7.1 Release
gstnvdsbufferpool.h File Reference
Data Structures
struct  _GstNvDsBufferPool
struct  _GstNvDsBufferPoolClass
Macros
#define GST_TYPE_NVDS_BUFFER_POOL   (gst_nvds_buffer_pool_get_type())
#define GST_IS_NVDS_BUFFER_POOL(obj)   (G_TYPE_CHECK_INSTANCE_TYPE ((obj), GST_TYPE_NVDS_BUFFER_POOL))
#define GST_NVDS_BUFFER_POOL(obj)   (G_TYPE_CHECK_INSTANCE_CAST ((obj), GST_TYPE_NVDS_BUFFER_POOL, GstNvDsBufferPool))
#define GST_NVDS_BUFFER_POOL_CAST(obj)   ((GstNvDsBufferPool*)(obj))
#define GST_NVDS_MEMORY_TYPE   "nvds"
#define GST_BUFFER_POOL_OPTION_NVDS_META   "GstBufferPoolOptionNvDsMeta"
Typedefs
typedef typedefG_BEGIN_DECLS struct _GstNvDsBufferPool GstNvDsBufferPool
typedef struct _GstNvDsBufferPoolClass GstNvDsBufferPoolClass
typedef struct _GstNvDsBufferPoolPrivate GstNvDsBufferPoolPrivate
Functions
GType gst_nvds_buffer_pool_get_type (void)
GstBufferPool * gst_nvds_buffer_pool_new (void)
◆ GST_BUFFER_POOL_OPTION_NVDS_META
Definition at line 46 of file gstnvdsbufferpool.h.
◆ GST_IS_NVDS_BUFFER_POOL
#define GST_IS_NVDS_BUFFER_POOL (   obj)    (G_TYPE_CHECK_INSTANCE_TYPE ((obj), GST_TYPE_NVDS_BUFFER_POOL))
Definition at line 41 of file gstnvdsbufferpool.h.
◆ GST_NVDS_BUFFER_POOL
#define GST_NVDS_BUFFER_POOL (   obj)    (G_TYPE_CHECK_INSTANCE_CAST ((obj), GST_TYPE_NVDS_BUFFER_POOL, GstNvDsBufferPool))
Definition at line 42 of file gstnvdsbufferpool.h.
◆ GST_NVDS_BUFFER_POOL_CAST
#define GST_NVDS_BUFFER_POOL_CAST (   obj)    ((GstNvDsBufferPool*)(obj))
Definition at line 43 of file gstnvdsbufferpool.h.
◆ GST_NVDS_MEMORY_TYPE
Definition at line 45 of file gstnvdsbufferpool.h.
◆ GST_TYPE_NVDS_BUFFER_POOL
Definition at line 40 of file gstnvdsbufferpool.h.
Typedef Documentation
◆ GstNvDsBufferPool
Definition at line 36 of file gstnvdsbufferpool.h.
◆ GstNvDsBufferPoolClass
Definition at line 37 of file gstnvdsbufferpool.h.
◆ GstNvDsBufferPoolPrivate
Definition at line 38 of file gstnvdsbufferpool.h.
Function Documentation
◆ gst_nvds_buffer_pool_get_type()
GType gst_nvds_buffer_pool_get_type ( void  )
◆ gst_nvds_buffer_pool_new()
GstBufferPool* gst_nvds_buffer_pool_new ( void  )
