NvBufSurfTransform Interface
This file specifies the NvBufSurfTransform image transformation APIs.
The NvBufSurfTransform API provides methods to set and get session parameters and to transform and composite APIs.
Definition in file nvbufsurftransform.h.
Data Structures | |
| struct | NvBufSurfTransformRect |
| Holds the coordinates of a rectangle. More... | |
| struct | _NvBufSurfTransformConfigParams |
| Holds configuration parameters for a transform/composite session. More... | |
| struct | _NvBufSurfaceTransformParams |
| Holds transform parameters for a transform call. More... | |
| struct | _NvBufSurfTransformCompositeParams |
| Holds composite parameters for a composite call. More... | |
| struct | _NvBufSurfTransform_ColorParams |
| struct | _NvBufSurfTransformCompositeBlendParams |
| Holds composite blend parameters for a composite blender call. More... | |
| struct | _NvBufSurfTransformCompositeBlendParamsEx |
| Holds extended composite blend parameters for NvBufSurfTransformMultiInputBufCompositeBlend and NvBufSurfTransformMultiInputBufCompositeBlendAsync API. More... | |
Macros | |
| #define | NVBUFSURF_MAX_SYNCOBJ 5 |
| Defines the maximum number of sync objects. More... | |
Typedefs | |
| typedef struct CUstream_st * | cudaStream_t |
| Forward declaration of cudaStream_t. More... | |
| typedef struct _NvBufSurfTransformConfigParams | NvBufSurfTransformConfigParams |
| typedef struct _NvBufSurfaceTransformParams | NvBufSurfTransformParams |
| typedef struct _NvBufSurfTransformCompositeParams | NvBufSurfTransformCompositeParams |
| typedef struct _NvBufSurfTransform_ColorParams | NvBufSurfTransform_ColorParams |
| typedef struct _NvBufSurfTransformCompositeBlendParams | NvBufSurfTransformCompositeBlendParams |
| typedef struct _NvBufSurfTransformCompositeBlendParamsEx | NvBufSurfTransformCompositeBlendParamsEx |
| typedef struct NvBufSurfTransformSyncObj * | NvBufSurfTransformSyncObj_t |
| Holds the information about synchronization objects for asynchronous transform/composite APIs. More... | |
| #define NVBUFSURF_MAX_SYNCOBJ 5 |
Definition at line 33 of file nvbufsurftransform.h.
| typedef struct CUstream_st* cudaStream_t |
Definition at line 35 of file nvbufsurftransform.h.
