7.1 Release
deepstream_app.h File Reference
Data Structures
struct  NvDsInstanceBin
struct  NvDsPipeline
struct  NvDsConfig
struct  NvDsInstanceData
struct  _AppCtx
Typedefs
typedef struct _AppCtx AppCtx
typedef void(* bbox_generated_callback) (AppCtx *appCtx, GstBuffer *buf, NvDsBatchMeta *batch_meta, guint index)
typedef gboolean(* overlay_graphics_callback) (AppCtx *appCtx, GstBuffer *buf, NvDsBatchMeta *batch_meta, guint index)
Functions
gboolean create_pipeline (AppCtx *appCtx, bbox_generated_callback bbox_generated_post_analytics_cb, bbox_generated_callback all_bbox_generated_cb, perf_callback perf_cb, overlay_graphics_callback overlay_graphics_cb)
 Create DS Anyalytics Pipeline per the appCtx configurations. More...
gboolean pause_pipeline (AppCtx *appCtx)
gboolean resume_pipeline (AppCtx *appCtx)
gboolean seek_pipeline (AppCtx *appCtx, glong milliseconds, gboolean seek_is_relative)
void toggle_show_bbox_text (AppCtx *appCtx)
void destroy_pipeline (AppCtx *appCtx)
void restart_pipeline (AppCtx *appCtx)
gboolean parse_config_file (NvDsConfig *config, gchar *cfg_file_path)
 Function to read properties from configuration file. More...
gboolean parse_config_file_yaml (NvDsConfig *config, gchar *cfg_file_path)
 Function to read properties from YML configuration file. More...
NvDsSensorInfoget_sensor_info (AppCtx *appCtx, guint source_id)
 Function to procure the NvDsSensorInfo for the source_id that was added using the nvmultiurisrcbin REST API. More...
Typedef Documentation
◆ AppCtx
Definition at line 46 of file deepstream_app.h.
◆ bbox_generated_callback
Definition at line 48 of file deepstream_app.h.
◆ overlay_graphics_callback
Definition at line 50 of file deepstream_app.h.
Function Documentation
◆ create_pipeline()
gboolean create_pipeline ( AppCtx appCtx,
Parameters
appCtx[IN/OUT] The application context providing the config info and where the pipeline resources are maintained
bbox_generated_post_analytics_cb[IN] This callback shall be triggered after analytics (PGIE, Tracker or the last SGIE appearing in the pipeline) More info: create_common_elements()
all_bbox_generated_cb[IN]
perf_cb[IN]
overlay_graphics_cb[IN]
◆ destroy_pipeline()
void destroy_pipeline ( AppCtx appCtx)
◆ get_sensor_info()
NvDsSensorInfo* get_sensor_info ( AppCtx appCtx,
guint  source_id
Parameters
[in]appCtx[IN/OUT] The application context providing the config info and where the pipeline resources are maintained
[in]source_id[IN] The unique source_id found in NvDsFrameMeta
Returns
[transfer-floating] The NvDsSensorInfo for the source_id that was added using the nvmultiurisrcbin REST API. Please note that the returned pointer will be valid only until the stream is removed.
◆ parse_config_file()
gboolean parse_config_file ( NvDsConfig config,
gchar *  cfg_file_path
Parameters
[in]configpointer to NvDsConfig
[in]cfg_file_pathpath of configuration file.
Returns
true if parsed successfully.
◆ parse_config_file_yaml()
gboolean parse_config_file_yaml ( NvDsConfig config,
Parameters
Returns
◆ pause_pipeline()
gboolean pause_pipeline ( AppCtx appCtx)
◆ restart_pipeline()
void restart_pipeline ( AppCtx appCtx)
◆ resume_pipeline()
gboolean resume_pipeline ( AppCtx appCtx)
◆ seek_pipeline()
gboolean seek_pipeline ( AppCtx appCtx,
glong  milliseconds,
◆ toggle_show_bbox_text()
void toggle_show_bbox_text ( AppCtx appCtx)
