7.1 Release
infer_custom_process.h File Reference
Data Structures
class  nvdsinferserver::IInferCustomProcessor
 Interface of Custom processor which is created and loaded at runtime through CreateCustomProcessorFunc. More...
Namespaces
 nvdsinferserver
Typedefs
typedef nvdsinferserver::IInferCustomProcessor *(* CreateCustomProcessorFunc) (const char *config, uint32_t configLen)
 Custom processor context is created and loaded in runtime. More...
Typedef Documentation
◆ CreateCustomProcessorFunc
typedef nvdsinferserver::IInferCustomProcessor*(* CreateCustomProcessorFunc) (const char *config, uint32_t configLen)
Parameters
[in]configContents of prototxt configuration file serialized as a string.
[in]configLenuse for string length of config
Returns
new instance of IInferCustomProcessor. If failed, return nullptr
Definition at line 113 of file infer_custom_process.h.
