Data Structures | |
| struct | _GstDsExample |
| struct | _GstDsExampleClass |
| Boiler plate stuff. More... | |
Macros | |
| #define | PACKAGE "dsexample" |
| #define | VERSION "1.0" |
| #define | LICENSE "Proprietary" |
| #define | DESCRIPTION "NVIDIA example plugin for integration with DeepStream on DGPU" |
| #define | BINARY_PACKAGE "NVIDIA DeepStream 3rdparty IP integration example plugin" |
| #define | URL "http://nvidia.com/" |
| #define | GST_TYPE_DSEXAMPLE (gst_dsexample_get_type()) |
| #define | GST_DSEXAMPLE(obj) (G_TYPE_CHECK_INSTANCE_CAST((obj),GST_TYPE_DSEXAMPLE,GstDsExample)) |
| #define | GST_DSEXAMPLE_CLASS(klass) (G_TYPE_CHECK_CLASS_CAST((klass),GST_TYPE_DSEXAMPLE,GstDsExampleClass)) |
| #define | GST_DSEXAMPLE_GET_CLASS(obj) (G_TYPE_INSTANCE_GET_CLASS((obj), GST_TYPE_DSEXAMPLE, GstDsExampleClass)) |
| #define | GST_IS_DSEXAMPLE(obj) (G_TYPE_CHECK_INSTANCE_TYPE((obj),GST_TYPE_DSEXAMPLE)) |
| #define | GST_IS_DSEXAMPLE_CLASS(klass) (G_TYPE_CHECK_CLASS_TYPE((klass),GST_TYPE_DSEXAMPLE)) |
| #define | GST_DSEXAMPLE_CAST(obj) ((GstDsExample *)(obj)) |
| #define | NVDSEXAMPLE_MAX_BATCH_SIZE 1024 |
| Maximum batch size to be supported by dsexample. More... | |
Typedefs | |
| typedef typedefG_BEGIN_DECLS struct _GstDsExample | GstDsExample |
| typedef struct _GstDsExampleClass | GstDsExampleClass |
Functions | |
| GType | gst_dsexample_get_type (void) |
| #define BINARY_PACKAGE "NVIDIA DeepStream 3rdparty IP integration example plugin" |
Definition at line 46 of file gstdsexample_cuda.h.
| #define DESCRIPTION "NVIDIA example plugin for integration with DeepStream on DGPU" |
Definition at line 45 of file gstdsexample_cuda.h.
| #define GST_DSEXAMPLE | ( | obj | ) | (G_TYPE_CHECK_INSTANCE_CAST((obj),GST_TYPE_DSEXAMPLE,GstDsExample)) |
Definition at line 57 of file gstdsexample_cuda.h.
| #define GST_DSEXAMPLE_CAST | ( | obj | ) | ((GstDsExample *)(obj)) |
Definition at line 62 of file gstdsexample_cuda.h.
| #define GST_DSEXAMPLE_CLASS | ( | klass | ) | (G_TYPE_CHECK_CLASS_CAST((klass),GST_TYPE_DSEXAMPLE,GstDsExampleClass)) |
Definition at line 58 of file gstdsexample_cuda.h.
| #define GST_DSEXAMPLE_GET_CLASS | ( | obj | ) | (G_TYPE_INSTANCE_GET_CLASS((obj), GST_TYPE_DSEXAMPLE, GstDsExampleClass)) |
Definition at line 59 of file gstdsexample_cuda.h.
| #define GST_IS_DSEXAMPLE | ( | obj | ) | (G_TYPE_CHECK_INSTANCE_TYPE((obj),GST_TYPE_DSEXAMPLE)) |
Definition at line 60 of file gstdsexample_cuda.h.
| #define GST_IS_DSEXAMPLE_CLASS | ( | klass | ) | (G_TYPE_CHECK_CLASS_TYPE((klass),GST_TYPE_DSEXAMPLE)) |
Definition at line 61 of file gstdsexample_cuda.h.
| #define GST_TYPE_DSEXAMPLE (gst_dsexample_get_type()) |
Definition at line 56 of file gstdsexample_cuda.h.
| #define LICENSE "Proprietary" |
Definition at line 44 of file gstdsexample_cuda.h.
| #define NVDSEXAMPLE_MAX_BATCH_SIZE 1024 |
Definition at line 65 of file gstdsexample_cuda.h.
| #define PACKAGE "dsexample" |
Definition at line 42 of file gstdsexample_cuda.h.
| #define URL "http://nvidia.com/" |
Definition at line 47 of file gstdsexample_cuda.h.
| #define VERSION "1.0" |
Definition at line 43 of file gstdsexample_cuda.h.
| typedef typedefG_BEGIN_DECLS struct _GstDsExample GstDsExample |
Definition at line 52 of file gstdsexample_cuda.h.
| typedef struct _GstDsExampleClass GstDsExampleClass |
Definition at line 53 of file gstdsexample_cuda.h.
| GType gst_dsexample_get_type | ( | void | ) |
