7.1 Release
infer_grpc_client.h File Reference
Header file for the gRPC client and request class for inference using the Triton Inference Server. Uses the Triton client library for inference using gRPC.
Definition in file infer_grpc_client.h.
Data Structures
class  nvdsinferserver::TritonGrpcRequest
 Triton gRPC inference request class holding data associated with one inference request. More...
class  nvdsinferserver::InferGrpcClient
 Wrapper class for the gRPC client of the Triton Inference Server, interfaces with the Triton client library. More...
Namespaces
 nvdsinferserver
Typedefs
typedef std::map< std::string, std::string > nvdsinferserver::Headers
using nvdsinferserver::SharedGrpcRequest = std::shared_ptr< TritonGrpcRequest >
using nvdsinferserver::TritonGrpcAsyncDone = std::function< void(NvDsInferStatus, SharedBatchArray)>
