8.0 Release
gst-nvdssr.h File Reference
NVIDIA DeepStream: Smart recording API
Definition in file gst-nvdssr.h.
Data Structures
struct  NvDsSRInitParams
 Holds initializtion paramerters required to create NvDsSRContext. More...
struct  NvDsSRContext
 Holds information about smart record instance. More...
struct  NvDsSRRecordingInfo
 Hold information about video recorded. More...
Macros
#define _DS_DEPRECATED_(STR)   __attribute__ ((deprecated (STR)))
Typedefs
typedef struct NvDsSRRecordingInfo NvDsSRRecordingInfo
typedef gpointer(* NvDsSRCallbackFunc) (NvDsSRRecordingInfo *info, gpointer userData)
typedef guint32 NvDsSRSessionId
typedef struct NvDsSRInitParams NvDsSRInitParams
typedef struct NvDsSRContext NvDsSRContext
Enumerations
enum  NvDsSRContainerType {
  NVDSSR_CONTAINER_MP4,
  NVDSSR_CONTAINER_MKV
 Specifies container types. More...
enum  NvDsSRStatus {
  NVDSSR_STATUS_OK,
  NVDSSR_STATUS_INVALID_VAL,
  NVDSSR_STATUS_INVALID_OP,
  NVDSSR_STATUS_ERROR,
  NVDSSR_STATUS_CUSTOM1 = 100,
  NVDSSR_STATUS_CUSTOM2 = 101,
  NVDSSR_STATUS_CUSTOM3 = 102
 Specifies API return status. More...
Functions
NvDsSRStatus NvDsSRCreate (NvDsSRContext **ctx, NvDsSRInitParams *params)
 Creates the instance of smart record. More...
NvDsSRStatus NvDsSRStart (NvDsSRContext *ctx, NvDsSRSessionId *sessionId, guint startTime, guint duration, gpointer userData)
 Starts the video recording. More...
NvDsSRStatus NvDsSRStop (NvDsSRContext *ctx, NvDsSRSessionId sessionId)
 Stops the previously started recording. More...
NvDsSRStatus NvDsSRDestroy (NvDsSRContext *ctx)
 Destroys the instance of smart record. More...
◆ _DS_DEPRECATED_
#define _DS_DEPRECATED_ (   STR)    __attribute__ ((deprecated (STR)))
Definition at line 29 of file gst-nvdssr.h.
