prometheus::Info Class Reference
A info metric to represent textual information which should not change during process lifetime.
This class represents the metric type info: https://github.com/OpenObservability/OpenMetrics/blob/98ae26c87b1c3bcf937909a880b32c8be643cc9b/specification/OpenMetrics.md#info Prometheus does not provide this type directly, it is used by emulating a gauge with value 1: https://prometheus.io/docs/concepts/metric_types/#gauge
The value of the info cannot change. Example of infos are:
  • the application's version
  • revision control commit
  • version of the compiler
The class is thread-safe. No concurrent call to any API of this type causes a data race.
Definition at line 26 of file sources/includes/prometheus/info.h.
Public Member Functions
 Info ()=default
 Create a info. More...
ClientMetric Collect () const
 Get the current value of the info. More...
 Info ()=default
Static Public Attributes
static const MetricType metric_type {MetricType::Info}
◆ Info() [1/2]
prometheus::Info::Info ( )
default
Create a info.
◆ Info() [2/2]
default
Create a info.
Member Function Documentation
◆ Collect() [1/2]
ClientMetric prometheus::Info::Collect ( ) const
Collect is called by the Registry when collecting metrics.
◆ Collect() [2/2]
Field Documentation
◆ metric_type
static const MetricType prometheus::Info::metric_type {MetricType::Info}
static
Definition at line 28 of file sources/includes/prometheus/info.h.
