8.0 Release
13 #ifndef __GST_NVQUERY_INT_H__
14 #define __GST_NVQUERY_INT_H__
GstQuery * gst_nvquery_uri_from_streamid_new(guint streamid)
GstClockTime avg_frame_time
gboolean gst_nvquery_stream_caps_parse_streamid(GstQuery *query, guint *streamid)
gboolean gst_nvquery_num_surfaces_per_buffer_parse(GstQuery *query, guint *num_surfaces_per_buffers)
void gst_nvquery_stream_caps_set(GstQuery *query, GstCaps *caps)
void gst_nvquery_nppstream_set(GstQuery *query, gpointer cudastream)
void gst_nvquery_resolution_set(GstQuery *query, guint width, guint height)
gboolean gst_nvquery_sourceid_parse(GstQuery *query, guint *sourceid)
void gst_nvquery_sourceid_set(GstQuery *query, guint sourceid)
void gst_nvquery_uri_from_streamid_set(GstQuery *query, const gchar *uri)
GstQuery * gst_nvquery_resolution_new(void)
gboolean gst_nvquery_resolution_parse(GstQuery *query, guint *width, guint *height)
void gst_nvquery_ntp_sync_set(GstQuery *query, _NtpData *ntp_data)
gboolean gst_nvquery_stream_caps_parse(GstQuery *query, GstStructure **str)
GstQuery * gst_nvquery_num_surfaces_per_buffer_new(void)
GstClockTime ntp_time_epoch_ns
GstQuery * gst_nvquery_ntp_sync_new(void)
gboolean gst_nvquery_is_resolution(GstQuery *query)
gboolean gst_nvquery_is_stream_caps(GstQuery *query)
gboolean gst_nvquery_is_ntp_sync(GstQuery *query)
GstQuery * gst_nvquery_nppstream_new(void)
void gst_nvquery_num_surfaces_per_buffer_set(GstQuery *query, guint num_surfaces_per_buffers)
gboolean gst_nvquery_is_sourceid(GstQuery *query)
gboolean gst_nvquery_is_num_surfaces_per_buffer(GstQuery *query)
gboolean gst_nvquery_is_nppstream(GstQuery *query)
gboolean gst_nvquery_uri_from_streamid_parse(GstQuery *query, const gchar **uri)
GstQuery * gst_nvquery_stream_caps_new(guint streamId)
GstQuery * gst_nvquery_sourceid_new(void)
gboolean gst_nvquery_nppstream_parse(GstQuery *query, gpointer cudastreamptr)
gboolean gst_nvquery_ntp_sync_parse(GstQuery *query, _NtpData *ntp_data)
GstClockTime frame_timestamp
gboolean gst_nvquery_is_uri_from_streamid(GstQuery *query)
gboolean gst_nvquery_uri_from_streamid_parse_streamid(GstQuery *query, guint *streamid)
