7.1 Release
infer_defines.h File Reference
Macros
#define DISABLE_CLASS_COPY(NoCopyClass)
#define SIMPLE_MOVE_COPY(Cls)
#define INFER_UNUSED(a)   (void)(a)
#define INFER_LOG_FORMAT_(fmt)   "%s:%d " fmt, __FILE__, __LINE__
#define INFER_EXPORT_API   __attribute__((__visibility__("default")))
#define InferError(fmt, ...)
#define InferWarning(fmt, ...)
#define InferInfo(fmt, ...)
#define InferDebug(fmt, ...)
#define RETURN_IF_FAILED(condition, ret, fmt, ...)
#define CHECK_NVINFER_ERROR_PRINT(err, action, logPrint, fmt, ...)
#define CHECK_NVINFER_ERROR(err, action, fmt, ...)   CHECK_NVINFER_ERROR_PRINT(err, action, InferError, fmt, ##__VA_ARGS__)
#define RETURN_NVINFER_ERROR(err, fmt, ...)   CHECK_NVINFER_ERROR(err, return ifStatus, fmt, ##__VA_ARGS__)
#define CONTINUE_NVINFER_ERROR(err, fmt, ...)   CHECK_NVINFER_ERROR(err, , fmt, ##__VA_ARGS__)
#define CHECK_CUDA_ERR_W_ACTION(err, action, logPrint, fmt, ...)
#define CHECK_CUDA_ERR_NO_ACTION(err, fmt, ...)   CHECK_CUDA_ERR_W_ACTION(err, , InferError, fmt, ##__VA_ARGS__)
#define RETURN_CUDA_ERR(err, fmt, ...)
#define CONTINUE_CUDA_ERR(err, fmt, ...)   CHECK_CUDA_ERR_NO_ACTION(err, fmt, ##__VA_ARGS__)
#define READ_SYMBOL(lib, func_name)   lib->symbol<decltype(&func_name)>(#func_name)
#define DIVIDE_AND_ROUND_UP(a, b)   ((a + b - 1) / b)
#define INFER_ROUND_UP(value, align)   (((value) + (align)-1) & (~((align)-1)))
#define INFER_ROUND_DOWN(value, align)   ((value) & (~((align)-1)))
#define INFER_WILDCARD_DIM_VALUE   -1
#define INFER_MEM_ALIGNMENT   1024
◆ CHECK_CUDA_ERR_NO_ACTION
#define CHECK_CUDA_ERR_NO_ACTION (   err,
  fmt,
Definition at line 108 of file infer_defines.h.
◆ CHECK_CUDA_ERR_W_ACTION
#define CHECK_CUDA_ERR_W_ACTION (   err,
  action,
  logPrint,
  fmt,
Value:
do { \
cudaError_t errnum = (err); \
if (errnum != cudaSuccess) { \
logPrint(fmt ", cuda err_no:%d, err_str:%s", ##__VA_ARGS__, \
(int)errnum, cudaGetErrorName(errnum)); \
action; \
} while (0)
Definition at line 98 of file infer_defines.h.
◆ CHECK_NVINFER_ERROR
#define CHECK_NVINFER_ERROR (   err,
  action,
  fmt,
Definition at line 88 of file infer_defines.h.
◆ CHECK_NVINFER_ERROR_PRINT
#define CHECK_NVINFER_ERROR_PRINT (   err,
  action,
  logPrint,
  fmt,
Value:
do { \
NvDsInferStatus ifStatus = (err); \
if (ifStatus != NVDSINFER_SUCCESS) { \
auto errStr = NvDsInferStatus2Str(ifStatus); \
logPrint(fmt ", nvinfer error:%s", ##__VA_ARGS__, errStr); \
action; \
} while (0)
Definition at line 78 of file infer_defines.h.
◆ CONTINUE_CUDA_ERR
#define CONTINUE_CUDA_ERR (   err,
  fmt,
Definition at line 115 of file infer_defines.h.
◆ CONTINUE_NVINFER_ERROR
#define CONTINUE_NVINFER_ERROR (   err,
  fmt,
Definition at line 94 of file infer_defines.h.
◆ DISABLE_CLASS_COPY
#define DISABLE_CLASS_COPY (   NoCopyClass)
Value:
NoCopyClass(const NoCopyClass&) = delete; \
void operator=(const NoCopyClass&) = delete
Definition at line 25 of file infer_defines.h.
◆ DIVIDE_AND_ROUND_UP
#define DIVIDE_AND_ROUND_UP (   a,
)    ((a + b - 1) / b)
Definition at line 121 of file infer_defines.h.
◆ INFER_EXPORT_API
Definition at line 44 of file infer_defines.h.
◆ INFER_LOG_FORMAT_
#define INFER_LOG_FORMAT_ (   fmt)    "%s:%d " fmt, __FILE__, __LINE__
Definition at line 41 of file infer_defines.h.
◆ INFER_MEM_ALIGNMENT
Definition at line 125 of file infer_defines.h.
◆ INFER_ROUND_DOWN
#define INFER_ROUND_DOWN (   value,
  align
Definition at line 123 of file infer_defines.h.
◆ INFER_ROUND_UP
#define INFER_ROUND_UP (   value,
  align
Definition at line 122 of file infer_defines.h.
◆ INFER_UNUSED
#define INFER_UNUSED (   a)    (void)(a)
Definition at line 36 of file infer_defines.h.
◆ INFER_WILDCARD_DIM_VALUE
Definition at line 124 of file infer_defines.h.
◆ InferDebug
#define InferDebug (   fmt,
Value:
do { \
dsInferLogPrint__( \
NVDSINFER_LOG_DEBUG, INFER_LOG_FORMAT_(fmt), ##__VA_ARGS__); \
} while (0)
Definition at line 64 of file infer_defines.h.
◆ InferError
#define InferError (   fmt,
Value:
do { \
NVDSINFER_LOG_ERROR, INFER_LOG_FORMAT_(fmt), ##__VA_ARGS__); \
} while (0)
Definition at line 46 of file infer_defines.h.
◆ InferInfo
#define InferInfo (   fmt,
Value:
do { \
NVDSINFER_LOG_INFO, INFER_LOG_FORMAT_(fmt), ##__VA_ARGS__); \
} while (0)
Definition at line 58 of file infer_defines.h.
◆ InferWarning
#define InferWarning (   fmt,
Value:
do { \
NVDSINFER_LOG_WARNING, INFER_LOG_FORMAT_(fmt), ##__VA_ARGS__); \
} while (0)
Definition at line 52 of file infer_defines.h.
◆ READ_SYMBOL
#define READ_SYMBOL (   lib,
  func_name
Definition at line 118 of file infer_defines.h.
◆ RETURN_CUDA_ERR
#define RETURN_CUDA_ERR (   err,
  fmt,
Value:
err, return NVDSINFER_CUDA_ERROR, InferError, fmt, ##__VA_ARGS__)
Definition at line 111 of file infer_defines.h.
◆ RETURN_IF_FAILED
#define RETURN_IF_FAILED (   condition,
  ret,
  fmt,
Value:
do { \
if (!(condition)) { \
InferError(fmt, ##__VA_ARGS__); \
return ret; \
} while (0)
Definition at line 70 of file infer_defines.h.
◆ RETURN_NVINFER_ERROR
#define RETURN_NVINFER_ERROR (   err,
  fmt,
Definition at line 91 of file infer_defines.h.
◆ SIMPLE_MOVE_COPY
#define SIMPLE_MOVE_COPY (   Cls)
Value:
Cls& operator=(Cls&& o) { \
move_copy(std::move(o)); \
return *this; \
Cls(Cls&& o) { move_copy(std::move(o)); }
Definition at line 29 of file infer_defines.h.
NVDSINFER_LOG_ERROR
@ NVDSINFER_LOG_ERROR
Definition: nvdsinfer.h:252
NVDSINFER_SUCCESS
@ NVDSINFER_SUCCESS
Definition: nvdsinfer.h:222
INFER_LOG_FORMAT_
Definition: infer_defines.h:41
NVDSINFER_LOG_INFO
@ NVDSINFER_LOG_INFO
Definition: nvdsinfer.h:254
@ NVDSINFER_LOG_WARNING
Definition: nvdsinfer.h:253
@ NVDSINFER_CUDA_ERROR
CUDA error was encountered.
Definition: nvdsinfer.h:233
InferError
#define InferError(fmt,...)
Definition: infer_defines.h:46
NVDSINFER_LOG_DEBUG
@ NVDSINFER_LOG_DEBUG
Definition: nvdsinfer.h:255
NvDsInferStatus2Str
const INFER_EXPORT_API char * NvDsInferStatus2Str(NvDsInferStatus status)
Returns the NvDsInferStatus enum name as a string.
#define CHECK_CUDA_ERR_W_ACTION(err, action, logPrint, fmt,...)
Definition: infer_defines.h:98
