7.1 Release
server_appctx DeepStream Yaml Parser API
Defines an API for the GStreamer REST Application Server context.
Data Structures
struct  AppCtx
 REST server application context. More...
Functions
NvDsYamlParserStatus nvds_parse_server_appctx (gchar *cfg_file_path, const char *group, AppCtx *appctx)
 Set AppCtx from values specified in a YAML configuration file. More...
NvDsYamlParserStatus nvds_parse_check_rest_server_with_app (gchar *cfg_file_path, const char *group, gboolean *within_multiurisrcbin)
 Set "within_multiurisrcbin" varible from values specified in a YAML configuration file. More...
Function Documentation
◆ nvds_parse_check_rest_server_with_app()
NvDsYamlParserStatus nvds_parse_check_rest_server_with_app ( gchar *  cfg_file_path,
const char *  group,
gboolean *  within_multiurisrcbin
Parameters
[in]cfg_file_pathThe YAML config file used by an application.
[in]groupGroup in the YAML config file to be parsed and application context values to be updated.
[in]within_multiurisrcbinThe boolean variable updated as per the parameter key(s) values defined in the group. If True, nvds_rest_server library is to be used directly.
Returns
Yaml parsing status for the API call.
◆ nvds_parse_server_appctx()
NvDsYamlParserStatus nvds_parse_server_appctx ( gchar *  cfg_file_path,
const char *  group,
AppCtx appctx
Parameters
[in]appctxThe context which gets updated as per the parameter key(s) values defined in the group
Returns
