7.1 Release
nvdsinferserver::TrtServerAllocator Class Reference
Wrapper class for Triton server output memory allocator.
Definition at line 351 of file infer_trtis_server.h.
Inheritance diagram for nvdsinferserver::TrtServerAllocator:
Collaboration diagram for nvdsinferserver::TrtServerAllocator:
Public Types
using AllocFn = std::function< SharedSysMem(const std::string &, size_t, InferMemType, int64_t)>
using FreeFn = std::function< void(const std::string &, SharedSysMem)>
Public Member Functions
 TrtServerAllocator (AllocFn alloc, FreeFn release)
 Constructor, create an instance of the type TRITONSERVER_ResponseAllocator which calls provided allocator and release functions. More...
virtual ~TrtServerAllocator ()=default
 Destructor. More...
TRITONSERVER_ResponseAllocator * ptr ()
 Get the pointer to the TRITONSERVER_ResponseAllocator instance. More...
Member Typedef Documentation
◆ AllocFn
using nvdsinferserver::TrtServerAllocator::AllocFn = std::function<SharedSysMem(const std::string&, size_t, InferMemType, int64_t)>
Definition at line 354 of file infer_trtis_server.h.
◆ FreeFn
using nvdsinferserver::TrtServerAllocator::FreeFn = std::function<void(const std::string&, SharedSysMem)>
Definition at line 355 of file infer_trtis_server.h.
◆ TrtServerAllocator()
nvdsinferserver::TrtServerAllocator::TrtServerAllocator ( AllocFn  alloc,
FreeFn  release
Parameters
allocAllocation function for the output tensors.
releaseRelease function for the output tensors.
◆ ~TrtServerAllocator()
virtual nvdsinferserver::TrtServerAllocator::~TrtServerAllocator ( )
virtualdefault
Destructor.
Default.
Member Function Documentation
◆ ptr()
TRITONSERVER_ResponseAllocator* nvdsinferserver::TrtServerAllocator::ptr ( )
inline
Definition at line 374 of file infer_trtis_server.h.
