Loading [MathJax]/jax/output/HTML-CSS/config.js
8.0 Release
infer_datatypes.h File Reference
Header file for the data types used in the inference processing.
Definition in file infer_datatypes.h.
Data Structures
struct  nvdsinferserver::InferDims
 Holds the information about the dimensions of a neural network layer. More...
struct  nvdsinferserver::InferBatchDims
 Holds full dimensions (including batch size) for a layer. More...
struct  nvdsinferserver::InferBufferDescription
 Holds the information about a inference buffer. More...
class  nvdsinferserver::IBatchBuffer
 Interface class for a batch buffer. More...
class  nvdsinferserver::IBatchArray
 Interface class for an array of batch buffers. More...
Namespaces
 nvdsinferserver
Typedefs
using nvdsinferserver::SharedIBatchBuffer = std::shared_ptr< IBatchBuffer >
using nvdsinferserver::SharedIBatchArray = std::shared_ptr< IBatchArray >
using nvdsinferserver::SharedIOptions = std::shared_ptr< IOptions >
Enumerations
enum  nvdsinferserver::InferTensorOrder : int {
  nvdsinferserver::InferTensorOrder::kNone = 0,
  nvdsinferserver::InferTensorOrder::kLinear = 1,
  nvdsinferserver::InferTensorOrder::kNHWC = 2
 The type of tensor order. More...
enum  nvdsinferserver::InferMemType : int {
  nvdsinferserver::InferMemType::kNone = 0,
  nvdsinferserver::InferMemType::kGpuCuda = 1,
  nvdsinferserver::InferMemType::kCpu = 2,
  nvdsinferserver::InferMemType::kCpuCuda = 3,
  nvdsinferserver::InferMemType::kNvSurface = 5,
  nvdsinferserver::InferMemType::kNvSurfaceArray = 6
 The memory types of inference buffers. More...
enum  nvdsinferserver::InferDataType : int {
  nvdsinferserver::InferDataType::kFp32 = FLOAT,
  nvdsinferserver::InferDataType::kFp16 = HALF,
  nvdsinferserver::InferDataType::kInt8 = INT8,
  nvdsinferserver::InferDataType::kInt32 = INT32,
  nvdsinferserver::InferDataType::kInt16 = 7,
  nvdsinferserver::InferDataType::kUint8,
  nvdsinferserver::InferDataType::kUint16,
  nvdsinferserver::InferDataType::kUint32,
  nvdsinferserver::InferDataType::kFp64,
  nvdsinferserver::InferDataType::kInt64,
  nvdsinferserver::InferDataType::kUint64,
  nvdsinferserver::InferDataType::kString,
  nvdsinferserver::InferDataType::kBool,
  nvdsinferserver::InferDataType::kNone = -1
 Datatype of the tensor buffer. More...
enum  nvdsinferserver::InferPostprocessType : int {
  nvdsinferserver::InferPostprocessType::kDetector = 0,
  nvdsinferserver::InferPostprocessType::kClassifier = 1,
  nvdsinferserver::InferPostprocessType::kSegmentation = 2,
  nvdsinferserver::InferPostprocessType::kTrtIsClassifier = 3,
  nvdsinferserver::InferPostprocessType::kOther = 100
 Inference post processing types. More...
enum  nvdsinferserver::InferMediaFormat : int {
  nvdsinferserver::InferMediaFormat::kRGB = 0,
  nvdsinferserver::InferMediaFormat::kBGR,
  nvdsinferserver::InferMediaFormat::kGRAY,
  nvdsinferserver::InferMediaFormat::kRGBA,
  nvdsinferserver::InferMediaFormat::kBGRx,
  nvdsinferserver::InferMediaFormat::kUnknown = -1
 Image formats. More...
