NVIDIA GStreamer DeepStream: Custom Message Functions
Description: This file specifies the NVIDIA DeepStream GStreamer custom message functions.
Definition in file includes/gst-nvdscustommessage.h.
Functions | |
| G_BEGIN_DECLS GstMessage * | gst_nvmessage_new_stream_add (GstObject *obj, NvDsSensorInfo *sensor_info) |
| Creates a new Stream ADD message - denoting a new stream getting added to nvmultiurisrcbin. More... | |
| gboolean | gst_nvmessage_is_stream_add (GstMessage *message) |
| Determines whether a message is a stream ADD message. More... | |
| gboolean | gst_nvmessage_parse_stream_add (GstMessage *message, NvDsSensorInfo *sensor_info) |
| Parses the stream ID from a stream ADD message. More... | |
| GstMessage * | gst_nvmessage_new_stream_remove (GstObject *obj, NvDsSensorInfo *sensor_info) |
| Creates a new Stream REMOVE message - denoting a new stream getting removed from nvmultiurisrcbin. More... | |
| gboolean | gst_nvmessage_is_stream_remove (GstMessage *message) |
| Determines whether a message is a stream REMOVE message. More... | |
| gboolean | gst_nvmessage_parse_stream_remove (GstMessage *message, NvDsSensorInfo *sensor_info) |
| Parses the stream ID from a stream REMOVE message. More... | |
| gboolean | gst_nvmessage_parse_fps_stream_add (GstMessage *message, NvDsFPSSensorInfo *sensor_info) |
| gboolean | gst_nvmessage_parse_fps_stream_remove (GstMessage *message, NvDsFPSSensorInfo *sensor_info) |
| GstMessage * | gst_nvmessage_force_pipeline_eos (GstObject *obj, gboolean force_eos) |
| Sends custom message to force-eos on the pipeline. More... | |
| gboolean | gst_nvmessage_parse_force_pipeline_eos (GstMessage *message, gboolean *force_eos) |
| Parses the force_eos from a force eos message. More... | |
| gboolean | gst_nvmessage_is_force_pipeline_eos (GstMessage *message) |
| Determines whether a message is a force pipeline eos message. More... | |
| GstMessage * | gst_nvmessage_reconnect_attempt_exceeded (GstObject *obj, NvDsRtspAttemptsInfo *rtsp_info) |
| Creates a new attempt-exceeded message - denoting a reconnection attempt is exceeded for a rtsp uri. More... | |
| gboolean | gst_nvmessage_parse_reconnect_attempt_exceeded (GstMessage *message, NvDsRtspAttemptsInfo *rtsp_info) |
| Parses the NvDsRtspAttemptsInfo from a attempt-exceeded message. More... | |
| gboolean | gst_nvmessage_is_reconnect_attempt_exceeded (GstMessage *message) |
| Determines whether a message is a attempt-exceeded message. More... | |
| GstMessage* gst_nvmessage_force_pipeline_eos | ( | GstObject * | obj, |
| gboolean | force_eos | ||
The element on which custom message related to eos is to be sent.
params[in] object A gboject on which custom message to be sent params[in] force_eos A force_eos variable
| gboolean gst_nvmessage_is_force_pipeline_eos | ( | GstMessage * | message | ) |
params[in] message A pointer to the message to be checked.
| gboolean gst_nvmessage_is_reconnect_attempt_exceeded | ( | GstMessage * | message | ) |
| gboolean gst_nvmessage_is_stream_add | ( | GstMessage * | message | ) |
| gboolean gst_nvmessage_is_stream_remove | ( | GstMessage * | message | ) |
| G_BEGIN_DECLS GstMessage* gst_nvmessage_new_stream_add | ( | GstObject * | obj, |
| NvDsSensorInfo * | sensor_info | ||
params[in] obj The GStreamer object creating the message. params[in] sensor_info Sensor info of the stream which is getting added into nvmultiurisrcbin
| GstMessage* gst_nvmessage_new_stream_remove | ( | GstObject * | obj, |
params[in] obj The GStreamer object creating the message. params[in] sensor_info Sensor info of the stream which is getting removed from nvmultiurisrcbin
| gboolean gst_nvmessage_parse_force_pipeline_eos | ( | GstMessage * | message, |
| gboolean * | force_eos | ||
params[in] message A pointer to a force eos message. params[out] force_eos A pointer to force_eos variable
| gboolean gst_nvmessage_parse_fps_stream_add | ( | GstMessage * | message, |
| NvDsFPSSensorInfo * | sensor_info | ||
The stream ID is the index of the stream which is getting added to nvmultiurisrcbin
params[in] message A pointer to a stream ADD message. params[out] stream_id A pointer to NvDsSensorInfo The string NvDsFPSSensorInfo->sensor_id should not be modified, and remains valid until the next call to a gst_nvmessage_parse*() function with the given message. Please use or make copy within the bus callback scope.
| gboolean gst_nvmessage_parse_fps_stream_remove | ( | GstMessage * | message, |
The stream ID is the index of the stream which is getting removed from nvmultiurisrcbin
params[in] message A pointer to a stream REMOVE message. params[out] stream_id A pointer to NvDsSensorInfo The string NvDsFPSSensorInfo->sensor_id should not be modified, and remains valid until the next call to a gst_nvmessage_parse*() function with the given message. Please use or make copy within the bus callback scope.
| gboolean gst_nvmessage_parse_reconnect_attempt_exceeded | ( | GstMessage * | message, |
| NvDsRtspAttemptsInfo * | rtsp_info | ||
params[in] message A pointer to a attempt-exceeded message. params[out] NvDsRtspAttemptsInfo A pointer to NvDsRtspAttemptsInfo
| gboolean gst_nvmessage_parse_stream_add | ( | GstMessage * | message, |
params[in] message A pointer to a stream ADD message. params[out] stream_id A pointer to NvDsSensorInfo The string NvDsSensorInfo->sensor_id should not be modified, and remains valid until the next call to a gst_nvmessage_parse*() function with the given message. Please use or make copy within the bus callback scope.
| gboolean gst_nvmessage_parse_stream_remove | ( | GstMessage * | message, |
params[in] message A pointer to a stream REMOVE message. params[out] stream_id A pointer to NvDsSensorInfo The string NvDsSensorInfo->sensor_id should not be modified, and remains valid until the next call to a gst_nvmessage_parse*() function with the given message. Please use or make copy within the bus callback scope.
| GstMessage* gst_nvmessage_reconnect_attempt_exceeded | ( | GstObject * | obj, |
params[in] obj The GStreamer object creating the message. params[in] rtsp_info rtsp info of the stream which exceeds rtsp reconnection attempt
