7.1 Release
Welcome
API Modules
Data Structures
Data Structures
Data Structure Index
Class Hierarchy
Data Fields
All
_
a
b
c
d
e
f
g
h
i
j
k
l
m
n
o
p
q
r
s
t
u
v
w
x
y
z
Functions
_
a
b
c
d
e
f
g
h
i
j
k
l
m
n
o
p
q
r
s
t
u
v
w
Variables
_
a
b
c
d
e
f
g
h
i
j
k
l
m
n
o
p
q
r
s
t
u
v
w
x
y
z
Typedefs
a
b
c
d
e
f
i
k
l
m
o
p
r
s
t
Enumerations
Enumerator
Related Functions
Files
File List
Globals
All
_
a
b
c
d
e
f
g
h
i
k
l
m
n
o
p
q
r
s
t
u
v
Functions
a
c
d
e
f
g
i
l
m
n
p
r
s
t
u
v
Variables
a
d
g
i
k
l
m
n
p
t
u
Typedefs
a
b
c
d
f
g
m
n
o
p
r
s
t
u
Enumerations
_
b
c
d
e
g
n
p
r
s
t
Enumerator
a
b
c
d
e
f
g
h
i
k
l
m
n
p
q
r
s
t
Macros
_
a
b
c
d
e
f
g
i
l
m
n
o
p
r
s
t
u
v
All
Data Structures
Namespaces
Files
Functions
Variables
Typedefs
Enumerations
Enumerator
Friends
Macros
Modules
Pages
deepstream_streammux.h
1
2
* SPDX-FileCopyrightText: Copyright (c) 2018-2024 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
3
* SPDX-License-Identifier: LicenseRef-NvidiaProprietary
4
5
* NVIDIA CORPORATION, its affiliates and licensors retain all intellectual
6
* property and proprietary rights in and to this material, related
7
* documentation and any modifications thereto. Any use, reproduction,
8
* disclosure or distribution of this material and related documentation
9
* without an express license agreement from NVIDIA CORPORATION or
10
* its affiliates is strictly prohibited.
11
12
13
#ifndef _NVGSTDS_STREAMMUX_H_
14
#define _NVGSTDS_STREAMMUX_H_
15
16
#include <gst/gst.h>
17
18
#ifdef __cplusplus
19
extern
"C"
20
21
#endif
22
23
typedef
struct
24
25
// Struct members to store config / properties for the element
26
gint
pipeline_width
27
gint
pipeline_height
28
gint
buffer_pool_size
29
gint
batch_size
30
gint
batched_push_timeout
31
gint
compute_hw
32
gint
num_surface_per_frame
33
gint
interpolation_method
34
guint64
frame_duration
35
guint
gpu_id
36
guint
nvbuf_memory_type
37
gboolean
live_source
38
gboolean
enable_padding
39
gboolean
is_parsed
40
gboolean
attach_sys_ts_as_ntp
41
gchar*
config_file_path
42
gboolean
sync_inputs
43
guint64
max_latency
44
gboolean
frame_num_reset_on_eos
45
gboolean
frame_num_reset_on_stream_reset
46
gboolean
async_process
47
gboolean
no_pipeline_eos
48
gboolean
use_nvmultiurisrcbin
49
gboolean
extract_sei_type5_data
50
NvDsStreammuxConfig
51
52
// Function to create the bin and set properties
53
gboolean
54
set_streammux_properties
NvDsStreammuxConfig
*config, GstElement *streammux);
55
56
#ifdef __cplusplus
57
58
#endif
59
60
#endif
/* _NVGSTDS_DSEXAMPLE_H_ */
NvDsStreammuxConfig::is_parsed
gboolean is_parsed
Definition:
deepstream_streammux.h:39
NvDsStreammuxConfig::interpolation_method
gint interpolation_method
Definition:
deepstream_streammux.h:33
NvDsStreammuxConfig::pipeline_height
gint pipeline_height
Definition:
deepstream_streammux.h:27
NvDsStreammuxConfig::num_surface_per_frame
gint num_surface_per_frame
Definition:
deepstream_streammux.h:32
gboolean set_streammux_properties(NvDsStreammuxConfig *config, GstElement *streammux)
NvDsStreammuxConfig::max_latency
guint64 max_latency
Definition:
deepstream_streammux.h:43
NvDsStreammuxConfig::use_nvmultiurisrcbin
gboolean use_nvmultiurisrcbin
Definition:
deepstream_streammux.h:48
NvDsStreammuxConfig::enable_padding
gboolean enable_padding
Definition:
deepstream_streammux.h:38
NvDsStreammuxConfig::live_source
gboolean live_source
Definition:
deepstream_streammux.h:37
NvDsStreammuxConfig::frame_duration
guint64 frame_duration
Definition:
deepstream_streammux.h:34
NvDsStreammuxConfig::async_process
gboolean async_process
Definition:
deepstream_streammux.h:46
NvDsStreammuxConfig::extract_sei_type5_data
gboolean extract_sei_type5_data
Definition:
deepstream_streammux.h:49
NvDsStreammuxConfig::batched_push_timeout
gint batched_push_timeout
Definition:
deepstream_streammux.h:30
NvDsStreammuxConfig::batch_size
gint batch_size
Definition:
deepstream_streammux.h:29
NvDsStreammuxConfig::no_pipeline_eos
gboolean no_pipeline_eos
Definition:
deepstream_streammux.h:47
NvDsStreammuxConfig
Definition:
deepstream_streammux.h:23
NvDsStreammuxConfig::frame_num_reset_on_eos
gboolean frame_num_reset_on_eos
Definition:
deepstream_streammux.h:44
NvDsStreammuxConfig::buffer_pool_size
gint buffer_pool_size
Definition:
deepstream_streammux.h:28
NvDsStreammuxConfig::nvbuf_memory_type
guint nvbuf_memory_type
Definition:
deepstream_streammux.h:36
NvDsStreammuxConfig::pipeline_width
gint pipeline_width
Definition:
deepstream_streammux.h:26
NvDsStreammuxConfig::frame_num_reset_on_stream_reset
gboolean frame_num_reset_on_stream_reset
Definition:
deepstream_streammux.h:45
NvDsStreammuxConfig::sync_inputs
gboolean sync_inputs
Definition:
deepstream_streammux.h:42
NvDsStreammuxConfig::config_file_path
gchar * config_file_path
Definition:
deepstream_streammux.h:41
NvDsStreammuxConfig::compute_hw
gint compute_hw
Definition:
deepstream_streammux.h:31
NvDsStreammuxConfig::attach_sys_ts_as_ntp
gboolean attach_sys_ts_as_ntp
Definition:
deepstream_streammux.h:40
NvDsStreammuxConfig::gpu_id
guint gpu_id
Definition:
deepstream_streammux.h:35
Advance Information | Subject to Change | Generated by NVIDIA | Mon Oct 14 2024 13:27:43 | PR-09318-R32
