7.1 Release
_GstNvStreamMux Struct Reference
Definition at line 42 of file gstnvstreammux.h.
Collaboration diagram for _GstNvStreamMux:
Data Fields
GstElement element
GstPad * srcpad
GstSegment segment
GstFlowReturn last_flow_ret
unsigned int width
unsigned int height
NvStreamMuxhelper
bool send_eos
bool eos_sent
bool all_pads_eos
gboolean query_resolution
unsigned int batch_size
gint timeout_usec
GstVideoInfo out_videoinfo
unsigned int num_surfaces_per_frame
bool pad_task_created
gulong frame_duration_nsec
gulong cur_frame_pts
GstClockTime pts_offset
gchar * config_file_path
 Path to the configuration file for this instance of gst-nvstreammux. More...
gboolean config_file_available
 boolean TRUE if a new config_file_path setting is available More...
gboolean config_file_parse_successful
 Boolean indicating if the config parsing was successful. More...
gboolean module_initialized
gboolean segment_sent
guint num_sink_pads
gboolean isAudio
 Audio support. More...
GstNvStreamMuxCtxmuxCtx
 muxer context More...
gboolean sys_ts
 property that specifies if the ntp timestamp is from rtspsrc or system More...
GstNvDsNtpCalculatorMode ntp_calc_mode
GHashTable * sink_pad_caps
gboolean sync_inputs
 whether input buffer synchronization is turned ON/OFF More...
GstClockTime max_latency
GstClockTime prev_outbuf_pts
NvTimeSyncsynch_buffer
GstClockTime peer_latency_min
GstClockTime peer_latency_max
gboolean peer_latency_live
gboolean has_peer_latency
GMutex ctx_lock
gboolean frame_num_reset_on_eos
gboolean frame_num_reset_on_stream_reset
GstClockTime frame_duration
 Application specified frame duration used for NTP timestamp calculaion. More...
bool pushed_stream_start_once
gboolean no_pipeline_eos
INvStreammuxDebugdebug_iface
Field Documentation
◆ all_pads_eos
bool _GstNvStreamMux::all_pads_eos
Definition at line 63 of file gstnvstreammux.h.
◆ batch_size
unsigned int _GstNvStreamMux::batch_size
Definition at line 67 of file gstnvstreammux.h.
◆ config_file_available
gboolean _GstNvStreamMux::config_file_available
Definition at line 84 of file gstnvstreammux.h.
◆ config_file_parse_successful
gboolean _GstNvStreamMux::config_file_parse_successful
Definition at line 87 of file gstnvstreammux.h.
◆ config_file_path
gchar* _GstNvStreamMux::config_file_path
Definition at line 82 of file gstnvstreammux.h.
◆ ctx_lock
GMutex _GstNvStreamMux::ctx_lock
Definition at line 119 of file gstnvstreammux.h.
◆ cur_frame_pts
gulong _GstNvStreamMux::cur_frame_pts
Definition at line 78 of file gstnvstreammux.h.
◆ debug_iface
INvStreammuxDebug* _GstNvStreamMux::debug_iface
Definition at line 128 of file gstnvstreammux.h.
◆ element
GstElement _GstNvStreamMux::element
Definition at line 44 of file gstnvstreammux.h.
◆ eos_sent
bool _GstNvStreamMux::eos_sent
Definition at line 61 of file gstnvstreammux.h.
◆ frame_duration
GstClockTime _GstNvStreamMux::frame_duration
Definition at line 124 of file gstnvstreammux.h.
◆ frame_duration_nsec
gulong _GstNvStreamMux::frame_duration_nsec
Definition at line 76 of file gstnvstreammux.h.
◆ frame_num_reset_on_eos
gboolean _GstNvStreamMux::frame_num_reset_on_eos
Definition at line 121 of file gstnvstreammux.h.
◆ frame_num_reset_on_stream_reset
gboolean _GstNvStreamMux::frame_num_reset_on_stream_reset
Definition at line 122 of file gstnvstreammux.h.
◆ has_peer_latency
gboolean _GstNvStreamMux::has_peer_latency
Definition at line 118 of file gstnvstreammux.h.
◆ height
unsigned int _GstNvStreamMux::height
Definition at line 55 of file gstnvstreammux.h.
◆ helper
NvStreamMux* _GstNvStreamMux::helper
Definition at line 57 of file gstnvstreammux.h.
◆ isAudio
gboolean _GstNvStreamMux::isAudio
Audio support.
Definition at line 96 of file gstnvstreammux.h.
◆ last_flow_ret
GstFlowReturn _GstNvStreamMux::last_flow_ret
Definition at line 51 of file gstnvstreammux.h.
◆ max_latency
GstClockTime _GstNvStreamMux::max_latency
Definition at line 109 of file gstnvstreammux.h.
◆ module_initialized
gboolean _GstNvStreamMux::module_initialized
Definition at line 89 of file gstnvstreammux.h.
◆ muxCtx
GstNvStreamMuxCtx* _GstNvStreamMux::muxCtx
muxer context
Definition at line 99 of file gstnvstreammux.h.
◆ no_pipeline_eos
gboolean _GstNvStreamMux::no_pipeline_eos
Definition at line 126 of file gstnvstreammux.h.
◆ ntp_calc_mode
GstNvDsNtpCalculatorMode _GstNvStreamMux::ntp_calc_mode
Definition at line 103 of file gstnvstreammux.h.
◆ num_sink_pads
guint _GstNvStreamMux::num_sink_pads
Definition at line 93 of file gstnvstreammux.h.
◆ num_surfaces_per_frame
unsigned int _GstNvStreamMux::num_surfaces_per_frame
Definition at line 72 of file gstnvstreammux.h.
◆ out_videoinfo
GstVideoInfo _GstNvStreamMux::out_videoinfo
Definition at line 70 of file gstnvstreammux.h.
◆ pad_task_created
bool _GstNvStreamMux::pad_task_created
Definition at line 74 of file gstnvstreammux.h.
◆ peer_latency_live
gboolean _GstNvStreamMux::peer_latency_live
Definition at line 117 of file gstnvstreammux.h.
◆ peer_latency_max
GstClockTime _GstNvStreamMux::peer_latency_max
Definition at line 116 of file gstnvstreammux.h.
◆ peer_latency_min
GstClockTime _GstNvStreamMux::peer_latency_min
Definition at line 115 of file gstnvstreammux.h.
◆ prev_outbuf_pts
GstClockTime _GstNvStreamMux::prev_outbuf_pts
Definition at line 111 of file gstnvstreammux.h.
◆ pts_offset
GstClockTime _GstNvStreamMux::pts_offset
Definition at line 79 of file gstnvstreammux.h.
◆ pushed_stream_start_once
bool _GstNvStreamMux::pushed_stream_start_once
Definition at line 125 of file gstnvstreammux.h.
◆ query_resolution
gboolean _GstNvStreamMux::query_resolution
Definition at line 65 of file gstnvstreammux.h.
◆ segment
GstSegment _GstNvStreamMux::segment
Definition at line 49 of file gstnvstreammux.h.
◆ segment_sent
gboolean _GstNvStreamMux::segment_sent
Definition at line 91 of file gstnvstreammux.h.
◆ send_eos
bool _GstNvStreamMux::send_eos
Definition at line 59 of file gstnvstreammux.h.
◆ sink_pad_caps
GHashTable* _GstNvStreamMux::sink_pad_caps
Definition at line 104 of file gstnvstreammux.h.
◆ srcpad
GstPad* _GstNvStreamMux::srcpad
Definition at line 46 of file gstnvstreammux.h.
◆ sync_inputs
gboolean _GstNvStreamMux::sync_inputs
Definition at line 107 of file gstnvstreammux.h.
◆ synch_buffer
NvTimeSync* _GstNvStreamMux::synch_buffer
Definition at line 113 of file gstnvstreammux.h.
◆ sys_ts
gboolean _GstNvStreamMux::sys_ts
Definition at line 102 of file gstnvstreammux.h.
◆ timeout_usec
gint _GstNvStreamMux::timeout_usec
Definition at line 68 of file gstnvstreammux.h.
◆ width
unsigned int _GstNvStreamMux::width
Definition at line 53 of file gstnvstreammux.h.
