7.1 Release
13 #ifndef _GST_NVDSCOMMON_CONFIG_H_
14 #define _GST_NVDSCOMMON_CONFIG_H_
120 gint pipeline_height;
121 gint batched_push_timeout;
127 gint buffer_pool_size;
129 gint num_surfaces_per_frame;
130 gint interpolation_method;
132 guint nvbuf_memory_type;
133 gboolean live_source;
134 gboolean enable_padding;
135 gboolean attach_sys_ts_as_ntp;
136 gchar* config_file_path;
137 gboolean sync_inputs;
139 gboolean frame_num_reset_on_eos;
140 gboolean frame_num_reset_on_stream_reset;
142 guint64 frame_duration;
144 gboolean async_process;
145 gboolean no_pipeline_eos;
146 gboolean extract_sei_type5_data;
NvDsUriSrcBinSRCont smart_rec_container
struct _NvDsRtspAttemptsInfo NvDsRtspAttemptsInfo
struct _GstDsNvUriSrcConfig GstDsNvUriSrcConfig
NvDsUriSrcBinType src_type
NvDsUriSrcBinSRType smart_record
guint64 ipc_connection_interval
gboolean disable_passthrough
gchar * sensorId
unique Sensor ID string
gchar * smart_rec_file_prefix
gchar const * sensor_name
@ DEC_SKIP_FRAMES_TYPE_KEY_FRAME_ONLY
guint drop_frame_interval
gchar * sensorName
Sensor Name string; could be NULL.
NvDsUriSrcBinDecSkipFrame
@ DEC_SKIP_FRAMES_TYPE_NONREF
guint smart_rec_def_duration
guint smart_rec_cache_size
gboolean low_latency_mode
gchar * smart_rec_dir_path
NvDsUriSrcBinSRMode smart_rec_mode
@ DEC_SKIP_FRAMES_TYPE_NONE
NvDsUriSrcBinRtpProtocol rtp_protocol
NvDsUriSrcBinDecSkipFrame skip_frames_type
gint rtsp_reconnect_interval_sec
gint ipc_connection_attempts
struct _NvDsSensorInfo NvDsSensorInfo
gboolean ipc_buffer_timestamp_copy
gint rtsp_reconnect_attempts
gboolean attempt_exceeded
