format.
INT64
Specifies INT64 format.
UINT8
Specifies UINT8 format.
FLOAT
HALF
INT8
INT32
INT64
UINT8
Definition at line 72 of file sources/includes/nvdsinfer.h.
◆ NvDsInferDataType [2/2]
Enumerator
FLOAT
HALF
INT8
INT32
INT64
UINT8
FLOAT
HALF
INT8
INT32
INT64
UINT8
Definition at line 72 of file 9.0/sources/includes/nvdsinfer.h.
◆ NvDsInferLogLevel [1/2]
Enumerator
NVDSINFER_LOG_ERROR
NVDSINFER_LOG_INFO
NVDSINFER_LOG_DEBUG
NVDSINFER_LOG_ERROR
NVDSINFER_LOG_INFO
NVDSINFER_LOG_DEBUG
Definition at line 257 of file 9.0/sources/includes/nvdsinfer.h.
◆ NvDsInferLogLevel [2/2]
Enumerator
NVDSINFER_LOG_ERROR
NVDSINFER_LOG_INFO
NVDSINFER_LOG_DEBUG
NVDSINFER_LOG_ERROR
NVDSINFER_LOG_INFO
NVDSINFER_LOG_DEBUG
Definition at line 257 of file sources/includes/nvdsinfer.h.
◆ NvDsInferStatus [1/2]
Enumerator
NVDSINFER_SUCCESS
Failed to configure the NvDsInferContext instance possibly due to an erroneous initialization property.
Custom Library interface implementation failed.
Invalid parameters were supplied.
Output parsing failed.
CUDA error was encountered.
TensorRT interface failed.
Resource error was encountered.
Triton error was encountered.
Renamed TRT-IS to Triton.
[deprecated]TRT-IS error was encountered
NVDSINFER_MEM_ERROR
Cuda Memory error was encountered.
Unknown error was encountered.
NVDSINFER_SUCCESS
NVDSINFER_MEM_ERROR
Definition at line 226 of file sources/includes/nvdsinfer.h.
◆ NvDsInferStatus [2/2]
Enumerator
NVDSINFER_SUCCESS
NVDSINFER_MEM_ERROR
NVDSINFER_SUCCESS
NVDSINFER_MEM_ERROR
Definition at line 226 of file 9.0/sources/includes/nvdsinfer.h.
Function Documentation
◆ NvDsInferStatus2Str()
const char * NvDsInferStatus2Str ( NvDsInferStatus  status)
Parameters
[in]statusAn NvDsInferStatus value.
Returns
String name for the status. Memory is owned by the function. Callers should not free the pointer.
