8.0 Release
gstnvdsbufferpool.h
1 /*
2  * Copyright (c) 2019-2020, NVIDIA CORPORATION. All rights reserved.
3  *
4  * Redistribution and use in source and binary forms, with or without
5  * modification, are permitted provided that the following conditions
6  * are met:
7  * * Redistributions of source code must retain the above copyright
8  * notice, this list of conditions and the following disclaimer.
9  * * Redistributions in binary form must reproduce the above copyright
10  * notice, this list of conditions and the following disclaimer in the
11  * documentation and/or other materials provided with the distribution.
12  * * Neither the name of NVIDIA CORPORATION nor the names of its
13  * contributors may be used to endorse or promote products derived
14  * from this software without specific prior written permission.
15  *
16  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS ``AS IS'' AND ANY
17  * EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
18  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
19  * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
20  * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
21  * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
22  * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
23  * PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
24  * OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
25  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
26  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
27  */
28
29 #ifndef GSTNVDSBUFFERPOOL_H_
30 #define GSTNVDSBUFFERPOOL_H_
31
32 #include <gst/gst.h>
33
34 G_BEGIN_DECLS
35
38 typedef struct _GstNvDsBufferPoolPrivate GstNvDsBufferPoolPrivate;
39
40 #define GST_TYPE_NVDS_BUFFER_POOL (gst_nvds_buffer_pool_get_type())
41 #define GST_IS_NVDS_BUFFER_POOL(obj) (G_TYPE_CHECK_INSTANCE_TYPE ((obj), GST_TYPE_NVDS_BUFFER_POOL))
42 #define GST_NVDS_BUFFER_POOL(obj) (G_TYPE_CHECK_INSTANCE_CAST ((obj), GST_TYPE_NVDS_BUFFER_POOL, GstNvDsBufferPool))
43 #define GST_NVDS_BUFFER_POOL_CAST(obj) ((GstNvDsBufferPool*)(obj))
44
45 #define GST_NVDS_MEMORY_TYPE "nvds"
46 #define GST_BUFFER_POOL_OPTION_NVDS_META "GstBufferPoolOptionNvDsMeta"
47
49 {
50  GstBufferPool bufferpool;
51
53 };
54
56 {
57  GstBufferPoolClass parent_class;
58 };
59
61
62 GstBufferPool* gst_nvds_buffer_pool_new (void);
63
64 G_END_DECLS
65
66 #endif /* GSTNVDSBUFFERPOOL_H_ */
_GstNvDsBufferPool
Definition: gstnvdsbufferpool.h:48
Definition: gstnvdsbufferpool.h:38
GstNvDsBufferPool
typedefG_BEGIN_DECLS struct _GstNvDsBufferPool GstNvDsBufferPool
Definition: gstnvdsbufferpool.h:36
GstBufferPool * gst_nvds_buffer_pool_new(void)
GType gst_nvds_buffer_pool_get_type(void)
_GstNvDsBufferPool::bufferpool
Definition: gstnvdsbufferpool.h:50
_GstNvDsBufferPoolClass
Definition: gstnvdsbufferpool.h:55
_GstNvDsBufferPool::priv
GstNvDsBufferPoolPrivate * priv
Definition: gstnvdsbufferpool.h:52
_GstNvDsBufferPoolClass::parent_class
Definition: gstnvdsbufferpool.h:57
