8.0 Release
28 #ifndef __GST_NVDSCUSTOMMESSAGE_H__
29 #define __GST_NVDSCUSTOMMESSAGE_H__
176 gboolean * force_eos);
gboolean gst_nvmessage_parse_stream_add(GstMessage *message, NvDsSensorInfo *sensor_info)
Parses the stream ID from a stream ADD message.
gboolean gst_nvmessage_parse_fps_stream_remove(GstMessage *message, NvDsFPSSensorInfo *sensor_info)
Parses the stream ID from a stream REMOVE message.
gboolean gst_nvmessage_parse_reconnect_attempt_exceeded(GstMessage *message, NvDsRtspAttemptsInfo *rtsp_info)
Parses the NvDsRtspAttemptsInfo from a attempt-exceeded message.
gboolean gst_nvmessage_parse_stream_remove(GstMessage *message, NvDsSensorInfo *sensor_info)
struct _GstObject GstObject
gboolean gst_nvmessage_parse_fps_stream_add(GstMessage *message, NvDsFPSSensorInfo *sensor_info)
gboolean gst_nvmessage_parse_force_pipeline_eos(GstMessage *message, gboolean *force_eos)
Parses the force_eos from a force eos message.
gboolean gst_nvmessage_is_stream_remove(GstMessage *message)
Determines whether a message is a stream REMOVE message.
GstMessage * gst_nvmessage_new_stream_remove(GstObject *obj, NvDsSensorInfo *sensor_info)
Creates a new Stream REMOVE message - denoting a new stream getting removed from nvmultiurisrcbin.
GstMessage * gst_nvmessage_reconnect_attempt_exceeded(GstObject *obj, NvDsRtspAttemptsInfo *rtsp_info)
Creates a new attempt-exceeded message - denoting a reconnection attempt is exceeded for a rtsp uri.
GstMessage * gst_nvmessage_force_pipeline_eos(GstObject *obj, gboolean force_eos)
Sends custom message to force-eos on the pipeline.
gboolean gst_nvmessage_is_stream_add(GstMessage *message)
Determines whether a message is a stream ADD message.
G_BEGIN_DECLS GstMessage * gst_nvmessage_new_stream_add(GstObject *obj, NvDsSensorInfo *sensor_info)
Creates a new Stream ADD message - denoting a new stream getting added to nvmultiurisrcbin.
gboolean gst_nvmessage_is_force_pipeline_eos(GstMessage *message)
Determines whether a message is a force pipeline eos message.
gboolean gst_nvmessage_is_reconnect_attempt_exceeded(GstMessage *message)
Determines whether a message is a attempt-exceeded message.
