Functions | |
| void | drawBoundingBox_cuda_unit_alpha (uint8_t *pBGRA, const int nWidth, const int nHeight, const int nBgraPitch, const int x_min, const int y_min, const int x_max, const int y_max, cudaStream_t stream, unsigned int r, unsigned int g, unsigned int b, unsigned int border_width) |
| void | drawBoundingBox_cuda (uint8_t *pBGRA, const int nWidth, const int nHeight, const int nBgraPitch, const int x_min, const int y_min, const int x_max, const int y_max, cudaStream_t stream, unsigned int r, unsigned int g, unsigned int b, float a, unsigned int border_width) |
| void | bboxAlphaFill_cuda (uint8_t *pBGRA, const int nWidth, const int nHeight, const int nBgraPitch, const int x_min, const int y_min, const int x_max, const int y_max, unsigned int r, unsigned int g, unsigned int b, float a, cudaStream_t stream) |
| void | bgra_to_gray (uint8_t *dpBgra, const int nBgraPitch, uint8_t *dpGray, const int nGrayPitch, const int nWidth, const int nHeight, cudaStream_t stream) |
| void | nv12_to_gray_batch (const uint8_t *pNv12, int nNv12Pitch, uint8_t *pGray, int nGrayPitch, int nWidth, int nHeight, int nBatchSize, cudaStream_t stream) |
| void bboxAlphaFill_cuda | ( | uint8_t * | pBGRA, |
| const int | nWidth, | ||
| const int | nHeight, | ||
| const int | nBgraPitch, | ||
| const int | x_min, | ||
| const int | y_min, | ||
| const int | x_max, | ||
| const int | y_max, | ||
| unsigned int | r, | ||
| unsigned int | g, | ||
| unsigned int | b, | ||
| float | a, | ||
| cudaStream_t | stream | ||
| void bgra_to_gray | ( | uint8_t * | dpBgra, |
| uint8_t * | dpGray, | ||
| const int | nGrayPitch, | ||
| void drawBoundingBox_cuda | ( | uint8_t * | pBGRA, |
| cudaStream_t | stream, | ||
| float | a, | ||
| unsigned int | border_width | ||
| void drawBoundingBox_cuda_unit_alpha | ( | uint8_t * | pBGRA, |
| void nv12_to_gray_batch | ( | const uint8_t * | pNv12, |
| int | nNv12Pitch, | ||
| uint8_t * | pGray, | ||
| int | nWidth, | ||
| int | nHeight, | ||
| int | nBatchSize, | ||
