8.0 Release
gstnvinfer_allocator.h File Reference
Data Structures
struct  GstNvInferMemory
 This file describes the custom memory allocator for the Gstreamer TensorRT plugin. More...
Functions
GstNvInferMemorygst_nvinfer_buffer_get_memory (GstBuffer *buffer)
 Get GstNvInferMemory structure associated with buffer allocated using GstNvInferAllocator. More...
GstAllocator * gst_nvinfer_allocator_new (guint width, guint height, NvBufSurfaceColorFormat color_format, guint batch_size, guint gpu_id)
 Create a new GstNvInferAllocator with the given parameters. More...
Function Documentation
◆ gst_nvinfer_allocator_new()
GstAllocator* gst_nvinfer_allocator_new ( guint  width,
guint  height,
guint  batch_size,
guint  gpu_id
Parameters
widthWidth of the network input, in pixels.
heightHeight of the network input, in pixels.
color_formatColor format of the buffers in the pool.
batch_sizeMax size of batch that will be inferred.
gpu_idID of the gpu where the batch memory will be allocated.
Returns
Pointer to the GstNvInferAllocator structure cast as GstAllocator
◆ gst_nvinfer_buffer_get_memory()
GstNvInferMemory* gst_nvinfer_buffer_get_memory ( GstBuffer buffer)
Parameters
bufferGstBuffer allocated by this allocator.
Returns
Pointer to the associated GstNvInferMemory structure
