7.1 Release
gstnvstreammux.h File Reference
Data Structures
struct  _GstNvStreamMux
struct  _GstNvStreamMuxClass
Macros
#define GST_TYPE_NVSTREAMMUX   (gst_nvstreammux_2_get_type ())
#define GST_NVSTREAMMUX(obj)   (G_TYPE_CHECK_INSTANCE_CAST((obj),GST_TYPE_NVSTREAMMUX,GstNvStreamMux))
#define GST_NVSTREAMMUX_CLASS(klass)   (G_TYPE_CHECK_CLASS_CAST((klass),GST_TYPE_NVSTREAMMUX,GstNvStreamMuxClass))
#define GST_IS_NVSTREAMMUX(obj)   (G_TYPE_CHECK_INSTANCE_TYPE((obj),GST_TYPE_NVSTREAMMUX))
#define GST_IS_NVSTREAMMUX_CLASS(klass)   (G_TYPE_CHECK_CLASS_TYPE((klass),GST_TYPE_NVSTREAMMUX))
#define NEW_METADATA   1
Typedefs
typedef struct _GstNvStreamMux GstNvStreamMux
typedef struct _GstNvStreamMuxClass GstNvStreamMuxClass
Functions
G_GNUC_INTERNAL GType gst_nvstreammux_2_get_type (void)
◆ GST_IS_NVSTREAMMUX
#define GST_IS_NVSTREAMMUX (   obj)    (G_TYPE_CHECK_INSTANCE_TYPE((obj),GST_TYPE_NVSTREAMMUX))
Definition at line 34 of file gstnvstreammux.h.
◆ GST_IS_NVSTREAMMUX_CLASS
#define GST_IS_NVSTREAMMUX_CLASS (   klass)    (G_TYPE_CHECK_CLASS_TYPE((klass),GST_TYPE_NVSTREAMMUX))
Definition at line 36 of file gstnvstreammux.h.
◆ GST_NVSTREAMMUX
#define GST_NVSTREAMMUX (   obj)    (G_TYPE_CHECK_INSTANCE_CAST((obj),GST_TYPE_NVSTREAMMUX,GstNvStreamMux))
Definition at line 30 of file gstnvstreammux.h.
◆ GST_NVSTREAMMUX_CLASS
#define GST_NVSTREAMMUX_CLASS (   klass)    (G_TYPE_CHECK_CLASS_CAST((klass),GST_TYPE_NVSTREAMMUX,GstNvStreamMuxClass))
Definition at line 32 of file gstnvstreammux.h.
◆ GST_TYPE_NVSTREAMMUX
Definition at line 28 of file gstnvstreammux.h.
◆ NEW_METADATA
Definition at line 40 of file gstnvstreammux.h.
Typedef Documentation
◆ GstNvStreamMux
Definition at line 38 of file gstnvstreammux.h.
◆ GstNvStreamMuxClass
Definition at line 39 of file gstnvstreammux.h.
Function Documentation
◆ gst_nvstreammux_2_get_type()
G_GNUC_INTERNAL GType gst_nvstreammux_2_get_type ( void  )
