nvdsinferserver::InferBufferDescription Struct Reference
Holds the information about a inference buffer.
Definition at line 168 of file sources/includes/nvdsinferserver/infer_datatypes.h.
Inheritance diagram for nvdsinferserver::InferBufferDescription:
Collaboration diagram for nvdsinferserver::InferBufferDescription:
Data Fields
InferMemType memType
 Memory type of the buffer allocation. More...
long int devId
 Device (GPU) ID where the buffer is allocated. More...
InferDataType dataType
 Datatype associated with the buffer. More...
InferDims dims
 Dimensions of the tensor. More...
uint32_t elementSize
 Per element bytes, except kString (with elementSize is 0) More...
std::string name
 Name of the buffer. More...
bool isInput
 Boolean indicating input or output buffer. More...
Field Documentation
◆ dataType
InferDataType nvdsinferserver::InferBufferDescription::dataType
◆ devId
long int nvdsinferserver::InferBufferDescription::devId
Definition at line 176 of file sources/includes/nvdsinferserver/infer_datatypes.h.
◆ dims
InferDims nvdsinferserver::InferBufferDescription::dims
◆ elementSize
uint32_t nvdsinferserver::InferBufferDescription::elementSize
Definition at line 188 of file sources/includes/nvdsinferserver/infer_datatypes.h.
Referenced by nvdsinferserver::RefBatchBuffer::getBufOffset(), and nvdsinferserver::RefBatchBuffer::getBufPtr().
◆ isInput
bool nvdsinferserver::InferBufferDescription::isInput
Definition at line 196 of file sources/includes/nvdsinferserver/infer_datatypes.h.
◆ memType
InferMemType nvdsinferserver::InferBufferDescription::memType
Definition at line 172 of file sources/includes/nvdsinferserver/infer_datatypes.h.
◆ name
std::string nvdsinferserver::InferBufferDescription::name
