8.0 Release
gst-nvquery-internal.h File Reference
Data Structures
struct  _NtpData
Functions
GstQuery * gst_nvquery_nppstream_new (void)
gboolean gst_nvquery_is_nppstream (GstQuery *query)
void gst_nvquery_nppstream_set (GstQuery *query, gpointer cudastream)
gboolean gst_nvquery_nppstream_parse (GstQuery *query, gpointer cudastreamptr)
GstQuery * gst_nvquery_resolution_new (void)
gboolean gst_nvquery_is_resolution (GstQuery *query)
void gst_nvquery_resolution_set (GstQuery *query, guint width, guint height)
gboolean gst_nvquery_resolution_parse (GstQuery *query, guint *width, guint *height)
GstQuery * gst_nvquery_stream_caps_new (guint streamId)
gboolean gst_nvquery_is_stream_caps (GstQuery *query)
void gst_nvquery_stream_caps_set (GstQuery *query, GstCaps *caps)
gboolean gst_nvquery_stream_caps_parse_streamid (GstQuery *query, guint *streamid)
gboolean gst_nvquery_stream_caps_parse (GstQuery *query, GstStructure **str)
GstQuery * gst_nvquery_num_surfaces_per_buffer_new (void)
gboolean gst_nvquery_is_num_surfaces_per_buffer (GstQuery *query)
void gst_nvquery_num_surfaces_per_buffer_set (GstQuery *query, guint num_surfaces_per_buffers)
gboolean gst_nvquery_num_surfaces_per_buffer_parse (GstQuery *query, guint *num_surfaces_per_buffers)
GstQuery * gst_nvquery_ntp_sync_new (void)
gboolean gst_nvquery_is_ntp_sync (GstQuery *query)
gboolean gst_nvquery_ntp_sync_parse (GstQuery *query, _NtpData *ntp_data)
void gst_nvquery_ntp_sync_set (GstQuery *query, _NtpData *ntp_data)
GstQuery * gst_nvquery_uri_from_streamid_new (guint streamid)
gboolean gst_nvquery_is_uri_from_streamid (GstQuery *query)
void gst_nvquery_uri_from_streamid_set (GstQuery *query, const gchar *uri)
gboolean gst_nvquery_uri_from_streamid_parse (GstQuery *query, const gchar **uri)
gboolean gst_nvquery_uri_from_streamid_parse_streamid (GstQuery *query, guint *streamid)
GstQuery * gst_nvquery_sourceid_new (void)
gboolean gst_nvquery_is_sourceid (GstQuery *query)
gboolean gst_nvquery_sourceid_parse (GstQuery *query, guint *sourceid)
void gst_nvquery_sourceid_set (GstQuery *query, guint sourceid)
Function Documentation
◆ gst_nvquery_is_nppstream()
gboolean gst_nvquery_is_nppstream ( GstQuery *  query)
◆ gst_nvquery_is_ntp_sync()
gboolean gst_nvquery_is_ntp_sync ( GstQuery *  query)
◆ gst_nvquery_is_num_surfaces_per_buffer()
gboolean gst_nvquery_is_num_surfaces_per_buffer ( GstQuery *  query)
◆ gst_nvquery_is_resolution()
gboolean gst_nvquery_is_resolution ( GstQuery *  query)
◆ gst_nvquery_is_sourceid()
gboolean gst_nvquery_is_sourceid ( GstQuery *  query)
◆ gst_nvquery_is_stream_caps()
gboolean gst_nvquery_is_stream_caps ( GstQuery *  query)
◆ gst_nvquery_is_uri_from_streamid()
gboolean gst_nvquery_is_uri_from_streamid ( GstQuery *  query)
◆ gst_nvquery_nppstream_new()
GstQuery* gst_nvquery_nppstream_new ( void  )
◆ gst_nvquery_nppstream_parse()
gboolean gst_nvquery_nppstream_parse ( GstQuery *  query,
◆ gst_nvquery_nppstream_set()
void gst_nvquery_nppstream_set ( GstQuery *  query,
gpointer  cudastream
◆ gst_nvquery_ntp_sync_new()
GstQuery* gst_nvquery_ntp_sync_new ( void  )
◆ gst_nvquery_ntp_sync_parse()
gboolean gst_nvquery_ntp_sync_parse ( GstQuery *  query,
_NtpData ntp_data
◆ gst_nvquery_ntp_sync_set()
void gst_nvquery_ntp_sync_set ( GstQuery *  query,
_NtpData ntp_data
◆ gst_nvquery_num_surfaces_per_buffer_new()
GstQuery* gst_nvquery_num_surfaces_per_buffer_new ( void  )
◆ gst_nvquery_num_surfaces_per_buffer_parse()
gboolean gst_nvquery_num_surfaces_per_buffer_parse ( GstQuery *  query,
guint *  num_surfaces_per_buffers
◆ gst_nvquery_num_surfaces_per_buffer_set()
void gst_nvquery_num_surfaces_per_buffer_set ( GstQuery *  query,
◆ gst_nvquery_resolution_new()
GstQuery* gst_nvquery_resolution_new ( void  )
◆ gst_nvquery_resolution_parse()
gboolean gst_nvquery_resolution_parse ( GstQuery *  query,
guint *  width,
guint *  height
◆ gst_nvquery_resolution_set()
void gst_nvquery_resolution_set ( GstQuery *  query,
guint  width,
guint  height
◆ gst_nvquery_sourceid_new()
GstQuery* gst_nvquery_sourceid_new ( void  )
◆ gst_nvquery_sourceid_parse()
gboolean gst_nvquery_sourceid_parse ( GstQuery *  query,
guint *  sourceid
◆ gst_nvquery_sourceid_set()
void gst_nvquery_sourceid_set ( GstQuery *  query,
guint  sourceid
◆ gst_nvquery_stream_caps_new()
GstQuery* gst_nvquery_stream_caps_new ( guint  streamId)
◆ gst_nvquery_stream_caps_parse()
gboolean gst_nvquery_stream_caps_parse ( GstQuery *  query,
GstStructure **  str
◆ gst_nvquery_stream_caps_parse_streamid()
gboolean gst_nvquery_stream_caps_parse_streamid ( GstQuery *  query,
guint *  streamid
◆ gst_nvquery_stream_caps_set()
void gst_nvquery_stream_caps_set ( GstQuery *  query,
GstCaps *  caps
◆ gst_nvquery_uri_from_streamid_new()
GstQuery* gst_nvquery_uri_from_streamid_new ( guint  streamid)
◆ gst_nvquery_uri_from_streamid_parse()
gboolean gst_nvquery_uri_from_streamid_parse ( GstQuery *  query,
const gchar **  uri
◆ gst_nvquery_uri_from_streamid_parse_streamid()
gboolean gst_nvquery_uri_from_streamid_parse_streamid ( GstQuery *  query,
guint *  streamid
◆ gst_nvquery_uri_from_streamid_set()
void gst_nvquery_uri_from_streamid_set ( GstQuery *  query,
const gchar *  uri
